Question about Hoover U5491-900 Bagged Upright Vacuum
U5491-900 hoover bagged upright,Anniversay Model
Anniversary model. Unit has a slider switch on the handle.Move switch very slowly unit comes on for1/10 second. Seems like actual switch located remotely. Where is switch, which pieces need to be removed to get to switch, is it the switch or the connection between the actual switch and the slider switch located on the hanndle?? Any place on internet to see exploded view of this model?? Thanks, Lee
    New Friend:
  • 110 Answers
Hoover U5491 900
Give this a try.
Posted on Nov 28, 2017
reddevil6
  • 1673 Answers
SOURCE: hoover z700 removable basket
On page 11 of your manual it talsk about the pre-filter which I think is the one you are talking about, it isn't to come out, so either is pressed in or glued. But if this is less then 1 year old it is under warranty. If it is then take it in and have it repaired,
http://www.hoover.com/pdfs/manuals/U9145900.pdf
Posted on Jan 30, 2008
  • 4 Answers
SOURCE: How do you remove the Handle from the Hoover Windtunnel Deluxe to replace the switch?
Removing the handle assembly should be easy after removal of the two screws. It may be binding or hanging up on the self-propel cable...or the plastic may just be stuck/binding. Note that the handle slides in and out of the vacuum unit along the same axis as the two screws (i.e. slides straight off the back towards you when you are standing behind the vacuum). Try to pry it off gently w/thin-bladed screwdriver or butter knife (careful now!). Not sure about the smoking issue but you may have a severely plugged filter and the unit is overheating as a result. Check that out immediately/first to avoid fire or expensive motor burnout.
Posted on Jan 02, 2009
SOURCE: replace on/off switch on hoover vacuum
My wife picked one up on the side of the road that someone had tossed. The power switch would not turn off. I took the two bolts out of the top part of the handle, and then removed the screws along the back. This will remove the required panels to access the On/Off switch. Once I found the actual on/off button, I found it to be frozen in the "ON" position. After manipulating it for a few minutes, I got the switch to work. This machine now operates great, and I now have a Hoover :)
Posted on Jan 03, 2009
SOURCE: hoover s3765 windtunnel power head does not run
I have the exact same problem as you have. Have you found a solution since you posted on Mar. 18, 2009? Thank you.
Posted on Oct 20, 2009
VacuumRepair
  • 438 Answers
SOURCE: hoover self propelled bagged windtunnel upright
Greetings from GoVacuum,
Here's a great video repair tutorial that we've put together to try and help you with the repair on your Hoover WindTunnel. I hope that this helps you with your repair. If you found this solution helpful, please rate this repair video by clicking on the 4 Thumbs Up Icons in the top right hand corner of my repair solution. Feel free to email me at chris.jones@govacuum.com if you have any questions about the repair!
Video Repair of Hoover Windtunnel Belt Change;
Thank you very much,
Chris Jones
GoVacuum.com
Posted on Mar 19, 2010
Hoover Windtunnel model U5491900air isblowing out of side filter no air coming into bag
The bag chamber is not sealing properly. Turn on the unit again, block up the hose with one hand and feel around the bag door to determine where the suction loss is coming from. It could be near the bottom of the door where one of the tabs have not been inserted properly. Good luck!
Jan 25, 2012 | Hoover Elite U5061-900 Bagged Upright...
I have a Hoover windtunnel, model U5470900. The on-off switch is broken. How do I order the parts and what is the instructions for replacing the switch?
I think this is a common problem, as the actual switch is located behind the cleaning tools caddy. The switch is toggled via a long, plastic rod connected to the thumb slider on the handle. It's a comically poor design. I'm not sure, but I think you'd have to replace the entire handle assembly if the slider no longer works. An easier solution is to simply plug the vacuum into a surge protector with an on/off switch.
Feb 13, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
Tuned off and won't turn on again
This is a great product. Do not pitch. I've own this same unit for years. Take off the handle. There are four screww located half way down the hanlde. Once the handle is off, you will see the red swtich button. Flip the swtich on/off with handle off and unit plugged. The unit should come on. Put the handle back on and it should operate fine. If it doen't you mjay need a new switch
May 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover windtunnel vaccum U6445-900 motor not turning on. I removed the screws and located the contacts inside. There is an on-off switch which seems to be stuck Is there a way to replace this switch
There are a number of Hoover vacuums that are subject to a recall due to an overheating on/off switch. Check out this web site to see if your is included. You'll need the model number and serial number from the back of the unit. The manufacturer will direct you to an authorized repair center for a free replacement of the defective switch.
http://www.cpsc.gov/cpscpub/prerel/prhtml05/05156.html
May 03, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Brush roller on Hoover upright stops turning
There should be a belt tensioner for the V belt, maybe it is not contacting the belt when you tilt the handle back. If this is less then 1 year old, then it is under warranty, take it in to a warranty servicer for warranty repair.
Dec 13, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Wind Tunnel 2 won't stay on
Possible that the switch is bad, part #40309033, take the handle off, then the tool compartment, then you can get to the switch, almost bet that one of the contacts is bad.
Feb 20, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
My hoover 2000w keeps stopping. There is no blockage. Please explain.
reddevil6 is correct. This model number is a no-show. It would help to know if this is a canister or an upright, bagged or bagless. Canister models start with the letter "S" and uprights with the letter "U". You will usually find the model number on a silver sticker on the bottom of the unit, or in the case of some uprights, on the lower back of the handle.
Jan 15, 2008 | Vacuums
How to remove handle from Hoover 5445-900 upright wind tunnel vacuum
Hoover.com doesn't have a manual specific to your model but there is one similar which will show how to remove the upper handle from the body.
http://www.hoover.com/pdfs/manuals/U5467900.pdf
Do you have a replacement switch? If not I believe you can buy one from Hoover (the switch and/or the upper handle assembly). Unfortunately your model isn't listed on the website, is this a new vacuum? I recommend giving them a call, that would be the easiest way.
Also remember when working with electronics to unplug the vacuum. Even when there is no power residual electricity can remain in the wires. If you feel unsure, take it to a repairman.
Hope this helps!
Dec 22, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Carpet Height Adjusment
In addition to the tab that contacts the bottom of the slider, there are 2 protusions on the adjustable wheel plate that move through holes in the housing, but only when the handle is tilted to begin vacuuming. The wheel plate has a spring that forces the tab against the slider. As the handle is moved to the upright position, the protusions move back through the holes, taking the tab away from the slider and the wheel plate locks in its highest position. Therefore, the position of the slider has no effect while the handle is upright and locked. Hope this helps.
Aug 19, 2007 | Hoover U5753-900 WindTunnel Bagless...
Hoover U5491-900 Bagged Upright Vacuum Logo
55 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
