Question about Linksys Wireless-g 2.4 Ghz Broadband Router Wrt54g V8
I don't have security set up on my Linksys router
S/N CDFD1F8X5026 MAC 001839E1E695
    Sergeant:
  • 486 Answers
Turn over router and check in the bottom default access IP address and then type that IP address in to your browser. Then it shall ask you for ID and password. Enter `Admin` or `admin` as ID and `Password` or `password` as password. You will see a web based setup opened in front of you. Go to the Wireless Lan settings and then you will SSID so change the SSID and this would be your network`s name. Then go to subsection security and select WPA2-PSK or simple WPA-PSK then enter your desired network key. Once done with all these things the click apply and reboot if prompted.
Posted on Nov 05, 2013
Can't get the TV/router connection made
double check the password, some are case sensitive. Also make sure you don't have mac filtering used on your router. If you do, you will have to enter the mac address of your TV before it will connect or turn off the mac filter. Also is your router set for DHCP or are your IP addresses manually assigned?
Oct 18, 2012 | JVC 55 1080p Smart Wi-Fi 3D 120Hz LED HDTV...
Password problems.
Depending on the type of router, you could have various defaults set, if you never changed them.
You can press the reset button somewhere located on the router itself, using a pen/pin/pencil, and then google your brand of router asking what the default password is.
If it is a Linksys, you could google "Linksys default password" or "Linksys default login" for example.
Dec 20, 2011 | Linksys WRT54G2 Wireless Router
I need to add a mac address to my router..so far not working
Open the setup page of the router and go to wireless tab. Click Wireless MAC filter sub tab. If wireless MAC filter is enabled then disable it. This option is always disabled by default. I think the wireless network might be the issue. If your wireless network is secured then make sure that you are entering the correct network key WEP / WPA .
Dec 01, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Ed router not secure
Follow the steps listed below and your router will be secure.
Linksys WRT54G Wireless-G Broadband Router
  1. Begin setup of your Linksys Wireless Router by first plugging in the power. Give it 10 seconds or so to initialize and then plug an ethernet cable into your wall jack and into the port on the back of the router marked Internet. Next get another ethernet cable and plug one end into your laptop and the other into one of the ports labeled 1-4 on the router. Your computer is now properly connected to the router to begin its setup and configuration.
  2. Next open a web browser window on the connected computer and type http://192.168.1.1 into the address bar and press enter. A window will pop up prompting you for a username and password to access the configuration page for your router. Enter admin for both the username and password.
  3. You should see the Setup page shown below.
    Accessing the router settings through a web browser.
  4. On this screen you should change the Router Name from its default value to something unique so that your Base Station will not be confused with another. Scroll to the bottom of the page and click Save Settings then click Continue when the Settings are successful dialog is displayed.
  5. Next, click on the Wireless tab at the top of the settings screen. Change the Wireless Network Name (SSID) from the default value to something unique (you can use the same name you set as your Router Name in the previous step. Then Disable the Wireless SSID Broadcast option and click Save Settings and then Continue when the Settings are successful dialog is displayed.
  6. Now click on the Wireless Security subsection at the top of the page. In order to password protect your wireless network first use the Security Mode dropdown box to select WEP and then from the WEP Security dropdown box select 128 bits 26 hex digits. Choose a password between 6 and 8 characters and type it into the Passphrase box. Then click Generate. Finally click Save Settings and then Continue when the Settings are successful dialog is displayed. You may also select WPA encryption, however not all network cards support this, so check your documentation first.
  7. Next click on the Wireless MAC Filter subsection at the top of the page. Then Enable the Wireless MAC Filter option and select the option to Permit only PCs listed to access the wireless network. Click on the Save Settings button at the bottom of the Filter List window and then Continue.
  8. Now click on the Edit MAC Filter List button to pop up a new window (shown below) where you will enter the MAC Address, also known as Physical Address, for each computer that you will be using to connect to your wireless network. If you don't know how to get this information follow the steps here. Once you have finished, click the Save Settings button at the bottom of the Filter List window and then Continue when the Settings are successful dialog is displayed. You may now close the Mac Address Filter List window.
    Creating a MAC Address Filter List will prevent unauthorized computers from using your connection.
  9. Finally click on the Administration tab at the top of the page. Change the default password for accessing your wireless router setup pages by typing a new one into the Router Password field and then confirming it. This should be a different password than the one you setup for WEP encryption, but should also be atleast 6 to 8 characters in length. Click the Save Settings button at the bottom of the Filter List window and then Continue when the Settings are successful dialog is displayed.
  10. If you encountered any problems during this configuration procedure, please consult the manual that was included with your router or contact the manufacturer.
  11. Your Linksys Wireless Router is now secure.
Sep 19, 2011 | Linksys Wireless-G WRT54G Router
How to create a password for the linksys router
Linksys WRT54G Setup
li {margin-bottom: 10px;} Linksys WRT54G Wireless-G Broadband Router
Sep 16, 2011 | Linksys Wireless-G WRT54G Router
Trying to set up e3000 router on iMac lion and keep getting window saying unsupported os need mac os x 10.6.1 or later. I have 10.7
Try to setup router manually.
You don't need to run the CD.
Open the setup page of the router and change the settings manually.
