Question about Kenmore Refrigerators
Not holding temp
Frig is on but warm could it be on a automatic defrost cycle?
    Genius:
  • 2,920 Answers
No not many frigdes came out with auto frost i think its on its last legs
Posted on Jan 12, 2009
Ge side by side frig won't defrost gss25sgmb new heater motherboard thermostats
Replace the thermistors #4 and #5 . 4 is the white bullet looking piece on top of the coils inside the freezer , with 2 white wires . 5 is at the bottom of the freezer , on the left side . These thermistors tell the main board , the temp and the board goes into defrost according to temp the thermistors "tell it " .
Aug 14, 2012 | GE GSS25SGMBS Side by Side Refrigerator
My GE profile side by side frig goes into defrost mode more often, every 1-2 days. Temps go up to 46 degrees for frig and 8 degrees for freezer. It doesn't take too long before it cools back down. Is...
. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
Mar 08, 2011 | GE Refrigerators
ON A NEW FRIG, KITCHEN AID KSCS23FVMK, HOW DOES THE DEFROST CYCLE WORK? DOES IT ONLY COME ON WHEN IT NEEDS DEFROSTING OR DOES IT DEFROST EVERY 8 HOURS OR SO BY TIMER IF IT NEEDS IT OR NOT?
It's fully automatic -- it will very briefly kick on the defrost cycle once a day (variable by model) to prevent frost buildup, but not long enough to warm the food.
Sep 26, 2010 | Refrigerators
GE GSH22KGM Frig not defrosting again
I would suggest replacing the # 4 thermistor , which is a 1 " long white piece with 2 white wires attached , clipped to the top of the coils . This thermistor , tells the main control board , the temperature of the coils and the board decides what to do next , such as defrost , end defrost cycle . Also , replace the defrost thermostat , the 1 inch cylinder with 2 wires going to it , which is also clipped onto the coils . This thermostat , cuts the heater off when it reaches a certain temperature , to keep the food from defrosting . It may also help , to replace the # 5 thermistor , which is below the coils , slid into a housing , with 2 white wires going to it also . This thermistor , tells the board , the actual freezer temp , so the compressor will cycle off/on , and the fan speed also . All 3 parts , are relatively not expensive . Be sure to get wire connectors because they do not come with these parts .
Apr 14, 2010 | GE GSH22KGM Side by Side Refrigerator
GE Profile Refrigerator defrost cycle last hours
it;s probably not going through the defrost cycle or its getting stuck in defrost .. on the back of frig the is a metal cover plate . in side you will find the main board . replace it . it runs the compressor and defrost and controls tempt . this is a very common problem . the new boards are better . and they cost a litle more . mm hope this helped / feed back pls .
Feb 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Temperature going up on freezer and frig overnight
The Unit has a defrost cycle either every six,tweelve,or twentyfour hours.It sounds like the thermal cut out is faulty located in the freezer side behind the wall where the fan is situated It is usually a steel round disk shaped sensor with two wires coming out of it.It,s purpose is to shut the power off to the defrosting element once it reaches the desired temperature to melt the ice away and them the unit cycles again after defrosting.Hope this helps.
Dec 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Our 4 year old GE side by side frig suddenly warmed to 64 degrees. Freezer stopped freezing and is at 43. Motor is running.
Really need to know what motor(s) are running (compressor, evap fan inside freezer compartment, condenser fan under fridge)?? Of course, check your temperature (thermostat) settings. Side-by-sides usually have 2 of them. They should be labled for refridgerator and freezer. The freezer control usually only opens a baffle from the freezer compartment to the refridge compartment. The refrigerator temp control is the one that controls the compressor on-off cycles and the temp of refrig compartment (this keeps the refrig compartment from freezing the milk and cokes) If the freezer control/baffle is set too far open, this will cause the refrig temp control to shut off too soon for the freezer temp to get low enough. These controls can get bumped out of the correct setting accidently from time to time.
To check the following, the fridge has to be running, or in a condition where it "should be" running: If compressor is running (condenser fan should be too), check if evaporator fan (inside freezer) is running. Open (freezer) door and hold door light switch in when you check evaporator fan operation (some fans stop when door is open) If it is not running you may have a bad evaporator fan motor. It could also be a bad defrost timer, causing the evaporator (also inside back of freezer) to ice-up. This blocks the air flow over evap. Also, there is a defrost terminator switch on the evaporator coil that stops the defrost cycle when coil is clear of ice/frost (but timer hasn't ended defrost cycle). If it is defective, that could also keep the fridge from going into the defrost cycle, or taking it out too soon. If it is the timer, change the defrost terminator as well. Depending on how handy you are, you may be able to check/change any of these parts yourself. If you don't know much about elecrical stuff, you should leave it to a repair tech. Hope this helps.
Jun 25, 2009 | GE Refrigerators
Hotpoint frig,top freezer motor runs contiunally, thermostat set in middle of temp. control. side of frig stays cool all time.[does not get warm as it used to] is defrost thermostat bad or timer?
niether. is there frost on back wall of freezer? if no look behind back wall and see if there is frost on all the coils when running. if less than 80% is frosty...freon. or is there frost covering back panel..if so then defrost problem would be correct. but side would be warm so I think not.
Jun 12, 2009 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
Temp is erratic too warm, too cold ....
Sounds like the defrost timer is not working correctly or the start capacitor is malfunctioning,Both are cheap and easy fixes.
May 09, 2009 | Refrigerators
Auot defrost problem?
cleaning the condensor is nothing to do with evaporator freezing up. keep an eye on it - you may have a problem with the defrost cycle. problem can also happen if freezer door has been left open
Jul 21, 2008 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
53 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
