Question about Freezers
I have a 1967 Sears Coldspot chest freezer. The front seal, which should be attached between the plastic door panel liner and the steel door itself has separated. Because it is not tightly anchored together, moisture gets in through this gap when the door is in the down position and ice builds up within the door, creating an even bigger gap in the front. I don't think it's as simple as replacing the seal, because you would have to pull the inner plastic liner off anyway. Any ideas?
3 Suggested Answers
Falling Down
  • 67 Answers
SOURCE: door liner on chest freezer broke due to ice build-up
if you can't find a replacement, use a piece of flat vinyl siding that goes on houses. You can heat it and bend it as needed, or cut it and screw the pieces to a balsa wood frame for lightweight support. Glue or epoxy probably won't work as the cold temps make them brittle but external caulking may be ok to hold the pieces together. Be sure to sand all edges and corners as the cut plastic can be sharp. If you can disassemble the unit and place the door face down, you can fill the cavity with insulating foam to help stabilize it.
Posted on Nov 30, 2007
  • 212 Answers
SOURCE: alot of ice builds up at the top part of the
yes. if the door seal is not making good seal then when the unit is running it will **** air in from where the seal is failing and create frost build up. need to inspect seal and make sure its making good contact.
Posted on Jun 25, 2009
How does one clean inside of freezer which had spoiled meat?
Hello Norm;
My name is peter. I am a retired field service refrigeration technician.
Plastic liners hold odor.
1.) Scrub down the liner with vinegar and water. Place baking soda on the shelves and close the door.
2.) There are special air fresheners for freezers to prevent odor. Sears carries them for about $12.00.
Mar 22, 2015 | Freezers
Philco Freezer - replace/repair seal & plastic around top
Good day,
Unlikely you would be able to repair if the inner liner is coming apart.
A local appliance parts house may be able to supply universal gasket to fit to the machine but again, if the inner liner is bad it could prove to be fruitless.
Oddly enough, if you visit supermarkets you will see chest type freezers with no top at all.
Seems like a terrible loss, but it's not.
Cold air falls, hot air rises. When the freezer generates cold air it doesn't spill out the top. It settles into the bottom of the freezer, and stays there. Likewise, warm air rises and has no interest in going into the freezer cavity.
Bottom line. Very little loss.
If appearance doesn't matter, and you can get it close, you should be able to continue to use it.
Your choice, but I thought you would like to know the physics involved here and how it does or doesn't affect you.
Mar 28, 2010 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Ice crystals forming on inside front freezer panel
Very possible the door seal is not properly sealed. Warm inflowing air onto a cold coil will cause ice build up at the lid.
Oct 08, 2009 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Chest freezer lid repair
if your freezer has the sping etc in each of the hinges, then yes take them off. If your freezer has a torshon bar type spring, DO NOT take the hinges off, as you will not get it back together
i have always replaced liners with the door attached. The lid of the freezer is going to bow out of shape when you remove all the screws and take the old lining off, so you need to replace the lining and leave the screws loose so you can realine the door bit by bit.
it is a bastard of a job, and i wish you all the best.
May 01, 2009 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Chest freezer ices up quicker than it should
if the box has mold between the seal and liner the the seal isn't the main problem, the main problem is the liner is bad and by time you got both parts if you can it would cost more than to replace the freezer.
Larry
Nov 25, 2008 | GE 5 cu. ft. / 142 liter Chest Freezer...
Door liner on chest freezer broke due to ice build-up
Nov 27, 2007 | GE 25.1 cu. ft. / 711 liter Chest Freezer...
Sears Kenmore Deep Freezer settings
i tilt my chest kenmore deep freezer to remove water when cleaning it by the time it was connected it didnt work
Nov 10, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Freezers Logo
47 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
