Question about LG WM2487H Front Load Washer
Lg washer wm2487hrm error code pf
When I turn on washer PF code comes on and I cannot wash, I have tried to reset it by unpluging the unit the problem presist. How can I repair the problem
SOURCE: LG WM1814CW Front load washer PF continues to come on and stops cycle
Seen This before Main control board fixed it It would go through most of the wash cycle and just quit no errors but PF
Posted on Jan 29, 2008
GodBlessU
  • 3513 Answers
SOURCE: my LG front load washer won't spin! Has code OE or
Check the door lid switch. Maybe it's not closing good. Try to stick a screwdriver in the switch.
Thanks
Posted on Oct 20, 2009
localwonder
  • 6784 Answers
SOURCE: Get error codes DE and PF. Tried to re-set
HI. Let's start with the DE code. A DE Error Code is an indication of a "Door Error". This indicates that the washing machine door is not shutting, locking or opening. I would recommend to try the troubleshooting chart That I have included, below this text. This will help isolate the issue so that it may be repaired.
Concerning the PF code; This code concerns the nature of the power stream that is fed to the unit when attached to its respective source. If this stream is interrupted or abruptly cut off for some reason, this will cause this code to appear. The DE code may have caused this false reading.
I would suggest on focusing on the main culprit; Which is the door switch assembly or wiring connections.
Posted on Dec 20, 2010
e-Guru
  • 3917 Answers
SOURCE: consistent problems with LG Tromm
Hi
The "PF" error code that appears in an LG Tromm washer has experienced a power failure. To clear the error, simply restart the washer cycle.
Also make sure the entire plug in wire connectors are making a positive grab on the main control board and also the unbalanced sensor.
Please check this official website link of LG thoroughly to get a detailed idea about the error:-
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6333
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on May 18, 2011
  • 60 Answers
SOURCE: My LG comes up with the error code PF
PF - Power Failure - PF error code indicates a power failure during the washer's cycle.
Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks
Posted on Nov 02, 2011
LG WASHER/DRYER COMBO PF Issues
pf is power failure,, need to replace main board... there should be a parts/repair manual inside unit.. usually bottom panel...
Aug 15, 2016 | LG Washing Machines
Wm3431 pf code
The PF error code indicates a power failure. This might occur while machine is working due to an external disturbance like a storm or power outage in the area. If the PF error code is displayed, turn off the power to the washer, unplug it for 10 seconds, and restart the wash cycle. If the error code continues to present after these steps have been taken, then the washer may require service.
Apr 26, 2012 | LG WM3431 Front Load Washer / Dryer
Thanks
Oct 23, 2011 | LG WM-2277HW Front Load Washer
I am getting a pf error code. the washer does nothing
Hope helps.
Sep 15, 2011 | Washing Machines
My maytage neptune washer is flashing PF what does that mean?
Hi
Error code PF means power failure. This happens when there is a power surge or the washer is unplugged manually. To reset this error you'll need to turn off the washer and unplug it for 10 minutes. Restart the washer and check, If the error still appears then pressing the Spin Speed key will begin the Board Output Test. This test turns ‘ON’ a specified output after a key press. Pressing the Spin Speed key again cancels the test. Please post back for further assistance if required.
Daniel
Aug 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
PF CODE COMES UP WHAT IS LIKELY PROBLE
Found the below at http://lgknowledgebase.com
hope this helps,
best of luck, have fun,
thanks,
chuck
Feb 25, 2010 | LG WM1814CW Front Load Washer
Pf error
Pf is power failure code you must push clear or reset washer by unplugging and plugging back in Good luck
Mar 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
No power
No error code like PF Some times unplug for 2 hours.to 6hours for it to reset.
Jan 13, 2009 | LG WM-2277HW Front Load Washer
Error code PF
PF means Power Failure!
Unplug both units for 10 minutes, then plug them back in and try operating them. You may need an electrician to investigate why you are losing power to both units
Jun 04, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Jan 29, 2008 | LG WM1814CW Front Load Washer
LG WM2487H Front Load Washer Logo
100 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
