Question about Intel Motherboard
No video there is no video output from the board. i tried installing an agp card and still do not get anything. any info would be appreciated
  • 837 Answers
If you have an "onboard" video and are switching to a video card you must set that in your BIOS ..
Posted on Jan 12, 2009
How to disable integrated intel extreme graphics 2 and install a geforce agp video card.
In the presence of AGP Graphics Card, the system automatically switches the video output to it. Hence, there is no need to disable Intel Graphics. Just add the AGP Card and connect the AGP Output to the monitor.
CreativeTECH
Dec 29, 2010 | HP Compaq d530 PC Desktop
Agp cards not working
ok hmmmm maybe it only except 4x agp? is it very old? maybe the slot maybe burned out? do you have enough power source to run the card? i cant think of anything else.. good luck. my agp card did the same thing when the power source burned out. some day i would get nice veiw someday a dark screen. i though restarting would help and eventually the power source burned out.
Jan 21, 2010 | Intel D865GLC Motherboard
No video output
Depending on your computer/motherboard there is either a bios setting or jumper you must disable to router video to your graphics card. It is probably still trying to output video on your integrated video card.
Hope this helps,
Bill
Oct 04, 2009 | Evga NVIDIA GeForce 9500GT,, PCI Express...
Video loss
Have you checked your BIOS settings in regards to Graphic/AGP controls? If it is NOT set on auto (which will read a AGP or PCI graphics card automatically over the on board) it will always look to the onboard card or known PCI Graphics card for the video output. Check those settings and reboot. Remember to save the bios config prior to changing anything.
You haven't brought up a blue screen error so we must assume you installed the drivers properly. The BIOS control of the AGP and graphics is most likely the problem.
Jun 03, 2009 | MSI K8N Neo2-F Motherboard
No video from the board
Check the motherboard user guide for how to reset to default factory settings. If the BIOS is set to work with the on-board only and the on-board VGA is dead the motherboard is supose to detect that and switch to AGP. If is not doing that chances are not only the on-board VGA controller is gone ... the motherboard is gone too.
Try with a PCI video card.
1.Reboot with the AGP or PCI video card installed - assuming the on-board is gone but the motherborad still OK.
2. Press DELETE key
is supose to go in BIOS settings menu.
Browse and Look for on board VGA adapter ENABLE/DISABLE setting or something similar.
(My bet ? You need a new motherboard.)
Jan 12, 2009 | Intel Motherboard
No Video Output
Do you get any picture at all?
Can you press the F1 key or DELETE key and bring up the Setup menu? Can you see it?
If you can't see the above, it sounds like someone was not grounded to the computer case when they installed the new motherboard. Static electricy is the #1 killer to all electronics. If this is the case, you will have to buy an aftermarket video card and install it to see anything.
The VGA monitor will work with any video cards on the market.
If the motherboard said that it uses an AGP video card. That is the only one it will use. Make sure the card matches the motherboard or it will not work. All video cards are marked on the outside top of the box and your motherboard is maked by the AGP slot. Make sure you get the right speed format also. 8X will only work with a 8X.
I hope this helps and I will check back later to see how you made out.
Apr 01, 2008 | Foxconn WinFast K7S741MG Motherboard for...
Motherboard problem
1)first u check by single ram, if not
2)remove the graphic card and connect moniter to onboard VGA, if done
3)refer the manual and select the jumper pins as master for AGP ,now connect to graphic card
4)if no display
5)remove the graphic card and try in on board vga
6)now you cant get display remove the bios battery and clear the cmos by using jumper pin short (refer mother board board manual ).then try with both VGA output
(NOTE:-if AGP or PCIE card present on board VGA not functoning)
all the best keep trying -i hope you get working pc by half an hour,if not call to profesional servicemens
regards
prasanna
Mar 06, 2008 | Intel Motherboard
Intel P$ 1.8 mhz on a D845HV/D845WN board
Before removing your current card swap video outputs on the PC. If currently connected to the VGA output switch to the HDMI connector AT the video card. Use the HDMI to VGA adapter that came with the video card. Check & see if the display loads Pc starts. Taking the information directly from your motherboard manual pg. 25, your AGP video can only run at, AGP supporting 1.5 V 4X AGP cards. The 9600pro runs at 8x & it is not backwards compatible. (able to run at either 8x or 4x). You could run the Sappire ATI Radeon 256MB 9550 DDR AGP 4x/8x 1.5volt card.
Here is one site: http://www.colordrives.com/sapphire-ati-radeon-9550-256mb-ddr-agp-4x-8x-video-card---retail-box.html
When you do get the video card be sure to set your bios AGP to the correct size as listed in your manual pg. 109 subsection 4.4.7
I hope this helped.
Feb 20, 2008 | Intel Motherboard
No video output - Desktop HP minitower Pavilion 6635 - cpu Intel Celerom 533Mhz
Try either a pci or AGP card. On most boards, it will recognize the card without changing anything on the board. Does the hard drive and other components power up? Just the video not working ? If so it is probably the chip on the video, if not it could be a board failure.
Nov 27, 2007 | HP (5064-6630) Motherboard
Adding a separate video card...
When you boot up the pc pressing either 'DEL' or 'F2' gets you into the bios menu. Look for something similar to 'PNP/PCI'configuration, then press enter and ensure the main graphics aperture is set to your 'AGP' port and not 'ONBOARD' or 'PCI'. I can assume you have installed the 'AGP' driver from your motherboard installation disc, and the diver for your graphics card. Lastly some AGP cards are not compatible with all boards, due to in some cases different voltage ratings.
Oct 17, 2006 | PC Chips Motherboard CPU Bundle: PCCHIPS...
Intel Motherboard Logo
21 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
