Flatron L1732-s monitor is stuck in power saving mode. How can i fix this?
  • 1,684 Answers
If you have a blinking power light and no picture or no power at all then the issue is not power save mode, it is a failure of the filter capacitors on the power supply board. The model monitor uses the AIP-0108 power board and when the filter capacitors go out you get the flashing power light. Here is a link to so information showing which capacitors will need to be replaced to rebuild the power supply board and get the unit back up and running.
http://www.ccl-la.com/catalog/product_info.php?products_id=246
And here is a picture of the power supply board with the capacitors circled in yellow.
Posted on Dec 06, 2012
  • 7,365 Answers
Monitor settings for windows 7
1. Start menu
2. Control panel
3. Hardware & sound
4. Power options
5. Choose which settings you want & then go to the change plan settings
6. Choose which setting you want to run your monitor
7. Then save changes
SOURCE: digital power saving mode
check your monitor power settings.
right click on your desk top then left click on 'properties' in the white box that appears.
this will bring up a 'display properties' box which should have a tab headed 'screen saver' amongst others.
select the screen saver tab.
in this tab there are 2 sections. one to select which screen saver you want to use (and what settings are applied to it), and another section which should be called 'monitor power'.
click the button here which says 'power...' to adjust your power settings.
in the next window there are 4 tabs. select the first tab (power schemes - which should be already selected by default) and you now have 4 options. leave the selected 'power scheme' in the top of the window as it is and just alter the settings for the selected power scheme.
your 4 options are: 'turn off monitor', 'turn off hard disks', 'system standby' and 'system hibernates'  i would recommend setting all of these to 'never', and don't forget to click the 'apply' button after you've done this.
i would also recommend disableing hibernation in the 'hibernate' tab (this is in the same window as the power schemes tab).
once you've adjusted your power settings, don't forget to activate one of your screen savers.  this is only important if you leave the monitor on for a long time with no changes taking place in terms of what is being displayed. if you leave a static image on for hours you will end up with permanent screen burn. (a ghost image that is always there - even when the monitor isn't switched on!).
i don't bother with screen savers personally as i find them annoying, and find it much easier to simply turn the monitor off whenever i'm not going to be using it for the next hour or more.
hope that solved your problem. apologies if it doesn't.
by the way, the tabs etc i described are what i have on my OS (windows XP pro) and may be named differently if you're using a different version of windows.  the 'power options' settings will still be accessible via 'screen saver' tab in desktop properties though.
good luck!
:o)
Posted on Oct 19, 2007
SOURCE: LG Flatron LCD Power Saving Mode
Hi, September 2008 and still problems happening with the LG screens. Mine is a Flatron W1942T.
I hit the screen as suggested (my old mum was a great believer in " if it won't work kick it", this applied to anything electrical, tele, vacuum cleaner etc.,) and guess what? my old mum was right. The screen came on.
Hope this works if it happens again. I'd turned everything off because of an electrical/thunder storm. Won't do that again.
Joan
Posted on Sep 14, 2008
pravinbhavsa
  • 348 Answers
SOURCE: Dell Monitor Power save mode activate using pc
yes right click on desktop select properties then click on screen saver then increase wait time problem will solved
Posted on Oct 29, 2008
SOURCE: monitor LG FLATRON E700SH
do any one have the moniter sittungs of LG E700SH
Posted on Jan 28, 2009
rajeish
  • 52 Answers
SOURCE: Power saving mode
Prevent the laptop/desktop monitor from going to power saving mode:
  • Click on Start | Control Panel | Power Options.
  • In the Power Option properties window, click on the Power Schemes Tab
  • Set the Turn off Monitor/ Turn off Hard Disks option when on Power (and also Battery for laptop users) to Never.
  • Now click on the Save as... button and assign a name to this power scheme... Let us call it 'Presentation' and then click on OK.
  • That's it congrats!
  • Posted on Aug 04, 2009
    Stop my lg flatron w2053tq monitor going immediately into power saving mode
    How old is your monitor? You may have some bad capacitors. At any rate, you'll have to take the monitor to a Technician for troubleshooting. Good luck.
    Feb 28, 2015 | LG Flatron W2053TQ
    Flatron W2353 monitor wont turn on
    LG W2353 dvi power saving mode
    how to fix ?
    Dec 22, 2012 | LG FLATRON W2353V 23 inch LCD Monitor
    My computer wouldn't start and it is stuck in power saving mode. its LG flatron L1753S.
    check the power cable, make sure you are using the correct video cable and input source and it may help if you try to use a different power cord that is confirmed working. if you use an adapter for it, verify that the adapter is working.
    Dec 04, 2010 | LG Flatron L1750S 17" LCD Monitor
    My flatron 1920P monitor is in power saving mode. How do I get it out of power saving mode?
    It may stuck in the standby mode because it is not seeing the signal feeding it or there is problem in the power supply, look for burnt parts, bad capacitors, etc.
    http://en.wikipedia.org/wiki/Capacitor_plague
    Please post back what you find.
    Nov 29, 2009 | LG L1920P 19" LCD Monitor
    Power saving mode on screen when I turn computer on
    if you are using dvi connector, change to vga connector
    Jun 23, 2009 | LG 22" FLATRON LCD Monitor
    Analog power saving mode?...
    I have a LG flatron wide keeps saying Analog power saving mode and than powers off how do I reset this?
    May 13, 2009 | LG 22" FLATRON LCD Monitor
    LG Flatron monitor
    Hi...there,
    In power saving mode to preventing further damaged to you monitor. You've got a busted backlight inverter that need to be replaced. Happy Holidays!
    Nov 06, 2008 | LG Flatron L1750S 17" LCD Monitor
    LG FLatron W2252TQ Not working properley in DIgital mode.
    Fixing power problems with your LG Flatron Monitor (LG1753S) ' Just ...
    blog.lopau.com/fixing-power-problems-with-your-lg-flatron-monitor-lg1753s/
    Fixing power problems with your LG Flatron Monitor (LG1753S) ... So after checking the power isproperly plugged, I shut down my pc again. .... I can start a game and then change the resolution, Popp of "energy saving mode digital" led goes ..
    Mar 21, 2017 | Computers & Internet
    My LG Flatron L1511S 15 in. Flat turned into Power Saving mode when I plug in serial cable!
    if the monitor showing powersaving mode, monitor is ok. It must be your CPU complaint.
    Jan 26, 2008 | LG Flatron L1511S 15" Flat Panel LCD...
    Computers & Internet Logo
    369 people viewed this question
    David Payne
    David Payne
