Question about Ovens
The bottom element in my whirlpool akp526/av oven needs replacing but it is a hidden element and I am not sure how to access it to fit a new one. Does anyone know how to open the oven to access the bottom element?
3 Suggested Answers
  • 38 Answers
SOURCE: how to replace a fan bake oven hidden element
Before attempting any repairs, make sure the power is turned off! If you are unsure or not confident, please call a service technician.
The element is behind a cover that is held in place either by screws or clips. Once the cover is removed, the element will be visible. The element will be screwed in place by a number of screws on the base plate and around the element itself. After removing the screws, pull the element fron the rear of the oven. the wires should be attached to the element via lugs. The lugs need to be unattached from the element. Before removing the wiring, take note of the connections so that reinstallation can be carried out.
Posted on Nov 22, 2009
apart4u
  • 213 Answers
SOURCE: Zanussi ZDQ 595 fan oven not heating
Here is a free video to help you with your cooker fan motor problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feedback please
For all your parts visit our site http://www.apart4u.co.uk
Posted on May 27, 2010
How do you remove the moulded Hidden Bake Element from the inside whirlpool ceramic range accubake system
first, remove power from the unit before doing ANYTHING! second, remove the back cover of the machine, this will expose another smaller panel with 4-6 screws in it running along the bottom edge across the back. after removing the screws you will have to gently BEND the panel down until you can see the wiring leading to the hidden bake element. cut the insulation covering the back of the element... be sure new element is placed in the exact location of the old one to avoid shorting the bake terminals to the metal cover, then reverse the removal process...
Apr 26, 2016 | Whirlpool 30" Self-Cleaning Freestanding...
How to replace the lower, hidden bake element in the lower oven of an Electrolux Icon oven
You need a 1/4 or 1/16 mm. to take it out, they always have a simgle plug.
Nov 13, 2013 | Electrolux Ovens
How to get access to bottom element (not visible modle) to replace ir?
That model is not shown as hidden bake but the bottom would have have to lift up to uncover the element .
Nov 19, 2010 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool Range GR563LXSSo Oven doesn't come up to temperature. How do you get access to the hidden bake element to check connection and voltage?
Hello- Access is thru left side panel (from front).  Unplug oven and move out for easier access. Remove panel and find cover for element under insulation. Be careful- fiberglass dust and sharp edges!  Insulation needs to be carefully pulled back enough to remove cover and element.  This is where most techs get sloppy-  Insulation should look just as good after you finish so take some time to do it right. Please acknowledge this posted solution if helpful. I have more info if needed.- Thanks- Ed
Mar 24, 2010 | Whirlpool Ovens
Dual Oven - upper oven bake element replaced but no heat from it
Usually no internal fuses, and most of the time the controller is rated for fault interupt current.... age will degrade them though...
How did you change the element without pulling out the stove? is it a 'click/plug' in? might be that the socket is messed up...
You should not have to disassemble the cabinet, should just be a few screws and the unit slides out... sometimes hidden behind small movable pannels..
Peace
Feb 27, 2010 | Ovens
I need to replace my bake element on the bottom of the oven. I have removed the plate but do not know how the wires disconnect
they are just a push-on spade terminal,pull them off replace the element and carefully push-on the terminals to the element
Nov 18, 2009 | Whirlpool GSC278PJS Oven
I am looking at buying the new hidden heat element
It sure can. Whirlpool has some wonderful appliances and their ovens have a very large capacity for your Thanksgiving turkey or what ever you cook. The best of luck to you and enjoy your huge new 30" oven.
Sep 07, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Replacement of bottom oven element for Whirlpool oven
its only screwed in to back wall no???if screws rusted well then drill htem out.hidden bake elemnet??hidden under oven cavity??in that case right side wall of unit comes off( a few screws down back side of panel and it removes from the side.(shut power first this element is always live!!!!!!!
Feb 24, 2008 | Ovens
Ovens Logo
56 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
