Question about Sanyo DP37647 37 in. LCD TV
There are 2 crescent shaped shadows - Sanyo DP37647 37 in. LCD TV
    Top Expert:
  • Sanyo Master
  • 14,553 Answers
Are they on the outside of the screen--can be seen with set turned off? failing that try to get a good photo and post it here.
Posted on Dec 06, 2012
How to remove and reinstall oven door
  1. open door half way
  2. lift firmly up and tilt back and downward at the same time
  3. It is a crescent moon shape hinge and will release and pull out fairly easy. no tools needed
  4. reverse procedure to install
Let me no if this helps Mike
Mar 18, 2016 | Ovens
Coolant leak on Ford Bronco 2 engine?
this part your looking at is a form of a freeze plug... the three prongs is a block heater. it can be replaced with a normal freeze plug or replace it with another and plug it in on these cold cold nights..
Feb 11, 2014 | Ford Bronco II Cars & Trucks
I'm using the Nikon ECLIPSE e800 microscope and for some reason there is a shadow on half of my slide. Also, I can usually find and take pictures of slides with the lamp adjusted at about 5 or so but...
There are a few things that could cause a shadow in the field of view. First if the condenser is not centered, this can create a crescent shaped shadow and rob your image of light. Center the condenser and raise it to within about a 16th of an inch from the top of the stage.
Second, the slider on the head which diverts light from the eyepieces to the camera must be fully engaged to the "camera" position
Third, make sure that the diaphragm on the condenser is not closed too far. There is an adjustment ring for this. Set it to 70-80% of the numerical aperture of the objective you are using.
Fourth: if there is a "swing out" condenser lens you will need it completely in or out depending on the objective you are using. for 2x-5x you need the swing out condenser lens completely out of the light path. For objectives 10x and up you need the swing out condenser lens completely in and centered in the light path.
If these things are properly adjusted you should not have a shadow in the field of view. If you still have a problem, let me know.
Dec 17, 2010 | Nikon Science & Laboratory
Km-630mae/where does the L-shaped metal bracket fit inside the float switch. It fell out
small bracket does not go inside, but outside the float switch. It goes behind where the float switch mounts. A screw goes thru the float, the bracket, and then into the machine. It holds the float level to it's adjustment.
Sep 02, 2010 | Hoshizaki KM-630M Crescent Cuber Ice Maker
I cant remove the blade or mesh basket to clean it.
you need the orange crescent shaped tool to loosen the filter
Jun 28, 2010 | Jack Lalanne Power Juicer 250 Watts
Crescent shaped image on screen - RCA 56" P56926
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and also check the power resistor, if values are not exact you have to replace them. These ICs are located behind the black heat sink; you can see once you open the back off the TV. Also, the convergence board should be checked for cracked solder joints and please make sure to check the resistors as if they are shot the ICs might blow again. All this is only recommended if you have electrical expertise and know how to solder/re-solder components, if not then you should get this done by a professional. The typical cost to get this fixed by a pro is around $250-$300. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Apr 07, 2010 | RCA P52926 52" Rear Projection Television
Need to take apart to clean ,cant find manual
If yours is the "express" you can download it off a website. Google search, "Jack LaLanne's Power Juicer OWNER'S MANUAL."
My model was different and needed this stupid little "crescent wrench." Not a normal crescent wrench, but a crescent moon shaped handle with two little knob things sticking out that fit into the two holes in the top of the blade. It screwed counter-clockwise until parts all came out for cleaning.
(hint: I never toss my owner's manual, but I couldn't find it anywhere until I saw on the box that it said it came with a recipe book. I went to my recipe book cabinet, and there was the owner's manual - in the recipe book.)
Good luck.
Nov 01, 2009 | Jack Lalanne Power Juicer 250 Watts
Electric dryer leaving brown marks on clothes
i would asssume that the marks are "crescent moon" in shape??? if so either the front or rear felt has/is going bad and casuing clothes to slip betweent the tub and the seal causing the streaks
Mar 14, 2009 | Whirlpool Dryers
Jack Lalanne power juicer classic crescent tool missing
Scroll down a little and theres the cresent tool. It has free shipping and its $7.99
https://www.unitycart.com/pjss/accessories/parts_classic.asp
Oct 18, 2008 | Jack Lalanne Power Juicer 250 Watts
Sanyo DP37647 37 in. LCD TV Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
