How do i remove the fuser unit to replace the thermal fuse in my zerox 5818 copier
  • 3,799 Answers
Ask Xerox. They may be able to supply you with a manual or diagram. Next time you may be better asking in the printer section.
Posted on Apr 15, 2013
I need a oweners manual for a copier. zerox 5818
I went to xerox.com and found this page for the 5818 :
http://www.support.xerox.com/support/xerox-5818/support/enus.html
but I could not find the owners manual, but there are contact #'s English 1-800-821-2797
Spanish 1-800-821-7726
and email support. If you ask them, they may be able to email you the manual.
Also, there is a "Frequently asked questions" area that may address some of your concerns
Dec 04, 2012 | Computers & Internet
Fuser open message not a broken gear
the fuser unit got a thermal fuse on need to replace. it over heat and the the power do not go throgh
Dec 02, 2011 | Brother MFC-8640D Printer
Need to replace the thermistor on my Savin 9945 DPE Copier- how do I access the thermistor unit? Where would it be located on the machine?
replacement of parts of copier is done by a technician, well if you could follow this you can replace the thermistor. open the right side and the front cove, the fuser is located on top of the OPC carriage unit, push the blue level going to the right side while pulling the fuser unit. after removing the fuser unit remove its the top and bottom cover. the two thermistors is located on top near the fixing separation claw beside the two thermal fuses. Good luck!
Aug 26, 2011 | Savin Office Equipment & Supplies
My Zerox copier is making black shaded copies. How do I fix this problem
Not knowing the model number I would think, either the drum unit needs replaced or the toner.
If the pages have repeat images is would be the fuser.
Nov 10, 2010 | Xerox Office Equipment & Supplies
My copier minolta cs/pro ep 2010 does not function. when you switch it on it displays a spaner symbol and error code 05
This is a C05 error code. This means you have a fuser error. The fuser is the section that gets hot right where the paper exits the machine. Most common failure in the fuser unit is the thermal fuse. The repair requires removal and some dis-assembly of the fuser unit to replace the fuse. Also have to use a special reset procedure to clear the C05 code from the machine after repairs are made. Do you have access to a local repair shop that can repair this for you?
Mar 20, 2010 | Minolta EP4000/5000 CS/PRO Copier
Receive H 4 error code on zerox 1255 copier-nothing happens, the machine won't turn on-tried switching power of for 5 seconds nothing happened. Made sure the machine was pluged in a receptacle by its self,...
A H4 code is a problem with the fuser unit. That xerox is a Sharp copier. You may have a blown thermister or thermal fuse or a fusing lamp. You may need to repair the problem before you can clear it. I believe the code to reset it is in service mode SM 16
Mar 12, 2010 | Office Equipment & Supplies
How to reset the error code C630 for KM 1525 COPIER
this is a problem with the fuser unit. it may only be the thermistor ( thermal fuse) in the fuser unit needs replacing. Maybe could be the power source pcb. Most likely the fuser or thermistor.
Oct 06, 2009 | Office Equipment & Supplies
Sharp AR-275 Getting H2-00 Erron on power on
In AR 275 Sharp copier H2 00 is very common problem, U have to only reset the above fuser error code as fallows
press # then intrrupt then c them intrrupt then display will show simulation mode then enter 14 then press ok key
If this is not enough then press press thermostat on fuser unit by removing the unit from machine this requires tech knowledge
OR you can try by replacing thermistor of fusing unit
If by above procedure the prob is not solved then and then you replace the fusing lamp
Even though u can check the lamp by removing back cover and turn on the machine u can observe the light of fusing lamp
pl ask for any difficulty.
Sep 18, 2008 | Sharp AR-5320 Black and White Copier
E000004-0010
canon NP 6330
error 800
Nov 15, 2007 | Canon imageRUNNER 5570 Copier
CANON XEROX MODEL 6050
E002 - Fusing unit not heating up.
Replace fuser and reset code, best bet is to contact dealer.
Nov 14, 2007 | Canon NP 6050 Copier
Computers & Internet Logo
David Payne
David Payne
