Question about Hotpoint WM56 Front Load Washer
Is the washer a cold or hot water fill?
The water supply I have to the washer is a cold water line only. At present I have a y piece connection to supply to both hot and cold water inlets. Are they both required or can I cap one and supply cold only to the cold input?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 38 Answers
I think only cold water is enough. The washer machine will warm up the water.
Posted on Dec 06, 2012
  • 6 Answers
SOURCE: Recently purchased a seccond hand
no it does not
Posted on Aug 30, 2008
barkencoa
  • 3463 Answers
SOURCE: I have a hotpoint aquarius
Most washers made today, are cold fill only, best way to check is look at rear of washer, and if there is only one hose, then it is cold fill only, if 2 hoses, then hot and cold fill..
So if your boiler is not working, then it should be o/k to use if cold fill only.
Plz rate my solution.
Thanks.
Posted on Jan 25, 2009
  • 86 Answers
SOURCE: relocation of hotpoint aquarius 1000 washing machine
You don't need hot and cold connected to your machine you can use just cold, but you DO need a supply of some kind to both valves, or your machine will stop when it comes to the rinse cycle and it won't distribute fabric conditioner. Ask for a cold fill adaptor from any plumbers merchants. It looks like a plastic Y the single stem connects onto your cold supply tap and the two hoses from the machine connect onto the top of the Y. The machine will take longer to do a wash but it will work perfectly.
Posted on Jun 21, 2009
barkencoa
  • 3463 Answers
SOURCE: hot point aquarius 1100
All Hotpoint washers have heater element regardless of whether they are cold fill only, or hot and cold fill.
if 2 connections at rear, then it is hot and cold fill, if only 1 connection, then it is cold fill only.
Please rate my solution.
Thanks.
Posted on Jul 24, 2009
marka19
  • 1430 Answers
SOURCE: Hi I have a hotpoint
First check the screens in the end of the hose and inside the water inlet valve. If clear you need to remove the top and check to see if you have power to the water inlet valve, there will be a solenoid for hot and one for cold. Check for power on the cold solenoid when washer is put into a fill cycle. If you have power replace the water inlet valve. The whole valve must be replaced. They are inexpensive and easy to replace. Here is a link that should help http://appliancehelponline.com/washerwaterinlet.html
Posted on Sep 16, 2010
Washer fills with hot water on cold wash or rinse. Turned off the hot water supply during cold cycle and machine stopped filling. Checked that the hoses were connected to right inlet valve and they are.
typically hot is on the left and cold is on the right at the house faucets but in some cases they are reversed so if filling with a cold setting and the right side supply is hot the plumber reversed the lines when the house was built which while its semi rare has been seen numberous times
Sep 26, 2011 | Whirlpool GHW9250M Front Load Washer
Where is the filter located and how often do you have to clean it?
Most washers have screen filters where the hot and cold water lines connect. The condition of your water supply would indicate how often you clean these screens. If you notice a decrease in water flow into the tub you should clean the screens.
Shut off the hot and cold water supply lines.
Drain the pressure from the lines by turning the timer dial through the fill cycle in both hot and cold water modes.
Remove the hot and cold water lines from the back of the washer.
Look for a screen inside the hose coupling or the washer inlet.
Remove screen and clean using a wire brush. If screen is damaged get a replacement at a hardware, or home improvement store.
Jul 20, 2011 | Washing Machines
Which is hot & cold inlet connection
If you want to connect up a washing machine that uses hot and cold water but you only have a cold water supply (such as in a basement or garage) you can use a Y Piece connector to connect the hot and cold fill hoses to a single cold water supply (external link to 4Washerhelp spares).
The washing machine will then work OK. Simply screw the Y-Piece onto the tap, and then screw the hot and cold fill hoses to the Y-piece and connect the other end of the fill hoses to the washing machine. (You may also be able to buy this part from a DIY store like B&Q)
If you don't connect a water supply to the hot valve (and simply connect the cold water hose to the cold valve leaving the hot valve with nothing connected to it) then some wash programs may not work as some programmes only fill with hot water. However, some washing machines will work OK with only the cold fill hose connected. You can always try it and see. The worse that will happen is the washer could either stick on the odd wash programme or may abort on some. If you do this though it's possible for water to drip out of the hot valve on some machines during fill. It's best to use a y-piece if possible.
The fact that you have connected cold water to the hot valve is irrelevant, the washing machine will not know any different and will just heat the water up to the correct temperature. The washing machine may use slightly more electricity but if it's less than 10 years old it shouldn't be significant unless you use a lot of 60 or 90 degree washes. On 40 degree washes, manufacturers argue it's more efficient to fill with cold water only and slowly heat up the water to 40 degrees.
Apr 30, 2011 | Washing Machines
Hi. I've just been loaned a Whirlpool awm 5125/4 washing machine (while mines gone for repair), but it has on the back of the machine, a hot inlet and a cold inlet. My machine only requires a cold water...
Your machine can be connected for cold fill only but, you will need to connect a "Y-Piece" for it to work:
The tail of the "Y" attaches to the cold water valve on your pipework. You then attach both hot and cold water hoses to the branches of the "Y" and connect both hot and cold water hoses to your washing machine. The wash cycles will take longer when connected this way as the machine has to heat the water internally. It will also be less energy effecient.
Please post back if you need further assistance.
Regards,
BElectric
Dec 11, 2010 | Whirlpool AWM5125/1 Front Load Washer
On a quatro 1400 can I just use the cold fill only
If there are 2 inlet valves at the rear of the washer, it is meant to be connected to hot and cold supply.
However, if you just wish to cold fill only, then you can fit a Y piece to the cold supply tap, and connect both hoses to this, and then to the washer.
Then whatever prog you select, it will fill with cold water.
You can get a Y piece from B&Q or some place like that.
Thankyou.
Feb 03, 2010 | Hoover Washing Machines
Can wjs1265w be connected to hot and cold water supply using Y connector - or must it be cold fill ONLY?
If there is only 1 inlet connector at rear of washer, then you must connect to the cold supply.
All current washers and washer dryers are cold fill only now.
If it has 2 connectors, then you must still connect to cold using a Y piece to make the final connection to washer.
Hope this helps.
Thankyou.
Jan 26, 2010 | Zanussi WJS1265W Front Load Washer/Dryer
The cold water does not run it trickles, hot water runs very fast
If both solenoid coils check the same, you probably have a clogged supply hose. Check that the filter screens inside the hose (if present) and the fill valve inlet are clear of mineral buildup. Try switching the hot and cold supply lines to see if the trouble moves from cold to hot. If the cold still only trickles in, replace the fill valve.
Jan 25, 2009 | Kenmore 22422 Top Load Washer
I have only bcold water feed but washer has hot/cold do i need 2
If it is a hot and cold fill m/c, what you need is a fitting that is referred to as a" Y" piece..To fit it, connect the straight leg of the "Y" piece to the cold supply tap, and then fit a hose to each of the two outlets, connecting each of these to the 2 inlets on the valve to the washer..
It will then fill with water, regardless of the programme you select.
You can purchase the "Y" piece connector from most hardware shops, or B&Q, and the like.
Thanks.
Jan 12, 2009 | Hotpoint WMA35 Front Load Washer
Kenmore oasis long fill
Check your hot and cold water supply hoses for residue buildup that restricts the flow of water.....there is a small metal screen filter that clogs up ....most likely the cause if your pipes are old and the inside walls are shedding deposits into the water line.
Jul 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Hotpoint WM56 Front Load Washer Logo
59 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
