Question about Brother DCP-7040 Laser Printer
Reset the unit - Brother DCP-7040 Laser Printer
    New Friend:
    Problem Solver:
  • 5 Answers
My garmin 200 gps is not coming on?
Try performing a soft reset on the unit.
Resetting Your nüvi
If your unit stops responding, turn off the unit, and then turn it back on. If this does not help, perform a reset using the reset button on the bottom of the unit.
Caution: Do not reset your nüvi with a ballpoint pen or other sharp object, which can damage your unit.
1. Disconnect the nüvi from external power.
2. Press the Reset button on the bottom of the nüvi.
3. Connect the nüvi to a power source.
A hard reset can also be done but will erase all the user data.
This is done by with the unit off and pressing and holding the bottom right hand corner of the screen while turning the unit on.
You could also try running the Garmin WebUpdater.
Download and Install WebUpdater.
Sep 15, 2011 | Garmin nuvi 200W GPS Receiver
Screen does nothing just says garmin
Resetting Your nüvi
Aug 24, 2011 | Garmin nuvi 205W GPS Receiver
Need to reset to factory settings
Try this hard reset method:
  • With the unit powered on, press and hold the reset button on back of unit for 30 seconds
  • Without releasing the reset button, unplug the unit and hold reset for another 30 seconds
  • Plug the unit back in STILL holding the reset button a final 30 seconds
Aug 16, 2011 | Linksys WRT160N Wireless Router
No signal- from my wireless route can not clear arp cahe Linksys sat my wrt54g is old
Perform a 30/30/30 reset; aka Hard Reset.
Hard Reset (aka 30/30/30 reset): The following procedure will clear out the NVRAM and set dd-wrt back to default values:
Mar 06, 2011 | Linksys Wireless-G WRT54G Router
I have a 1475 Magellan GPS which will not acquire the signal. My unit was on for over four hours last night, trying to acquire the satellite signal. How do I solve this problem?
I can understand the problem in the unit, so to over come this problem you have to reset the unit .When you reset the unit surely the unit will it acquire the satellite signal also it show your current location.Follow the steps to reset the unit :
On the left hand side at the lower bottom coner you can see a small pin hole there named as reset .Just insert a paper clip in to the hole when the unit is on.this is the way to reset the unit......
Feb 18, 2011 | GPS
Magellan 315 frozen
Occasionally, a unit will need to be reset. This can be due to software errors, firmware updates or simply at the command of technical support staff. A reset either will restart the unit, possibly clearing up any minor errors, or will restore the unit to the settings it was built with. There are three major Magellan units, which utilize different methods to perform this task.
Things You'll Need:
  • A thin object (such as a paper clip)
Using the stylus, tap "Main Menu" and select "View."
Tap "Settings," and select "Restore Factory Settings." You will be given the option to confirm this action. Be sure that you want to reset to the settings that the GPS was built with. This action is irreversible.
Tap "Confirm," and the unit will begin to reset.
Maestro/Roadmate GPS Units
Locate the button marked "Reset" on the left, right or bottom of the unit.
Using a thin object, such as a paper clip, depress the button for two to three seconds. The unit should reset.
If the unit does not reset, immediately press the button again and hold it for up to 10 seconds.
Tips & Warnings
  • Do not attempt to perform a factory reset on the Roadmate or Maestro GPS units by holding down both the "Reset" and "Power" buttons. This will cause the GPS unit to format its own hard drive. Doing so will erase all data, including the GPS software, from the unit.
Jul 20, 2010 | Magellan GPS 315 GPS Receiver
The fax log will not load when prompted
Please perform the resets given below and check if you are able to print the fax log. Please perform all the resets.
*** Partial Reset ***
* Turn on the unit
* Disconnect the power cord from the back of the unit
* Press # and 3 buttons simultaneously while plugging the power cord to the unit.
*** Semifull Reset ***
* Turn on the unit
* Press # and 6 buttons simultaneously while plugging the power cord to the unit.
*** NVM Reset ***
* Turn on the unit
* Press OK and Cancel buttons simultaneously while plugging the power cord to the unit.
Wish
Jul 31, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Reset base unit of Uniden TRU9485
Uniden TRU9485 (This didn’t work for me but this was the first instruction from Uniden Tech Support)
TO RESET THE BASE UNIT:
Unplug the base unit AC adapter.
Hold down for 15 seconds the DND, * and “menu” soft key (the middle silver soft key under the LCD) while plugging the base unit AC adapter back in.
All the settings should be reset.
Uniden TRU9485 (Worked for me)
ALTERNATE WAY TO RESET THE BASE UNIT:
Hold down for 15 seconds the DELETE KEY (zero with a line through it) while plugging base unit AC adapter back in.
May 28, 2009 | Uniden Lands Phones
Resetting the imaging unit
How do you reset the imaging unit?
Dec 19, 2007 | Samsung CLP-510 Laser Printer
Brother DCP-7040 Laser Printer Logo
29 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
