Question about Canon Office Equipment & Supplies
Paper feed on my canon fc-224s doesn't feed!
Paper feed is not working properly - doesn't grip paper so only feeds if paper is gently hand pushed
  • brasec Jan 12, 2009
    Thanks to iddriss47!
  • Anonymous Mar 15, 2014
    canon ipf755 cant feed paper
  • 26 Answers
Hello.
clean the roller "which take the paper" by any clean Cloth weten with water.
Posted on Jan 12, 2009
How to fix Canon Pixma MP470 printer that does not feed paper properly to print from Windows PC
Open up the printer and see if there is a small piece of paper that is interfering with the paper path. You may have to use a flashlight to see it.
Sep 10, 2014 | Canon PIXMA MP470 All-in-One Printer
Canon LBP 5050N Printer keeps coming up with paper jam. Have turned off, then turned on. Still did not fix. Can you help?
My LBP 5050N would print one page normally then stop with the next sheet just starting to feed (i.e. just touching the first feed wheel). When I took the paper tray out, there was one sheet left behind and I could pull that out easily without it tearing. It was gripped lightly at the beginning of the feed path.
Starting the printer again gave me another copy of the already-printed sheet (I guess that's Windows getting an error message from the printer and treating it as not having printed the first sheet).
As it will always print one page properly before jamming on the next one, the problem was obviously not a small piece of paper stuck somewhere.
I cleaned the rubber wheels with Isopropyl Alcohol as best I could, but they were not obviously dirty or slick/hardened with age. The result was the same.
Then I noticed that the two blue paper grips on each side of the tray showed a small gap of 1 or 2mm. I pushed them in to tighten them gently against the paper and the problem was solved.
I've been searching in many places for an answer to the 'frequent paper jam problem' and not seen this mentioned, so thought it would be useful to have it on record here.
Yeah, I was mentally challenged - I focused on the wrong thing from the beginning.
Feb 18, 2013 | Canon LBP5050N A4 Colour Laser Printer...
Hi, we run a canon ir 2016i in our office, and frequently the paper feed doesn't work properly. Especially the paper out of tray 3 and 4 gets stuck almost all the time. But quite often the paper f
The only thing I can think of, without actually seeing it work, is the feed rollers. I've never liked the feed system on this model, seems to be very temperamental. It could also be the feed clutches. There was a modification that should have done years ago dealing with the feed system. I don't know if this applied to the extra two cassettes but the two upper paper pick-up assemblies were to be replaced. Gears were updated.
May 08, 2017 | Canon iR 2016i Black and White Copier
Paper feed wont take paper to print gets crinkled and wont print
This is sort of scenario could be caused by dust inside the printer. Dust prevents the rollers from having a firm grip on the paper while picking paper. When one roller has a firm grip and rolls the paper well while the other doesn’t, crumples result. So I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front; if you have a blower please use it as well). This, if properly done should do it. Brush especially the rollers etc.
Dec 21, 2009 | Canon Pixma MP500 All-In-One InkJet...
The paper won't feed through. it did one minute then stopped
This is sort of scenario could be caused by dust inside the printer. Dust prevents the rollers from having a firm grip on the paper while picking paper. When one roller has a firm grip and rolls the paper well while the other doesn’t, crumples result. So I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). This, if properly done should do it. Brush especially the rollers etc.
Dec 06, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper won't feed into printer
I have taken a piece of cardboard, like the ones you get with a new shirt, size it to 8.5 x 11, and tell the printer to print a test page. hand feed the cardboard thru, and most times it will clean out the residual paper pieces stuck in the internal rollers. I have used this method several times and was successful 99% of the time. It isn't rocket science, but It may work. You will probably have to push the cardboard thru, but do not force it to much. It will not go thru easily on its own. Just a suggestion.
Jun 17, 2009 | Epson Stylus CX3810 All-In-One InkJet...
Paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper jam how to remove paper when jamed in rollers
First unplug the printer from power chord.
  1. Open the upper front door.
2. Grasping the print cartridge by the hand grip, pull it towards you and slightly up to lift it out of the holder.
3. Then pull the cartridge straight out towards you.
4. Locate the feed roller release lever and gently push it back to release the pressure on the paper.
5. Pull the paper out.
Hope this helps .
Feb 22, 2009 | Lexmark X4650 InkJet Printer
Paper feed feeding multiple sheets plus noisy feed
The most likely cause of this problem is a paper feeder malfunction. Because you were not specific in the model you have, repair could be rather variable.
One plausible cause is the paper rollers have tried up. Normally when the small rubber rollers grip the paper, the friction generated by a properly moisturized feeder can grip a single sheet. If your rollers are getting dry, you can use some rubbing alcohol on a q-tip and rub it on the rollers. Make sure not to use isopropyl alcohol, that will cause the rollers to dry out even more. I've heard of people using WD-40, but I've never tried that. You would want the WD-40 to dry a while otherwise it will leave greasy residue on your nice white paper.
Another cause could be a small object (paperclip, staple, raisins) stuck in the paper feeding mechanism. Carefully inspect the feeder, comparing one side to another, and gently pushing on the movable parts to make sure they can move free. You don't want to push too hard or you could knock out a needed spring or damage the plastic gears.
Hope this helps!
Oct 16, 2008 | Canon Office Equipment & Supplies
Automatic Paper feed
Check the feeder roller inside the printer for any foreign substance stuck to the roller, this may cause it not to grip properly. You can also try a few sheets at a time and make sure the paper tray is gripping the paper, but not too hard. If this fails, the roller may be out of place somewhat, try to reposition it. Let me know how you get on.
Sep 06, 2007 | Samsung ML 1210 Laser Printer
136 people viewed this question
old marine
old marine
