Question about Roketa 150cc four Wheeler
I have a roketa 150.no power to starter switch,brake lights work.battery charged.reverse light not working?.help
Checked fuse.lights work,tried newstarter switch,starts if i cross starter switch
2008 Ford ranger Won't start or crank at key switch. Any suggestions?
Make sure battery has a full charge and battery connections all good. The diagram is for starter motor. Not only check the fuses, use a test light and check voltage on fuse circuits. You have a starter relay, You could, for testing, unplug the relay, use proper jumper wire on load side of relay, the load side is terminal 87 and 30. It should crank the engine. If you try that make sure tranny is in park or neutral and parking brake is set.
Your security system says, starter motor disable. By using the jumper, your bypassing that for testing. I don't know what testing you've done?
Mar 04, 2018 | Ford Ranger Cars & Trucks
Truck wont start
Starter fluid won't work if the starter won't turn the engine over.
Get the battery load tested...it may not have enough juice to start the truck but have enough to light up the lights
check your fuses and battery connections at the starter. Is the anti theft light flashing? If it is that's your problem. Wait 10 minutes insert the key...wait for the theft light to go out before trying to start.
if that doesn't work you will need to get the starter checked...which means you will have to take it off.
Sep 01, 2016 | 2001 Oldsmobile Bravada
Stuck in park,power windows don't work,reverse lights don't work dash doesn't work. keeps blowing 10 amp fuse for reverse lights.changed brake pedal switch didn't help
of course changing a brake pedal switch will not help in a reversing light problem
they are two totally different circuits
check for a damaged wire at the reverse light switch or bulb holder for the reversing bulbs for a dead short
as for the rest check the IGN fuse under the bonnet
Feb 18, 2016 | 1997 Honda Accord
Brake lights will not work
Check that you have power to the rear of vehicle and check to see if you have power at that brake light switch. If you do then you might check all your grounds.
Jan 12, 2015 | Bosch 2000 00 Mercedes Benz E320...
Will not start,OR CRANK, NO NOISE
Do warning lights and gauges come on, when key is turned to on?
If yes, check for power on the small wire at starter solenoid mounted on the starter with the key held in start. If power at the solenoid, take starter off and test for a bad starter or solenoid. If no power at solenoid when key held over to crank, work back to the switch in the start circuit-starter relay, clutch or neutral safety switch,-power from the start wire out of switch is not getting to the starter solenoid.
If no warning lights or gauges work with key in on position, power is either not getting to switch (bad maxi-fuse or fuse link, or bad battery connections-clean and tighten, recheck)-or the switch itself is not sending power out. Check if battery is charged up. Check all connections and grounds for loose, poor connections.
The start circuit starts at the battery, then to ignition switch, then out of ignition switch on the start wire to the clutch switch (or neutral/park on automatics), and on , ending at the starter solenoid on the starter. Somewhere in your starting circuit, power is lost. Start at the battery-check charge, check connections, check ignition switch.
Aug 25, 2013 | Cars & Trucks
2009 Roketa 50 Gas Moped will not turn over
Hi, Msmcenaney before testing any electrical component in the Starting Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand, clutch, neutral safety switch.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter motor or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. Faulty ignition relay.
14. The electric starter is working but starter clutch has failed.
15. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Scooter Troubleshooting Scooter won start All about Scooters Fix Chinese 49cc Scooter that won start
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
http://www.roketapartsdept.com/
Roketa MC 08 50 User Manual
Aug 11, 2017 | Roketa 50cc Gas Moped Scooter
2009 Roketa 250 no electrical power
Hi, Dmdevers before testing any electrical component in the Starting Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
My brand new Roketa scooter won start
http://www.jr-richscooterdoc.com/Help_electrical_explained.pdf https://absolutelyscooters.net/Omanuals/Roketa_MC-54_150_Owner_Manual.pdf
http://www.roketapartsdept.com/roketa_mc-54-250_parts
Nov 01, 2017 | Roketa 150cc cheap Scooters
Honda 150 motorcycle, it runs but no lights and
good day Sir, try to check the timing off the magnito and check the fuse i hope it will help you.
Apr 06, 2010 | 2005 Honda CG 150 Titan ESD
1984 Ford F-150 replacing the starter?
Hi:
The starter is the next logical choice to swap, but make sure that you have checked all of the connections on your battery and solenoid, and that your charging system is working well enough that your battery is fully charged. If you pull on your head light switch, and then try to start the car, the lights should dim a bit, but not go out. Anyway, back to your starter. Remember to disconnect the negative terminal of your battery first. All it takes to change the starter is to disconnect the nuts that hold the wiring first, then take out the bolts tht mount the starter to the engine bell housing. Reverse the process to install, and hook up the battery terminal last....
Nov 20, 2009 | 1984 Ford F 150
Roketa 150cc four Wheeler Logo
26 people viewed this question
Top Roketa Computers & Internet Experts
David Payne
David Payne
Are you a Roketa Computer and Internet Expert? Answer questions, earn points and help others
