Question about RCA D56W20 56" Rear Projection Television
Won't turn on
Rca d56w20 56 in. rear projection tvWe just bought this tv from a friend. They delivered it and after a couple hours we plugged it in and it never came on. All we have ever gotten was a green flashing light or nothing. At first it would flash in a series of 3 blinks. then after awhile we tried again and it was 9 blinks. And now we try it and the green light comes on maybe 30secs and then shuts off.
  • nickib71 Jan 12, 2009
    My husband and son seen it work. The person we are buying it from brought it over to us. It hasn't worked since it got here. I don't have any idea what it would be. If someone knows could you please share the info with me. So I know what to do. Thank you
  • chucky1963 Jan 14, 2009
    It works very well when it wont to.I got from dad it worked great. until got it home !!!!. Now it turns it self off, if i let it sit for about 5 min. OK but not always help
    Genius:
  • 2,920 Answers
Id be calling the friend asking for a refund...what you have going on is pretty common but did you see it work prior to buying it or just take their word for it? you may have a bad flyback or transformer but it shouldnt be bad so soon after you happened to buy the tv and no it would not have gone bad from moving the tv
Posted on Jan 12, 2009
  • Ronnie Houston Jan 13, 2009
    it sounds like the transformer may be bad on it.as i stated id take it back to the friend and ask them for the money back since the tv isnt working as its supposed to.if the transformer is bad it wont allow the set to turn on at all other than flashing lights on the front. thats about all i can tell you other than to have a service man come out and fix it for you
Tv won't turn on. It turned off after a few minutes and won't turn back on. We opened it up and replaced the fuse.Didn't change anything. A friend said that it just seems to not be getting any...
does the power light flash three times slowly then stay off? If so chances are its just the CP150, cp120 and CP114 capacitors. There is the RCA repair kit by that same name available from www.tvrepairworld.com which has the capacitors and the CD with repair instructions
Oct 25, 2011 | RCA HD52W56 52" Rear Projection HDTV
RCA 52" rear projection tv
rscimeca,
This could literally be anything. I have a tip at http://www.fixya.com/support/r6396176-projection_tv_troubleshooting which will help you isolate the problem and tells you where to get the parts.
Thanks for using FixYa and for the great rating.
hardrocko
May 23, 2011 | RCA P52920BL 52" Rear Projection...
What kind of heat issue would my 56 inch projection tv have if after a couple hours shut off and on then then turns off . fuse, power supply . not sure
Sounds like it's possibly your convergence IC's overheating. On some projection tv's, after time, the solder joints on the IC's weaken from the heat and cause them to turn off the tv for it's own protection.
May 08, 2011 | RCA D56W20 56" Rear Projection Television
Will not power on and stay on
Problem is with the IC.Picture tube is OK.
Jul 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
We have rca tv model 52950 need year made
I have the same television and bought it brand new late 2001 and was delivered to my home January of 2002.
May 26, 2009 | RCA P52960 52" Rear Projection Television
Problem with RCA P52960
unplug tv from wall then turn back on
Aug 14, 2008 | RCA P52960 52" Rear Projection Television
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Rca projection tv model # p52753at
it has circuit broken .short call tech.
May 05, 2008 | RCA HD52W56 52" Rear Projection HDTV
What is this?
Likely to have a bad high voltage transformer: white square thing with large red wire coming out and possible horizontal output transistor maybe C5148: on metal heat sink behind transformer. Must use original transformer Average cost $300.00 according to which repairman. Be sure picture was good before it went out!
Nov 01, 2007 | RCA P46924 46" Rear Projection Television
Please help
If its a rear projection TV. It sounds like the Lamp is shot on the projector, or is going. Look in the back and see if it is lit if it is flickering I would definitely suggest replacing it. If that doesnt repair it then I would ultimately suggest the optical engine which is the projector of the TV
Jan 30, 2007 | Mitsubishi VS-5075 50" Rear Projection...
RCA D56W20 56" Rear Projection Television Logo
163 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
