Question about Gigabyte Tablet PC S1081-CF2 10.1inch Atom N2800 2GB 64GB SSD Windows
Radom moving of mouse on Gigabyte Tablet S1081
Very strange problem! When connecting through 3G (huawei EM770) to internet the mouse will random tap and move over the screen. see movie: http://www.youtube.com/watch?v=vMEnqrq5uQQ&feature=plcp Does anybody know what would be the problem ?
My irulu v1 won't connect to my mobile data how do I connect it
If your Irulu model has 3G capability, you need to buy a 3G USB adapter/dongle and then connect to your tablet using the USB or OTG cable that came with the tablet. If your model is not 3G-enabled, you can get on the Internet only via WiFi.
Dec 17, 2014 | Tablets & eReaders
Tip
How to connect your Apple iPad to the Internet
Connecting your Apple iPad to the internet is very simple. When you use a application that requires internet capabilities your iPad will do several things.
-The iPad will attempt to connect using the last Wi-Fi network you used that is available.
-If no network you previously used is available, the iPad will show a list of networks in range. You can then tap a network and if needed, enter a password to join the network. Any network with a locked Icon will require a password. These are secure networks.
-If no networks are available or if you don't choose one, the iPad will then connect over a cellular data network.
What is the difference between a cellular and Wi-Fi network? A Wi-Fi network is generally faster, but covers less of an area. Think of your home wireless network, or a wireless network at a library. It has limited range. A cellular network is generally slower but covers a larger area. Normally, if you are connected to a cellular network you will see a 3G icon or E icon at the top of your device. Also, you normally pay to use a cellular network.
To see all the Wi-Fi networks in range: From the Home screen, choose Settings > Wi-Fi. Tap a network to join it.
-G33k
on May 17, 2011 | Apple iPad 16 GB 3G Tablet PC
I have a RCA tablet rct6272w23 and I can't connect to internet what should I do?
Hi
To connect to the Internet with a tablet, you need to have either a SIM card with mobile access (3g or 4g) or a Wifi card in the tablet and access to a Wifi Hotspot. I downloaded the manual for your tablet here:
http://www.rcatablets.com/sites/default/files/CT9272W23%20IB%20English.pdf
and looking through it the first option does not exist for you as there is no facility for a SIM card.
Therefore you need to access a Wifi hotspot - somewhere. It could be your home router, a cafe, a railway station or a multitude of places. In order to access the Internet this way you must follow this procedure:
1. Go to Settings > WIRELESS & NETWORKS > Wi-Fi, and slide the Wi-Fi switch to the ON position.
2. The device will scan Wi-Fi networks automatically and display the available names.
• If the device finds a network that you connected to previously, it will connect to it automatically.
3. Tap a network name to connect to it, and enter a password if necessary.
4. Alternatively, if your Wi-Fi router supports Wi-Fi Protected Setup, tap the WPS icon at the top of the screen, and then press the WPS button on your router.
5. If your network does not broadcast its SSID, tap the Plus icon + at the top of the screen, and enter the Network SSID (name) of the network. If necessary, enter security or other network confi guration details.
In public places you may need to pay to get the necessary access password.
Hope this clears things up for you
Nov 14, 2014 | Tablets & eReaders
Tablet instructions
You can find the instructions for how to setup your secure wireless connection in the Huawei manual. And in the little booklet that came with your Samsung you can read how to connect to Huawei.
don't forget to make a note about the name and password you gave in on the Huawei.
please don' ask me to type over these pages, because one way or the other, you have to read it. Better take the booklets.
Jul 22, 2014 | Samsung Galaxy Tab 3 Tablet 10.1" TFT 1280...
My series keeps cutting out little circle looks like it is looking for wifi and it is connected
It could be a problem with your internet connection; wireless connection is always slower than ethernet. Try moving to another part of the house (closer to your wireless router) or testing the internet speed. You can test your speed at www.speedtest.net
Mar 29, 2014 | Apple iPad 32 GB 3G Tablet PC
Huawei mediapad 7 is not charging when plugged in over a long period the battery gets hot however and the screen tends to flicker if it does come on
Hate to say this but it sounds like your battery is fried. It takes the charge but since the battery is no good it won't hold the charge.
Mar 16, 2014 | Huawei MediaPad 7 Lite 3G WIFI S7-931u IPS...
Kocaso m736 connect to mobile network
Product spec says "Support external 3G module dongle".
You need to find a compatible one, Kocaso don't do one.
Put in a SIM card, pay for a Data connection, every 30 days.
Set up the connection settings dependent on the SIM supplier.
This depends on where you live in the world.
Huawei E173 is the only one that someone has found to work on android tablet.
Mar 11, 2014 | Kocaso M730W 1.2GHz 4GB 7 Capacitive...
How do I download a picture from my iPad to Facebook as my profile picture
If there are pictures in your iPad, then you just need to select one as your facebook profile picture. If no, firstly download some from the Internet, later choose one of them as facebook profile picture. Finish!
Android 4.0 Tablet PC
Jan 13, 2012 | Apple iPad 32 GB 3G Tablet PC
Says can't connect to Internet even though connected
There may be a conflict between the wifi and 3g network.Shut off wifi to check for connection again.Then do opposite,shut off 3g to connect to wifi only.
Aug 02, 2011 | Apple iPad 32 GB 3G Tablet PC
How to connec youtube viewer?
hi jaycelcandid,
good day!just connect it to your wireless internet then you can play youtube..
This is the post:
YouTube
The YouTube app organizes videos so they're really easy to see and navigate. To watch one, you just tap it. When you're watching in landscape, the video will automatically play in full screen. And with its high-resolution display, the latest YouTube HD videos will look amazing on iPad.
http://www.reevoo.com/p/apple-ipad-wi-fi-+-3g-32gb..or read here.
mastergani
Jan 07, 2011 | Apple iPad 32 GB 3G Tablet PC
Gigabyte Tablet PC S1081-CF2 10.1inch Atom N2800 2GB 64GB SSD Windows Logo
Top Gigabyte Tablets & eReaders Experts
Are you a Gigabyte Tablet and eReader Expert? Answer questions, earn points and help others
