Akai cassette deck GXC-725D
PLAYBACK ONLY ON ONE CHANNEL
  • Audio Player... Master
  • 1,258 Answers
It could be head dirt, bad switches, broken head wire or electronics problem. A Technician or you if you know electronics will need to get into it further to find where the problem is. There si no magic wand except some alcohol and a Q tip if the heads are dirty.
Posted on Dec 06, 2012
3 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: FAULTY LEFT CHANNEL ON PLAYBACK ON PIONEER
Is it electronic or mechanical? The left channel is the physical outer edge of the tape. It's more sensitive to damage and sloppy contact with the heads. If you can see a wave in light reflected off the tape it's probably shot.
When's the last time you cleaned the heads?
Posted on Jan 28, 2010
Grubhead
  • 5151 Answers
SOURCE: my sony cassette deck will
Chances are there is a fault on the right channel. It could be caused by a faulty switch or a wire off on the tape head. Lastly a fault in the electronics.
Posted on Dec 03, 2010
How do I connect speakers to an AKAI GXC-725D cassette player?
manual looks like its available here. you have to register but its free
http://www.hifiengine.com/manual_library/akai/gxc-725d.shtml
Dec 12, 2014 | Akai Car Audio & Video
Akai x 360d tape deck shows recording in both channels in stereo mode on playback one channel has a weak sound
1) Clean the heads real well using denature alcohol. If this does not fix it then try spraying the record play switches with Deoxit contact cleaner. After that it could be the well known Akai garbage transistors that a Technician will need to change.
Apr 02, 2014 | Audio Players & Recorders
Akai cassette deck GXC-725D playback only on one channel
Clean switches, check head wiring if it is a three head deck and then there could be bad relay contacts, defective electrolytic capacitors and even a malfunction in a muting circuit. That is why there are no easy answer but to get in with a scope and find out where the signal stops.
Dec 06, 2012 | Audio Players & Recorders
Aai have the following AKAI Audio Stereo System and no Idea how to connect them. Please help Akai Model AP-D210 turntable Akai model CS-F14 Stereo cassette deck Akai model AT-K110 Fm Am Tuner Akai...
In general, outs to ins.
If nothing else, get the manuals for the preamp and the EQ. You'll probably have to pay for them.
Google it.
Akai PR-A04 preamplifier << This is the control center and where everything comes together.
Akai AP-D210 turntable (ONLY to jacks that say "PHONO"
Akai EA-G40 Stereo Graphic Equalizer (in the Tape 1 Out/In set)
Akai CS-F14 Stereo cassette deck (in the Tape Out/In set of the EQUALIZER) *
Akai AT-K110 Fm Am Tuner (to the Tuner inputs)
Akai DT-100 Audio Tuner (to the Aux inputs)
Akai PA-W04 Amplfier (to the amp outputs)
* This will allow you to Equalize the Tape on the Record or the Playback side.
Read some audio magazines or websites. Get to understand Tape Monitor Loops.
Don't use excessive EQ.
Mar 17, 2011 | Akai Audio Players & Recorders
My sony cassette deck will only playback recording on the left channel
Nov 23, 2010 | Sony Audio Players & Recorders
Won't record and play sounds muffled
Muffled sound is either damaged media (is it mostly the Left Channel? Multiple tapes or not?) or dirty Playback Head. Clean the heads and transport.
Please define better what "won't record" means. Tapes to be recorded need to have the little tab in the corner of the cassette shell present to allow the machine to enter record mode.
Feb 19, 2010 | Sony TC WE435 Stereo Dual Cassette Deck...
FAULTY LEFT CHANNEL ON PLAYBACK ON PIONEER CASSETTE DECK
Jan 27, 2010 | Audio Players & Recorders
Gunk fused to record & playback heads of Onkyo cassette deck
The best cleaner for heads is Servisol Video 40. You can get it from Maplin's UK or Amazon.
Mar 19, 2009 | Onkyo TA-RW244 Single Cassette Deck
I have a akai gx f91 cassette deck just wonderd how much it worth
I have a counterpoint to the above statement. BarryMusic is correct that the AVERAGE cassette deck is worth about $20 bucks. You know, those piano keyed wow and flutter hiss monsters made from plastic Tupperware bins. However, the AKAI GX-F91 was at the pinnacle of cassette deck technology, just predating the release of CD. While never quite reaching the cult status of the Nakamichi Dragon or a few Studer Revox units, a drab one will easily fetch $200-$400 dollars as a PARTS MACHINE. A fully restored GX-F91 in the right market (Japan, Europe, the Middle East) can go NORTH of $1000. An all time high I saw was $1717 for a cherry machine. http://www.audio-extasa.eu/akai-gxf91-cassette-deck-p-648.html
Jan 02, 2009 | Audio Players & Recorders
Motor for Akai GXC-740D Casette Deck
Hi pelagic
The motor is probably faulty. The heat is a give away for that. Many motors for older decks can still be sourced. Can you see what part numbers may be on the back plate of the motor and I can find a source for you. Awaiting your reply
regards
robotek
Sep 07, 2008 | Audio Players & Recorders
117 people viewed this question
 Grubhead
Grubhead
