How do i change the clock on glow worm 30cxi
For some reason when I got up this morning, the clock on the boiler changed to approx 1 1/4 hrs later than the normal time!! I have no idea how and I also have no idea how to change it back to the correct time?
2 Suggested Answers
  • 120 Answers
SOURCE: service manual for a glow worm 30cxi boiler
Follow this link
http://www.glow-worm.co.uk/stepone/data/downloads_sd/51/00/00/cxi-range.pdf
Cheers
Posted on Aug 13, 2010
A climapro radio frequency handset controls a glow worm boiler. It only functions within one meter to the boiler. no error message ans batteries not exhausted. Do you have any idea? Thanks.
There are two things that may be a problem. I do not have any experience with this boiler, but have years of experience repair radio systems. It is possible that your antenna at the boiler is behind metal, or even not attached.
Check https://www.glow-worm.co.uk/homeowner/products/climapro-control-1476.html for additional help. Both the install and user manuals are here.
Dec 03, 2017 | Radio Communications
Hi just bought a VW Caddy Diesel 2006 and having problems starting it in the morning. Changed glowplugs but not made any difference. Any suggestions?
Hi there?
Have you checked if they have power goint to the glow plugs with the ignition on.
What is the temperature sensor reading in the morning, if it reads little bit worm then it thinks that the engine is worm and it wont power the glow plugs.
May 24, 2011 | Volkswagen Eurovan Cars & Trucks
Service manual for glow worm boiler micron soff
Can you give a model number and more info? I think you mean a micron 60ff in which case it is here: http://www.glow-worm.co.uk/stepone/data/downloads_sd/8d/00/00/micron-60ff.pdf
Jan 02, 2011 | Heating & Cooling
On my 30cxi boiler its flashing up f12 do you no the problem?
Electronic board and touch module communication error 1. Disconnect power for 1 minute.
2. Reconnect power.
3. If failure remains, replace board connection cable between touch control module and electronic control.
4. If failure remains, replace the electronic control.
5. If failure remains, replace the touch control module
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#ixzz0tXhzQz2F
http://www.appliancepartspros.com hope this helps
Jun 25, 2010 | Kitchen Ranges
Glow worm 45 60 boiler
You have to have 12" clearance on all sides.
Apr 02, 2009 | Water Heaters
How water problem
Your should be able to find the information here. Don't forget to check under discontinued products. www.glow-worm.co.uk
Dec 03, 2008 | Water Heaters
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
