Question about Irons
Iron steam generator not producing steam
The steam pulse light keeps flashing
    New Friend:
It wont steam
Posted on Dec 08, 2012
geokohler
  • 304 Answers
SOURCE: tefal proline express steam generator iron needs de scaling
Make a solution of half water and half white vinegar. Fill up your iron and get it good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up the vinegar concentration but do not go higher than 2 cup to 1.
George
Posted on Jul 24, 2008
SOURCE: Hinari steam vapor iron Model HIN001
More complete answer...
If you are having steam problems then the cartridge needs changing.
I phoned them (0161 652 1211) and they do sell the cartridge for £5.99 including delivery but are out of stock for a couple of weeks. You have to send them a cheque or postal orders. Good luck.
Send Cheque for £5.99 for each cartridge with note of model etc.
Pulse Home Products Ltd.
Middleton Road
Royton
Oldham
OL2 5LN
Posted on Oct 07, 2008
SOURCE: have just bought kenwood steam generator iron but
Press the variable steam control and the power on/off button to stop the light flashing - that worked for mine!
Posted on Sep 30, 2009
SOURCE: I have a Swan S15040 steam generator iron, the
I had same issue , now , once you turn the unit on , you should see displayed 3 steam jets and the flashing standby , turn the dial on the iron to max ,press the steam button on the machine to max steam , leave for a minute or so , now press the steam button on the iron , does it make a noise ? if it does , slightly raise the whole front end of the unit ( easier if you have the iron on the worktop and not on the unit !) for a minute then try and press the steam button on the iron again . I think there is a bit of an issue about the conection between the water tank and the filter . This solved my issues and i do hope it will help you .
Posted on Oct 16, 2009
SOURCE: I have a Bosch steam generator iron B25L
yes my bosch did the same but then it started working again only to pour vast amounts of water all over the clothes
Posted on Dec 20, 2009
I bought steam generator iron, iron work but doesn’t produce steam
Mix 1:1 water and white vinegar. Fill the water reservoir with mixture and hold the iron like you would normally. Keep pushing the steam button until steam comes out.
Nov 01, 2017 | Irons
Digital settings flashing
Breville VIN170 Extreme Steam Digital Steam Generator Iron, unplug the iron from the mains , keep both the power and keep the steam release button on the iron depressed and then plug in and switch on.
Below is a link to the user manual for the Iron
http://www.breville.co.uk/downloads/dl/file/id/378/steam_generator_iron_vin170_instruction_book.pdf
Hope this helps, if you require any further assistance please contact me.
Oct 18, 2014 | Breville Vin170 Extreme Steam Digital...
Filter light flashing what do I need to do no manual available
Aug 07, 2013 | Breville Vin170 Extreme Steam Digital...
How do you test a pump on a tefal steam generater
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Jan 31, 2013 | Irons
I have an elitech steam generator. It has stopped producing steam and a blue light on the base flashes? I have never used tap water and have changed the filter but it still doesn't work.
follow the steps: God bless you
If a routine cleaning of steam vents, channels or holes does not clear the blockages, you can use a steam iron cleaner. This is a mild acid type of cleaning mixture specially prepared for such a job. No other form of fluid should be tried; it may damage seals or jointing compounds used inside the iron.Use distylled water very IMPORTANT.
God bless you
Jul 24, 2012 | Irons
MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON does not provide steam
My MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON has stop producing steam. I have changed the filter and although it heats up, it does not produce any steam.
Feb 29, 2012 | Irons
My kenwood kbs 11b is not producing steam and stand by light is flashing, what should i do?
the steam holes is plug.
If you have hard water doposit in the line try some cr7
Oct 30, 2010 | Euro-Pro Steam Generator EP8001 Iron
Have just bought kenwood steam generator iron but there are no instructions with it. the filter light is flashing what do i do
Aug 31, 2009 | Irons
Irons Logo
175 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
