Question about Zanussi Dryers
Change door to open on other side - Zanussi Dryers
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 38 Answers
Which model?
Posted on Dec 06, 2012
Need to know what components to change on a 2001 Ford focus ZX3 driver side door that will not open
The outside door handle housing breaks inside the door. It's a PIA to change but parts are available from Dornan.
Nov 03, 2017 | Ford Cars & Trucks
Blizzard lb 1ss upright freezer change door opening
Under the bottom hinge, unbolt it, remove plastic plugs on other side of door, transfer hinges over and door handle, refit the lower one in new position, put plastic plugs in old holes
Mar 12, 2013 | Freezers
Change Door
there should be two plastic covers or two screws on the oppisite side.simply unscrew the hinge from the side its on flip the door the oppiste way.remove the door mechanism that is on the frame and put the mechanism onthe oppisite side and rescrew the hinge on the oppisite side
Apr 28, 2010 | Whirlpool GEW9250 Electric Dryer
Help . Change doors from right to left opening
first remove the door from the fridge, remove the hardware connected to the fridge, on the opposite side should be rubber or plastic caps covering some bolt holes. remove caps and install top of hinge transfer everything you see on the left to the right
Oct 21, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Is it possible to change door to open other side?
yes if there are screw holes to mount hinges on the other side and the handle is removable. this is not the case on all fridges but most you can .consult with your local dealer or handbook to be sure
Oct 05, 2009 | Refrigerators
Drivers side door not working
You need to change the power door regulator on the doors , to make sure they are not defective please check the power door fuse ,if they are blown out please change them if they don't open then you need to change power door
regulator on your car...
Good luck..
Apr 26, 2009 | 1996 Toyota 4Runner
Can you change the way the door opens on the neptune washer
Yes you can reverse the door on your washer.
Open the door, remove the screw in the middle of both hinges, (carefull not to drop them inside). Lift the door straight up and "wiggle" the door hinge straight out of the slot.
On the opposite side of the opening you will find two inserts, remove them and install them into the slots you removed the door from. Now the fun part... remove the hinges from your door side.
Make sure you note how they attach, now intall them on the other side of the door,EXACTLY, the way they were first installed. Do one at at time. After you have them on the other side and you put the other screws back in the side you removed the hinge from, lift the door and slide the hinge into the bottom and top slots of the washer opening. Secure the hinge with screws removed in the beginning making sure the door is closing properly and locking.
Apr 10, 2009 | Maytag Neptune MAH6500A Front Load Washer
Door/covers open
dear sir; check it out on the side door left hand side (if you face door) have piece plastic door switch actuator isn't broken, change door !
Dec 26, 2008 | Ricoh Aficio 450 Copier
Need to change door from left hand to right hand open on kenmore HE2
I am looking for the same answer on the washer. You can definitly change the dryer. The holes are on the other side under black tape.
Nov 16, 2007 | Kenmore 43142 Front Load Washer
Dryers Logo
41 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
