Question about Apple 17 in Powerbook with SuperDrive 1.67 GHz (APPM9689LLA) PC Notebook
Powerbk g4 1.67 lo-res. Harsh sound on startup.
Should I worry that my second-hand p/b G4 kind of coughs in a crackly way when it starts up? My previous machines have never made a sound like this, which is a bit like a badly-connected speaker.
Many thanks.
chris
  • pepeflamenco Jan 20, 2009
    Crackling noise (like speakers) coming from the lid of my Macbook Pro during the start-up!
    When I alter the angle of the screen of the laptop the noise disappears.
    But next time round when I start the computer the noise appears.
    This crackle disappears always once the computer enters the 'log-in' process.
I was exposed to whooping cough from March 7 thru March 28. I have had a harsh cough since March 27 with other cold symptoms for 4 or 5 days previous. Am I still contagious?
Have you seen a doctor? If you have and it was nothing more than a cold, you're probably not contagious anymore. If you haven't seen a doctor and think it was only a cold but the cough won't go away, I would advise you to see a doctor.
Apr 01, 2017 | Exposed Health & Beauty
Startup chime on my mac powerbook g4 stopped working. please help !
The parameter ram reset will reset that and other basics back to factory without losing any data. To do this, take a moment and find the command, option, p and r keys and figure out how you are going to hold them ALL down at together. The mac should be off, if not, shut it down (not restart-shutdown). Now, touch the power button and immediately hold down the cmd-option-p-r keys. Hold them for the screen to cycle black to gray THREE times (each taking about 15 seconds), then let go and let the mac complete the boot cycle. On the second cycle, you should have already heard the "chime" appear. That's it! Good Luck.
Dec 12, 2014 | Apple Powerbook G4 15" 1.5GHz SuperDrive...
How do iget the bloody door open tp insert disc
Mac OS 9.2
  • Press the Eject key on Apple Pro Keyboard
  • To open the second optical drive on a Power Mac G4 (Mirrored Drive Doors) computer, press Option-Eject on the Apple Pro Keyboard.
  • Open the Eject application found in the Eject Extras folder. The Eject Extras folder is located in the Apple Extras folder on the CD.
  • Click the iTunes eject button (see Figure 1).
  • Hold down the mouse button when you hear the startup sound as the computer restarts.
  • Start up from Mac OS X and customize the toolbar with an eject button.
Mac OS X
  • In the Finder, Choose View > Customize Toolbar. In the window that appears, drag the Eject button to the toolbar, then click Done. Select the disc you want to eject in the Finder window, then click the Eject button in the toolbar.
  • Press the Eject key on the Apple Pro Keyboard.
  • If you have a keyboard without an eject key, press F12 (under Mac OS X 10.1 and later). Note: You must press the F12 key longer to prevent the tray from accidentally opening.
  • Click the eject button in iTunes (illustrated in Figure 1).
  • Start up from Mac OS 9.2 and follow the options in the section above.
Aug 18, 2010 | Apple eMac G4 Desktop
I have a 2001 shadow and no manuel I'am not sure witch way to turn the valve ,,,on,off,or res.
I am surprised it has a valve. most bike after 1995 don't. But Honda's are all the same depending on whether or not your is up or down the center position is off. so either pointing up or down. (center if you will) then to the right of center or clockwise should be on and the other is Res. when in doubt between on and res just pick one and go for a drive with a jerry can of gas and a low tank.Go till it coughs and then switch to the other. it will either continue to cough or run fine after about ten seconds. hope this helps
Dec 28, 2009 | 2004 Honda VTX 1300 Retro
Startup switch on PB G4 17 not getting apple sound, takes numerous times to boot up. Using Tiger OS, upgraded to latest. Works fine, otherwise.
If a Mac is shut down while the volume is set to zero, the standard Apple startup chime will not sound, so it is impossible to say whether or not this symptom indicates a problem.
For a startup issue such as this, I would recommend zapping the PRAM and resetting Open Firmware.
To zap the PRAM, start with a powered-down machine, press the power button, then immediately hold down the four keys: command, option, P, R. After ten seconds or so, you should hear the optical drive reset, and then the startup chime (because the volume is reset to full by this procedure). Ten more seconds, another reset, another chime. After the second time you hear the chime, release the keys.
Shut the machine down again (if it doesn't start up successfully, hold the power button until the power goes off). Press the power button, then immediately hold down the four keys command, option, O, F. You will see some tech-speak on the screen, then it will wait for input. Enter the following three lines, pressing the "return" key at the end of each:
reset-nvram set-defaults reset-all
After the last line, your Mac will reboot itself. It should now boot much more reliably. If it doesn't, chances increase that you have a hardware problem. You may want to run the Apple Hardware Test from the DVDs that came with the PowerBook to check your memory and logic board. Failing this, you are in for a trip to the shop.
Oct 05, 2009 | Apple PowerBook G4 Mac Notebook
Mac not loading
Try resetting your pram:
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Aug 28, 2009 | Apple eMac G4 Desktop
Smoke out of tailpipe on startup
ask a question. White, blue, black? its most likely steam on this new of a car. nothing to worry about. if blue, its burning oil, blue on start up is leaky valve seals, black on startup is leaky injectors, real white smoke (tons will come out) not steam, is blown head gasket or cracked head/block
Jul 14, 2009 | 2002 Toyota Camry
When i stert my g4 imac,s screen was became blue
You need to reset your pram
Jul 01, 2009 | Apple iMac All-in-one - 3.06GHz Intel Core...
Powerbook G4 Laptop not starting :-(
sotware is awry 1. put in your system disk and restart holding the c key 2. when the screen shows hit continue 3. go to utilities in the header menu 4. select disk utilty 5. select repair permissions 6. select repair disk after the permission repair is complete 7. quit utility go to start up disk  select your hard drive and restart good luck
Apr 01, 2009 | Apple PowerBook G4 Mac Notebook
Apple 17 in Powerbook with SuperDrive 1.67 GHz (APPM9689LLA) PC Notebook Logo
77 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
