Akai cassette deck GXC-725D playback only on one channel
PLAYBACK ONLY ON ONE CHANNEL
  • Eddie Edwards
    Eddie Edwards Dec 06, 2012
    RECORDS ON BOTH CHANNELS ONLY PLAYS BACK ON RIGHT HAND CHANNEL
  • Audio Player... Master
  • 1,267 Answers
Clean switches, check head wiring if it is a three head deck and then there could be bad relay contacts, defective electrolytic capacitors and even a malfunction in a muting circuit. That is why there are no easy answer but to get in with a scope and find out where the signal stops.
Posted on Dec 10, 2012
5 Suggested Answers
robotek
  • 1512 Answers
SOURCE: Motor for Akai GXC-740D Casette Deck
Hi pelagic
The motor is probably faulty. The heat is a give away for that. Many motors for older decks can still be sourced. Can you see what part numbers may be on the back plate of the motor and I can find a source for you. Awaiting your reply
regards
robotek
Posted on Sep 11, 2008
dunnbiker
  • 8546 Answers
SOURCE: FAULTY LEFT CHANNEL ON PLAYBACK ON PIONEER
Is it electronic or mechanical? The left channel is the physical outer edge of the tape. It's more sensitive to damage and sloppy contact with the heads. If you can see a wave in light reflected off the tape it's probably shot.
When's the last time you cleaned the heads?
Posted on Jan 28, 2010
Grubhead
  • 5384 Answers
SOURCE: my sony cassette deck will
Chances are there is a fault on the right channel. It could be caused by a faulty switch or a wire off on the tape head. Lastly a fault in the electronics.
Posted on Dec 03, 2010
  • 11800 Answers
SOURCE: I have a Marantz PMD510 dual cassette deck. Both
There are no fuses in this unit. The decks can't read or record because either the connection switches from the heads to the boards have failed or the power source is no longer active.
You will need to locate the switch by following the data cable coming from the heads and determine why it has failed and how it can be fixed. Then check the connections from the switch to the signal board. Finally check the power : the output of the transformer and the filtering and stabilization stages.
Posted on Aug 16, 2011
Playback low in one channel in reverse playback only forward playback fine. unit has been cleaned and lubed
Hard to say, but the three leading suspects would be:
  • dirty relay or switch (whatever switches between the forward and reverse heads)
  • bad head (so worn that one channel just doesn't produce as much signal)
  • bad electrolytic capacitor in the reverse-head preamp
None of these qualifies as a quick fix and all of them would require an oscilloscope or high-sensitivity amplifier for troubleshooting.
Aug 05, 2015 | Teac Audio Players & Recorders
How do I connect speakers to an AKAI GXC-725D cassette player?
manual looks like its available here. you have to register but its free
http://www.hifiengine.com/manual_library/akai/gxc-725d.shtml
Dec 12, 2014 | Akai Car Audio & Video
Akai x 360d tape deck shows recording in both channels in stereo mode on playback one channel has a weak sound
1) Clean the heads real well using denature alcohol. If this does not fix it then try spraying the record play switches with Deoxit contact cleaner. After that it could be the well known Akai garbage transistors that a Technician will need to change.
Apr 02, 2014 | Audio Players & Recorders
Playback background noise
Undo the previous recording after each take
Dec 23, 2013 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
My OPPO -95 BVD in audio playback began losing it's left channel playback in two channel stereo mode operation
The electronics in that channel are failing, the intermittent scratchy sound is classic symptoms of internal transistors failing in manner called 'thermal runaway'. If I am right it probably works better when its cold and gets worse as it warms up, and when you turn up the volume. It will be cheaper to replace the appliance than repair it. Buy the cheapest supermarket item you can, because any appliance that takes in optical disks will not last more than a few years, usually they stop playing discs before the electronics fail.
Dec 15, 2013 | Televison & Video
It could be head dirt, bad switches, broken head wire or electronics problem. A Technician or you if you know electronics will need to get into it further to find where the problem is. There si no magic wand except some alcohol and a Q tip if the heads are dirty.
Dec 06, 2012 | Audio Players & Recorders
My sony cassette deck will only playback recording on the left channel
Nov 23, 2010 | Sony Audio Players & Recorders
Won't record and play sounds muffled
Muffled sound is either damaged media (is it mostly the Left Channel? Multiple tapes or not?) or dirty Playback Head. Clean the heads and transport.
Please define better what "won't record" means. Tapes to be recorded need to have the little tab in the corner of the cassette shell present to allow the machine to enter record mode.
Feb 19, 2010 | Sony TC WE435 Stereo Dual Cassette Deck...
177 people viewed this question
 Grubhead
Grubhead
