Built in dvd will not accept or eject dvds screen says no signal
Tv is less than a year old but when you try to put dvd in it does not take it or even try i.e does not make the noise. The screen shows no signal, im not sure if the two could be related but the remote control no longer work either.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Since no brand or model number is indicated try this:
Unplug set from power and if using a Box of any sort to feed signal unplug that also----let set sit for several minutes and power everything back up----this will allow set and or a box to try to reboot.
Posted on Dec 06, 2012
  • witchcraft1
    witchcraft1 Dec 06, 2012
    its quite literally a tv that is made specifically for tesco has no brand name on it. its a small 19 inch tv with built in dvd player. it was working fine but now the dvd player bit wont take the dvd it doesnt even try. i have turned of all the power to it and left it to rest but still no joy
SOURCE: 37LC7D, screen blank, cannot power off manually or w/remote
Hi, I would buy your TV
Posted on Dec 14, 2008
  • 814 Answers
SOURCE: tv screen is white; sound is ok
Need more information about you problem. Does the white screen appear on all functions.Does any input signal like a dvd or vcr show picture. If so, then you have a problem with signal connection coming from the television signal source, like a cable or satellite box. You need to check the connecting cables to see if they are outputting signal. Try using different cables to connect the signal source to the television. If this does not work. Try hooking up the signal source to another television to make sure you are receiving signal from them.If all this seems to be working fine and you are sure that you are using the remote control inputs correctly, you may have a problem the video input signal board on the television. You can contact PROSCAN at this web address. www.oncorpus.com. Go to customer support and ask for their technical assistance with your problem. The telephone number for PROSCAN service is 1-888-977-6722. I hope this has been of help with your problem.
Posted on May 21, 2009
  • 50 Answers
SOURCE: my tv will not shut off with the remote control
What type of tv was it and did you try to reprogram the remote?
Posted on Jul 10, 2009
bluenadas
  • 203 Answers
SOURCE: the dvd disc is stuck and won't eject
Bring the unit to a repair center to get the disk out. Trying yourself could ruin the unit.
If you brought it to me I wouldn't even charge you.
Posted on Sep 27, 2009
SOURCE: TV w/ built in DVD
What a crock of **** this is guys! This FIX is surly a sad work around for the poor! Replace the mother board and solve your problem the correct way. No need to butcher up this TV. Better still, buy a name brand TV and a service contract which will save you money in the long run.
Dan Jackson - CET, which means Certified Electronics Technician
Posted on Oct 06, 2010
Soniq tv with built in dvd player says no signal on dvd mode
DVD unit has gone to dvd heaven. Not cost effective to repair. See if you have inputs so you can use an external player.
Feb 20, 2012 | Televison & Video
Two questions: My Insignia NS-LTDVD 19 flat
This model/brand of LCDs does need a digital converter since they are a low end quality product, the manufacturers did not put an ASTC tuner to decode the HD signals.
The DVD assembly can be replace to fix the DVD issues.
I have a couple of these DVDs assemblies from a broken screens LCDs and they're like new condition.
Let me know if you need further assistance.
Jun 23, 2010 | Insignia NS-LTDVD19-09 LCD TV
Old tv plays dvds but when cable box is on or off image scrolls vertically on the screen. wondering if this is an issue that can be fixed or is symptomatic of a 15 yr old tv. thanks.
I'm not sure what you mean by "cable box is on or off". Do you mean connected? If the cable box is connected to the TV through a 300-ohm antenna input, you are probably getting a lot of interference from the workings of the cable box. Try moving the cable box away from the TV.
If the TV is connected to the cable box with a 75-ohm cable, it may not be properly grounded - try another cable.
Also try manually tuning the channel on which the cable signal comes in, usually 3 or 4. Try an alternate channel.
If the DVD player is built into the set, the signal is less subject to outside interference. If the DVD player connects to RCA jacks on the set, it is also less subject to interference.
Vertical hold problems can be caused by aging capacitors in the "sweep" circuits but usually one sees that as loss of vertical hold on the DVD signal, as well.
Good luck.
Jan 02, 2010 | Televison & Video
The tv works but the dvds wont play. The symbol showing the disk is trying to read appears and stays on screen but nothing ever happens. When I try to eject the disc it won't. I have to turn it off and on...
my dvd player doesn't play all types of discs, especially homemade like ones ripped from a home computer. However, i do not play many dvds, yet i have replaced the players many times. I dont think that most dvd players are built to last. Sounds like you have 1 built-in (to tv). The players are cheap now-- your better off saving the headache and replacing it- The last one i bought was $30.00 on sale-get a cheap 1 cause i think they all have a short lifespan.
Aug 31, 2009 | Disney DTD1363-CAR 13" TV/DVD
I have the tv/dvd combo- the dvds keep ejecting and won't play. I have had this problem for some time- the tv is less than 1 year old.
try while tv is playing unplug it to reset it,, if that dont work your belt or head on player bad or need lining up
Aug 12, 2009 | Insignia NS-LCD19 19 in. LCD TV
DVD input channel reads "no signal" when I try to play a DVD
First I would run a dvd cleaner in unit! Second you could take tv apart and look to see if signal cable is loose. the power wire seem fine as it powers up, and accepts an eject dvd.
Feb 28, 2009 | Proscan 32LB30QD 32 in. LCD TV
DVD player not accepting dvds
I would try getting a DVD Lens Cleaner kit from your local store.
www.walmart.com
Just pop in the cleaning dvd and let it clean.
could be as simple as dust on the lens, could be more serious but i would first try cleaning it.
I hope this helps.
Feb 19, 2009 | Televison & Video
Contact the helpline on 0871 2000 463. Maybe a faulty DVD drive. (Try a few different original disks first)
Feb 19, 2009 | Tvone TV-207 Television
DVD player won't eject
No but I'm having same problem and the dealer sugested just buying a new dvd player cause cost of repair or replacement is unbelivably high,approx 500 canadian for new dvd sleeve, the guy tells me they don't fix them they just put a whole new dvd player in from hthe manufacturer. Pretty disapointing considering how nice it is to have it built in.
Dec 24, 2006 | Hitachi 46W500 46 in. TV/DVD Combo
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