See How to setup Linksys E3000 router.
Aug 16, 2011 | Linksys E3000 Wireless Router
How do I secure my Linksys WRT160?
Go to the Linksys website and download the install program, but here are the highlights of what needs to be set....:
Wireless Router settings:
It is usually easiest to run the install wizard, which you can get from the manufacturers' website, usually for free, but be sure to be ready to set the items listed below:
To get access, start your browser, and put 192.168.1.1 or 192.168.0.1, or other address for your unit, into the ADDRESS bar (not search box) of your Internet Browser. Every unit has unique access login and passwords, some are admin with no password, some are admin and admin...seek access information from the website of the manufacturer of your unit. Look under support, downloads, drivers or similar sounding areas.
Things to set:
(Note: Routers are intended to be set by geeks. You have to SAVE EVERY page before you leave it, or the changes will be lost. A geek knows this (apparently). The router gives no protest...just dumps your changes. SAVE OFTEN.)
1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is typically NOT the security issue.
2. Set a recognizable system ID (descriptive name is easier to find when you need to connect wirelessly).
3. Invoke wireless security of at least WEP.
a. Assign your own access code, 10 digit home or cell #. Consider taping this information to bottom of the router. (Physical access is usually not the security issue.)
4. Check that your router is set to broadcast its' presence.
5. Change the channel of the wireless to 11, and avoid conflict with landline cordless phones. (Big issue, even the neighbors can interrupt).
There are more secure settings available, all the way down to only allowing certain MAC addresses to have access. A MAC address is a digit unique to each and every network card. Like a fingerprint. Most users do not set mac address limits.
Jul 18, 2011 | Linksys WRT160N Wireless Router
How do i change my security settings or change my password on linksys router
  1. Begin setup of your Linksys Wireless Router by first plugging in the power. Give it 10 seconds or so to initialize and then plug an ethernet cable into your wall jack and into the port on the back of the router marked Internet. Next get another ethernet cable and plug one end into your laptop and the other into one of the ports labeled 1-4 on the router. Your computer is now properly connected to the router to begin its setup and configuration.Next open a web browser window on the connected computer and type http://192.168.1.1 into the address bar and press enter. A window will pop up prompting you for a username and password to access the configuration page for your router. Enter admin for both the username and password.You should see the Setup page shown below.
    On this screen you should change the Router Name from its default value to something unique so that your Base Station will not be confused with another. Scroll to the bottom of the page and click Save Settings then click Continue when the Settings are successful dialog is displayed.Next, click on the Wireless tab at the top of the settings screen. Change the Wireless Network Name (SSID) from the default value to something unique (you can use the same name you set as your Router Name in the previous step. Then Disable the Wireless SSID Broadcast option and click Save Settings and then Continue when the Settings are successful dialog is displayed.Now click on the Wireless Security subsection at the top of the page. In order to password protect your wireless network first use the Security Mode dropdown box to select WEP and then from the WEP Security dropdown box select 128 bits 26 hex digits. Choose a password between 6 and 8 characters and type it into the Passphrase box. Then click Generate. Finally click Save Settings and then Continue when the Settings are successful dialog is displayed. You may also select WPA encryption, however not all network cards support this, so check your documentation first. Next click on the Wireless MAC Filter subsection at the top of the page. Then Enable the Wireless MAC Filter option and select the option to Permit only PCs listed to access the wireless network. Click on the Save Settings button at the bottom of the Filter List window and then Continue. Now click on the Edit MAC Filter List button to pop up a new window (shown below) where you will enter the MAC Address, also known as Physical Address, for each computer that you will be using to connect to your wireless network. If you don't know how to get this information follow the steps here. Once you have finished, click the Save Settings button at the bottom of the Filter List window and then Continue when the Settings are successful dialog is displayed. You may now close the Mac Address Filter List window.
  2. Finally click on the Administration tab at the top of the page. Change the default password for accessing your wireless router setup pages by typing a new one into the Router Password field and then confirming it. This should be a different password than the one you setup for WEP encryption, but should also be atleast 6 to 8 characters in length. Click the Save Settings button at the bottom of the Filter List window and then Continue when the Settings are successful dialog is displayed.
  3. If you encountered any problems during this configuration procedure, please consult the manual that was included with your router or contact the manufacturer.
  4. Your Linksys Wireless Router is now secure.
May 08, 2011 | Linksys Wireless-G WRT54G Router
Have a router but not software for linksys, have reset the router but don;t know how to put in new password
Welcome to fixya
No proplem you don't need a software cd to secure the router. Please follow the steps
Click the below link
http://192.168.1.1
Now it will ask for username and password
Enter username = ( blank) and password = admin
If you can't login using this credentials then you will have to reset the router
If you logged in . Then click on Wireless > Wireless security
On this screen select
Security Mode : WPA Personal
WPA Algorithm : TKIP
WPA shard Key : "enter a password here"
Group Key Renewal : set to default
Click on save settings. After that restart router .
Now your wireless network is secured and you will have to type the WPA shared key inorder to connect to router when it prompts
Thanks
Vote me If it helps
Feb 07, 2011 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-g 2.4 Ghz Broadband Router Wrt54g V8 Logo
49 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
