Question about Panasonic Video Cameras
PANASONIC NV-S20 DC POWER lead - Panasonic Video Cameras
3 Suggested Answers
  • 4 Answers
SOURCE: Charging Panasonic NV-DS38
Yes that is correct.
You have to use a separate charger as the "DC in" socket is on the camera body underneath the battery.
Posted on Nov 25, 2009
  • 1043 Answers
SOURCE: What leads do I need to connect my Panasonic NV-GS30
There is an optional cable available for your camera called the VW-CD1E that will make use of the firewire (DV) port on your camera. You will also need to have some sort of a video capture program like Adobe Premiere so that you can download the video from your camera and then edit or display it. You should be able to order the cable from any Panasonic retailer. The better electronic / video stores will probably have it in stock.
Posted on Apr 18, 2010
Apr 18, 2010 | Panasonic NV-GS30 Mini DV Digital...
Jul 21, 2009 | Panasonic NV-DS38 Mini DV Digital...
Completlly stop working after wrong polarity lead been plugged In
one of the first things that go are is the protection diode coming off the + input. Then a fuse and so on. Surface mount fuses are light in color (usially green with white text). Attempt to bypass these components with a small wire or paperclip. Once you follow the lead from positive input you will run into a black rectangular block about the size of a grain of rice with 3 leads. That will be your voltage regulator. Its set at the correct voltage, and since you already have a power supply with a set voltage, then you dont need it. Its also the first thing that blows when you switch polaritys. (voltage regulators have 3 pins - input output and ground) when you switch polaritys that ground becomes the "input" and ..... go to all http://www.alldatasheet.com/ and type in the text you see on that component. It will then identify the component and list its voltage output and at which pin.  Apply set voltage to lead and ... pray?
Best of luck.
May 25, 2009 | Panasonic NV-DS60 Mini DV Digital...
Panasonic NV-V8000 no apparent power ,fails to switch on
Check all the small size capacitors on the power board (switching ps). There is a small capacitor that will need to be replaced sooner or later. (They dry out with age).
Dec 30, 2008 | Panasonic Televison & Video
Transferring VHS-C tapes from a Panasonic NV-RX14B to my PC
Search Ebay for peripherals to transfer tape to PC - they come with all leads and software.
Mar 28, 2017 | Panasonic NV-VZ14 VHS-C Analog Camcorder
Connect Panasonic NV-DS27B Mini DV Digital Camcorder To PC ?
If you want to do the job properly for fully remote video editing, etc then you need a digital video capture card fitting into your PC and a firewire lead that suits your particular camera.
If it helps then I have the very thing for sale if your'e quick!!!
Martin :o)
Apr 06, 2008 | Panasonic NV-DS27B Mini DV Digital...
Video Cameras Logo
55 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
