Question about Lexmark X945E Printer
I want to get into diagnostic mode of x945e how do i do it
I want to know which buttons are go and return button
  • Official Brand Answer
  • 3,344 Answers
To enter the diagnostic menu:
1. Turn off the printer.
2. Press and hold the 3 and 6 buttons simultaneously.
3. Turn on the printer.
4. Release the buttons after 10 seconds.
Posted on Dec 06, 2012
How do I get into the diagnostic mode for the kodak 6850?
With printer off, press and hold "+" "-" and "menu" button at front panel. Then turn on your printer. keep holding the 3 buttons until you see "diagnostics" appearing on the lcd screen then let go of the buttons. you will be in diagnostic mode.
press the "menu" button once and you will see diagnostics. press "enter" button then "menu" button again until you see "check cutter"
Feb 19, 2015 | Kodak Photo Printer 6850 Thermal
520230. 31520193. 7Polaris 550 Xp eps 2009About 20 hours on unitStored indoorsI understand one code is Idle air and the other is power steering is disabled or not functioning. First I would try and...
Diagnostic Mode
The diagnostic mode is for informational purposes only. Please return your ATV to your dealer for all major repairs.
As long as the gauge is in the diagnostic mode, the wrench icon will remain lit.
To leave the diagnostic mode, turn the key switch off and on.
NOTE: Any movement of the tires will also take the machine out ofthe diagnostic mode.
To enter the diagnostics mode:
1. Turn the key switch off and wait 10 seconds.
2. Set the park brake and shift the transmission to neutral.
3. Hold the mode/reverse override button and turn the key switch on.
4. Release the switch as soon as the display is activated.
The initial screen display refers to the software version installed in
your ATV. This information is displayed briefly.
Use the mode/reverse override button to toggle through the diagnostic
screens.
Screen 1: Battery voltage
Screen 2: Tachometer
Screen 3: AWD diagnostic
This gauge indicates whether or not current is flowing through the
AWD coil (only on models with switchable AWD).
Screen 4: Gear circuit diagnostic
This screen displays the resistance value (in ohms) being read at thegear switch input of the gauge.
46 FEATURES
Instrument Cluster
Rider Information Center
Diagnostic Mode
Screen 5: Programmable service interval
The purpose of the programmable service interval is to provide the consumer and dealer with a convenient reminder for routine maintenance. When your vehicle leaves the factory, this feature is set at 50 hours. You must enable the programmable service interval before it
can be used.
Once the service interval mode is set with the hours when service is due, the hours of actual engine operation are subtracted from the set
hours until 0 is reached. When the counter reaches 0, the wrench icon will flash quickly for 5 seconds each time the vehicle is started as a reminder that the periodic maintenance is due.
To set the hours, press and hold the mode/override button until the wrench icon flashes. When it begins to flash, release the button. The setting will increase by one hour each time the button is pressed.
Pressing and holding the button will allow the numbers to escalate much faster. When the desired time increment is displayed, release the button and wait for the wrench to stop flashing. When the wrench stops blinking, your service hours are set.
NOTE: If you scroll past the intended number, hold the button down until the count turns over to 0. You can then reset the number.
If the service interval is enabled on your ATV and you wish to turn it off, toggle to the service interval mode. Press and hold the mode button for approximately 7 seconds until the word OFF appears in the
Rider Information Center.
Jun 28, 2013 | Polaris 2009 Sportsman 550 EFI XP With EPS
T632 reset count
Enter diagnostic mode:
1. Turn the printer off.
2. Press and hold the Go and Return buttons.
3. Turn the printer on.
4. Release the buttons when Performing Self Test displays on the operator panel.
Once you're in diagnostic mode, go to Printer Setup > Page Count.
To reset the maintenance page count to zero:
1. Select Reset Maintenance Count Configuration menu.
2. Pressing Select resets the maintenance page counter to zero.
Reset Maintenance Count Saved displays momentarily. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count screen.
Jan 30, 2013 | Lexmark T632 Laser Printer
Can I check how many copies I have made on my printer
Please access the Diagnostics Menu.
To enter the Diagnostic Mode:1. Turn the printer off.2. Press and hold the Go and Return buttons.3. Turn the printer on.4. Release the buttons when "Performing Self Test" displays onthe operator panel.
Once you are in the Diagnostics Mode, choose Printer Setup and then select Permanent Page Count.
