Question about Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux Advantage Series Vaccum is making noise when vaccum, what may be causing that?
Having hard time to open where the roller are located to see about the problem. I unscewed but can't get the plactis to come off. Was able to pull off the black hose and cleaned in there. I t sounds like something is beating inside.
  • Theresa Brooks Dec 06, 2012
    It is up Right Vacuum Cleaner Advantage Series Electrolux. Where can the noise be coming from??
  • Les Dickinson
    Les Dickinson Dec 06, 2012
    http://www.totalvac.com/manuals/electrol...
  • Electrolux Master
  • 18,394 Answers
Here is the manual ,if you slid the bumper strip off the one thats marked number 6 the cylinder should come apart, the bumper strip holds it all together..
http://www.totalvac.com/manuals/electrolux_manual_Lux7000.pdf
Posted on Dec 06, 2012
  • 44 Answers
SOURCE: electrolux 2100 new bag placed full bag indicator appears
It appears you have a bad control valve. My suggestion is to take it to your nearest Aerus dealer and have them replace it for you. You can find them by going to aerusonline.com and use their dealer locater. It shouldn't cost much to replace. You can disable it, but I don't suggest it. It is in place to protect you motor, and assuming you bought this machine new, you are aware of how much they cost. If you can't find a dealer locally, call the closest one and they may ship you the part. If you have to do it yourself, here is how. Open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl covered strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl separates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come off relatively easily, and everything will be exposed. The control valve rests under the bag housing, since the machine is now upside down. Pull the bag housing out, and the control valve will be right there. It's circular with vacuum lines connected to it. Just pull it out and move the vacuum lines to the new one, but be sure you get them in the right position!. It won't work if you don't. I hope this helps. Good Luck!!
Posted on Jan 04, 2009
LizDahl
  • 75 Answers
SOURCE: Electrolux Advantage Series canister vacuum
There is an area on the back of the tank where you will see lines, put your thumb there and pull the top half of the tank towards yourself. That should open the machine so you can replace your after filter.
Posted on Dec 29, 2007
  • 52 Answers
SOURCE: electrolux canister vaccum 2100
The filter for your Electrolux 2100 is located on the rear top of the machine. It is covered by a plastic grill. You simply place your finger in the rear of the plastic grill, push the tab in slightly and lift the grill up to expose the filter. The filter is approximately 4" by 6". It is NOT washable. Most Vac Shops sell replacement filters in addition to them being available at the local Electrolux distributor.
Posted on Nov 14, 2008
  • 73 Answers
SOURCE: Electrolux Vacuum keeps turning off and light looks like bag with
Turn the knob on the top of the vacuum all the way to the right.I had the same problem and that fixed it.
Posted on Aug 27, 2009
SOURCE: Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Posted on Apr 17, 2010
My rain vaccum
Need more information...Are you having problem with Main unit or the power nozzle? You can also call and speak to a Rainbow Specialist.
RainVac
www.rainvac.com
800-523-0510
Oct 07, 2012 | Rainbow E series Canister Wet/Dry Vacuum
How do i replace the belt foe whirlwind vaccum
Remove 4 screws on top and top plate will lift up exposing the belt and roller. Make sure you remove hair and other debris before replacing.
Jul 15, 2010 | Eureka Whirlwind Litespeed 5740 Bagless...
Electrolux central vaccum works sporadically
The the hose, wands and power nozzle to the nearest AERUS store for repair. You have a short that needs to be fixed. They should just be able to replace the wire assemblies inside the wands, handle and power nozzle.
Jun 09, 2010 | Electrolux Central Vacuum
The rollers on the vaccum seemed to be dragging and making a clucking noise when you push forward.
Try to disassemble the rollers, or at the very least inspect, and make sure nothing is getting lodged between the housing and the rollers.
Aug 20, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
No suction on wind tunnel vaccum cleaner
Your brush might be clogged with hair. while uplugged, flip over the vacum and check to see if there is any hair or string wrapped around the brush...
Jun 03, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Uprightvac 3500SA roller is not turning
When you lower the handle on the electrolux, you will see a little button on the top of the base . This is a reset button, turn the vaccum on and push the resrt button and it should start working again.
Mar 19, 2009 | Electrolux Epic 3500 Vacuum
A noise coming from the motor when I`m ready to vaccum
if it were m i would take it back and insit on a new one.something new shouldn't have to be fixed thatd why we buy it new
Dec 31, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Hi I have an electrolux "The Boss" hand held vaccum cleaner. I cannot find the instructions and am having problems changing the belt. It is model number Z57A. Product Number 900-250-006. It...
You need top lace belt on brush roller and re[-assemble by putting plastic cover on which is retained by 2 recessed philips screws.. Prize off triangular coverat fornt.behing that you should see the belt lying loose.You need to get a blunt object to twist and push belt ovet the motor shaft. You may get it on in wrong direction and if you do,loosen off belt and twist the other way.
Jul 12, 2008 | Electrolux Vacuums
Electrolux Lux 7000 Bagged Canister Vacuum Logo
121 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
