Question about Car Audio & Video
I want to know how much a set of Jensen j124fr car speakers are selling for
    Sergeant:
  • 256 Answers
$10 if your lucky,
Posted on Dec 06, 2012
I have a Sony STR-DE597 FM/AM Receiver .It has audio out plug and i have a Jensen js650 100 watt Subwoofer. how can i hook them up. Thanks.
The reason you may find it difficult to connect the Sony Receiver to the Jensen JS650 is that the JS650 does not have a line level input (RCA) to match the RCA subwoofer output of the STR-DE597 receiver. In this case, all you need to do is connect an extra set of speaker wires from the "Speaker B" Left and Right speaker connections on the back of the Sony to the speaker input connectors on the Jensen. On the front panel of the Sony, select speakers A+B settings so that the subwoofer is on in parallel with the front speakers.
I hope this answer is helpful to your home system set up.
Feb 15, 2015 | Sony STR-DE597 Receiver
No money
NOT MUCH MONEY GO TO ANY JUNK YARD YOU WOULD BE SURPRISED AT WHAT YOU CAN FIND JENSEN BLAPUNK YOU NAME IT THAY WILL SELL THIS STUFF FOR A LOT LESS THAN YOU WOULD THINK HOPE THIS HELPS YOU GOOD LUCK BOB
Apr 25, 2011 | Crossfire CF212D Car Speaker
I don't know how to set the clock on the jensen jbr550 radio in my bus
To set the clock, turn the radio on in tuner
mode (or any other mode).
Press D. The time appears on the display.
Press and hold D until the time display
begins flashing.
While the display is flashing, press the Up
Tuning button to adjust hours and the
“A” (AM) or “P” (PM) indication. Press the
Down Tuning button to adjust
minutes.
After five seconds, the time will set and the
display will return to tuner or CD display.
Aug 18, 2010 | Jensen Car Audio & Video
The red light on jensen 850watt amp wont turn off
jensen sucks dude. just sell it and upgrade. red light could be anytihng. chekc your speaker wires and make sure nothing is touching. from the remote start wire(blue) to the amps and subs. chekc and make sure there is nothing touching.
May 26, 2009 | Jensen Car Audio & Video
I need the customer manual for a jensen vm9212n multimedia receiver
Try the vm9312 manual it´s pretty much the same product, i guess is just that jensen and audiovox are selling the same product with a diferent model numbers depending on the country they sell it. try this link http://audiovox2.info/docs/jensen/man/VM9312_DOC_OM.PDF
OSCAR
Apr 24, 2009 | Jensen Car Audio & Video
Hi to everyone. I have a jensen XS - JA485 1500W amplifier pushing a pair of pioneer 6x9 440W speakers and a set of Starsound digital splits for the front. The guys that installed the sound did not set the...
You can't drive a Pinto at 150 miles per hour without breaking it, you need to get more speakers. a possible solution will be to add a 100 microfarad non polar 200 volts capacitor in series with the speakers to cut the low frequency and use a separate sub for the bass.
Apr 09, 2009 | Jensen Car Audio & Video
Dont know how to wire a subwoofer
The Jensen XS1010 is a 4-ohm sub and should work properly off of the outputs of most any single channel monoblock sub amp or off a bridged 2-channel. You did not say what brand or type of amp you intend to use, but in any case, there's only 2 wires to connect to the sub, one positive (+) , the other negative (-). Simply match them up with the positive and negative on the amp speaker output and you are ready to bump.
Here's the link to Jensen's website:
http://mobile.jensen.com/jensen/
I'd recommend downloading the XS1010 manual. They recommend an enclosure with at least .75 CuFt internal volume.
If this helps, please rate it as "FixYa". Thanks!
Mar 28, 2009 | Jensen XS-1010 Car Subwoofer
I have a 1997 ford f-150,when i hook up the an - wire to my truck,how do i know which is - an which is my book dosnt diffrenciate between the two,jensen says which is whick,my truck book doesnt,thanks
radio install shops sell a wiring harness that utilizes stock radio plug in.these wiring harness,are labeled possitive an negative,thanks ken sheldon
Oct 11, 2008 | Jensen Car Audio & Video
How to activate the "LOUD" in my Jensen UV8
customer support suggested this: Turn the volume control, and while the yellow speaker icon is still visible, press and hold the volume control until you here a double beep. This confirms the new volume setting.
Dec 08, 2007 | Jensen VM9510 Car DVD Player
JENSEN XA 184 AMPLIFIER
Hi, Jensen is under different ownership from when your amp was made, so it's unlikely that you'll find a replacement plug for the high-level input. A high-low converter is also called a line-out converter. It's a device that connects to the speaker wires and changes the signal to a low-level RCA connection. This allows you to use the amp's RCA plugs with your speaker wiring (through RCA signal cables). A line-out converter should be available any place that sells car audio accessories.
Aug 11, 2007 | Jensen XA92 Car Audio Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
