Question about Hammering
Oil pump not working
Pump is runing but oil coming out
    Sergeant:
  • 288 Answers
Sounds like the pump is running and there may be oil either coming out or maybe no oil coming out.
Posted on Sep 11, 2013
Tip
How to fix AUDI steering oil owerflows from reservoir
Check up the hydraulic power steering pump.
See picture below for 1.6, 1.8 liters Audi (4 cyl.) engines:
If you find leaks and noise when runing, the hydraulic vane type pump is damaged. The pump inputs air inside and mix air with oil resulting foam. Therefore fluid volume inside steering instalation rises. Then pressure overflows oil from the reservoir. You need repair or replace hydraulic vane type steering pump.
on Dec 30, 2009 | Audi A4 Cars & Trucks
99 f 350 vacume pump has no power to it checked
The vaccum pump should only work when put in 4 wheel drive.If the truck is running rough the vaccum pump isnt it.Suspect fuel filter, water in fuel, bad injector harness under valve covers.That truck will run bad also if the oil hasnt been changed periodically because the ipr valve cannot work right due to dirty oil and gives icp sensor a bad signal.That truck has the 7.3L , very good engine.
Sep 06, 2014 | Cars & Trucks
Star and dyes
check the oil level ........ no oil pressure the ecu kill the pump may be the oil pump bad ........... if you press the gas pedal littlebit the engine start and keep runing and later on hapen again the idle valve is going bad
Dec 16, 2010 | 1997 Chevrolet C/K 3500
Honda Orthia 1996 GX Automatic. Car don't start. Start the car today (after a few weeks of been parked), start without problems, I leave it runing and when I come back to check it wasnt runing anymore...
check engine light? check oil level, low oil possible engine damage.is there gas in tank?guages can lie, add a gallon if not sure. when key is turned on, not all the way to start, can you hear the fuel pump, an electric motor sound? have someone listen above the tank with trunk open or listen under tank. past this, check if spark plugs are working, remove a plug, put wire back on, rest plug on metal to ground, turn motor and check for spark. please rate answer.
Jun 10, 2010 | 1996 Honda Civic
1998 VW Jetta with 2.0L 4cyl. No oil pressure or oil flow that I can see. Full on oil though, but absolutely dry in the valves. How difficult is it to replace the oil pump? Could something else be...
Did you have changed a cylinder head gasket? Possible turn around. If not need to change oil pump.It is easy.Just remove the sump but before that drain the oil because........Get new sump gasket.What about oil pressure lamp?Coming ON? If the engine runing and the lamp is ON change oil pump.
Apr 22, 2010 | 1998 Volkswagen Jetta
Robinair 15600 Vac. Pump
Check your pump oil level,It should be middle of sight glass while pump is runing & try to use origenal vacuum pump oil.
Apr 05, 2009 | Robinair 6 Cfm 2 Stage Vacuum Pump, R 12/R...
Hammering Logo
51 people viewed this question
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
