Question about Dell E771MM 17" CRT Monitor
My Dell monitor gives sharp noise when started without connecting to the CPU.When system has started it works fine.Can I know how to solve it please ?
  • 404 Answers
Hi!
I used to have a monitor similar to yours, from the noise you are describing is it like a crack? or an high voltage electrical spark/arc? (Mini lightening flash sound).
The Monitor I had De-gaussed each time it was switched on this is a weird thing that lines up the colour guns. If done whilst in use it gives the brief appearance of a shimmy/shake to the screen.
Have you a menu bar on or near the power on/ off switch? if you do try looking for De-gausse it may inadvertently become switched on to auto. You can De-gausse manually.
I do hope this helps.
Paul 'W'
Onyer~EDson(:0)~[><U.K.
Posted on Jan 12, 2009
No input signal on monitor-not connected to tv-computer works fine except for the no input signal
no input or signal means that the monitor is not receiving any signal from the CPU and if the power light is amber then and the cpu works fine then there could be a problem with the cable connecting the CPU and the monitor ...check the cable.
Mar 03, 2014 | Dell Computers & Internet
What makes 511-cpu fan not detected and 512-chassis not detected
Are you seeing this error on a system you built or a pre-built system? If it is a pre-built system, check that the fans are running. Next check where the fans are plugged in, the CPU fan must be connected to the CPU fan connector on your motherboard. The chassis (rear case fan) only needs to be connected to the motherboard if you want the monitoring/PWM (modulated fan speed) option. If your CPU fan is powered directly from the power supply, change this.
If this is a system you built or recently updated the case, check your fan power connections, as above. Next check the fan speed. My ASUS board will give the "CPU fan not detected" error if the CPU fan speed is too slow. A different CPU fan will solve the problem. (I got my fan with the CPU; it works fine.)
I hope this helps. Please add a comment with more information about your system for more assistance.
May 12, 2013 | Computers & Internet
My dell precision 470 beeps loud for 10 seconds when i turn it on and it has no signal to any monitor any ideas?
Please refer to the beep error codes for your work station here: http://support.dell.com/support/edocs/systems/ws670/en/ug_en/advtrbl.htm#wp1058075
Usually a 10 second beep is an issue with RAM not detected/installed or an issue with CPU
May 27, 2012 | Dell Precision 470 PC Desktop
I have dell optiplex 755 desktop with lcd monitor.everything is all right but monitor starts for 2 seconds and then turns off help me to solve this problen
If is possible we need to establish if the monitor is defective or not. Please connect to a different monitor/LCD TVscreen or just unplug the monitors data cable from the back of the computer powered it up and check if is giving you a message on the screen as "No signal detected". It will tell you that the monitor is fine and is a problem with your Dell computer.
Jun 29, 2011 | Dell Optiplex 755 Desktop Desktop Computer...
I just bought Logitech Clearchat Premium PC, how do I get it to work?
Assemble it: connect the data cable from the monitor to the CPU, Connect the mouse and keyboard to the CPU, connect the power cables for the CPU and for the monitor, press the CPU power button, and the monitor power button. If the computer doesn't work, then it came without an operating system.Get the operating system disk and insert it into the DVD or CD ROM/RW drive. Turn the computer off, and turn it on again. Check the monitor carefully and when it prompts for pressing any key to boot from the cd, do so very fast. The process of operating system installation will start. Follow the procedures and instructions it gives you till the end. If you are not sure of any step, ask or consult any person who can assist.
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Apr 12, 2011 | Computers & Internet
Inspiron 1300 PC Notebook: I can not start my Dell Inspiron 1300 , when i plu...
adapter should be fine..if light comes on adapter should be good...leave battery out of the system...just use adapter and when starting system up tap f12...see if u can see this menu..if not try a external monitor to see if u can get a image..if so run the diagnostic..if still no image or no external monitor it may be a mb
May 06, 2010 | Dell Inspiron 1300 Notebook
My computer cant turn on and its making noises
Did you your CPU Fan inside, that's the one who make some noises inside.
If your computer is failing to start then check CPU inside, all the peripherals double check on it. From VGA Card, Memory and other devices, maybe its not properly connected inside. Good luck!
Jul 29, 2009 | HP Pavilion a1120n (PX759AA) PC Desktop
No Display on IBM G42 CRT Monitor's screen
if u change monitor . you came to know fault of monitor or cpu., if monitor works cpu is not woking properly..some itime we face same problem to creat by changining highgraphic. we can reduce graohic by using f8. re instiling xp we can solve that type of some problem.
Jun 15, 2009 | HP LP2065 (Silver) 20.1 inch LCD Monitor
Monitor on but not working properly
If you just built the computer..the motherboard will give you a warning that some hardware has changed. you have to connect your keyboard and go into the bios and make sure everything is right. To be safe select set to default factory settings , save and reboot the computer. This is to prevent the settings for a previous cpu be used for the new one.
Feb 24, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell E771MM 17" CRT Monitor Logo
115 people viewed this question
Alun Cox