Aug 01, 2012 | Lexmark Optra S 1855 Laser Printer
How to reset ink memory z2320
Here are my initial thoughts:
A. Press 'Order Ink' and continue according to manual without actually ordering ink. At the end of this process, you may have fooled your printer to think that you placed new cartridge. If this is not possible, then your ink station is not very good, they did not reset your cartridge even though it was necessary for your model.
B.
1. Turn the printer off;
2. Enter the Diagnostics Mode by holding down the GO and RETURN buttons while powering on the printer until the display reads PERFORMING SELF TEST. When ready, the display will read PRINT REGISTRATION;
3. Scroll to PRINTER SETUP and press the SELECT button;
4. Scroll to MAINTENANCE PAGE COUNT and press the SELECT button;
5. Scroll to RESET MAINTENANCE COUNT and press the SELECT button to reset the count to zero
6. Press the RETURN button to return to the Diagnostics Mode main menu, then exit Diagnostics Mode to return to normal mode.
C. Use The Printer Solution Center Option
  • Open the "Printer Solution Center" program on the computer associated with the Lexmark printer.
  • Select the "Maintenance" tab in the "Printer Solution Center."
  • Select the "Install a new printer cartridge" option.
  1. Click the "Next" buttons until the "Print the Alignment page" window appears onscreen.
  2. Select the "Print" button. If the Lexmark printer still doesn't read the refilled cartridges as having sufficient ink, repeat the process.
Resetting the Cartridge Option
  • Remove the black and color cartridges, refilled or new, from the printer.
  • Turn the printer off using the power button. Leave the printer off for about 20 seconds to allow it to power down completely.
  • Turn the printer on using the power button. The printer will go through the normal start-up process and will determine that no cartridges are installed.
  • Repeat Steps 3 and 4 five times. This process will allow the Lexmark printer to remove the usual five most recent ink cartridges from its memory and list of current ink cartridges and, as a result, accept the newly refilled ink cartridge.
You might find the following video link helpful:
May 01, 2012 | Lexmark Z2320 InkJet Printer
Reset printer lexmark
Feb 15, 2012 | Lexmark Pro205 AllInOne InkJet Printer
LA FOTOCOPIADORA XEROX 1025 COPIABA BIEN DE REPENTE ME MANDA U2
U2 = Memory failure.
moz-screenshot.jpgClear U2 error
To enter diagnostics:
  1. Power on
  2. Press 'Clear' > 'Exposure' > 'Clear' > 'Exposure' buttons within 4 seconds.
  3. All the lamps on the control panel will go out.
  4. Enter the service mode using the 1 button.
Enter code 16
Press Start button
Exit diagnostics, by switching machine off.
If the error returns, you will need to replace the main board.
Good Luck!
Dec 05, 2009 | Xerox Office Equipment & Supplies
How to reset toner drum for the oki c5510 mfp?
. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 16, 2009 | OKI C5510 MFP All-In-One Led Printer
Toshiba 42h82
1. ENTERING TO SERVICE MODE
MUTE
S
(Service mode display)
3) While pressing the MUTE button,
press MENU button on TV set.
2) Press MUTE button
again to keep pressing.
1) Press MUTE button twice
on Remote Control.
2. DISPLAYING THE ADJUSTMENT MENU
1) Press MENU button on TV.
Adjustment mode
Press
Press
Service mode
Item
S Data
3. KEY FUNCTION IN THE SERVICE MODE
The following key entry during display of adjustment menu provides special functions.
Screen adjustment mode ON/OFF: TV (ANT)/VIDEO button (on TV)
Selection of the adjustment items : Channel s/t (on TV or Remote)
Change of the data value : Volume s/t (on TV or Remote)
Adjustment menu mode ON/OFF : MENU button (on TV)
Initialization of the memory (QA02) : RECALL+Channel button on TV (s)
Initialization of the self diagnostic data: RECALL+Channel button on TV (t)
“RCUT” selection : 1 button
“GCUT” selection : 2 button
“BCUT” selection : 3 button
“SCNT” selection : 4 button
“SCOL” selection : 5 button
“TNTC” selection : 6 button
Convergence adj : 7 button
Self diagnostic display : 9 button
Oct 21, 2008 | Televison & Video
Fuser reset / transfer reset
RESET OKIDATA TONER DRUM by RTINSC (11/17/05 10:34 AM) reply + / -
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Aug 11, 2008 | OKI C5510 MFP All-In-One Led Printer
Lexmark X945E Printer Logo
190 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
