Question about Craftsman 7.8 Generac Generator Engine Muffler Exhaust 4200 Watt Part No. 83071
What are the valve settings for a Craftsman Generator 4200 Model 580.32674
Model 580.32674
2 Suggested Answers
  • 252 Answers
SOURCE: Just changed oil on the
make sure you put the correct type of oil in the crankcase for this machine
if you use the wrong type of oil ,oil level sensor float wont work and causes a shut down to protect the generator engine from damage
try draining oil and refilling with 20w/50 oil
cheers pauly46
Posted on Apr 03, 2011
Need valve setting for B&S 18.5 single engine
.003-.005 intake (bottom valve)
.005-.007 exhaust (top valve)
with piston 1/4" past top dead center with both valves closed
Jul 13, 2014 | Craftsman Garden
White smoke
You are getting oil into the cylinders. Possibly bad seals on the valves or bad rings on the pistons.
Apr 01, 2014 | Craftsman 5600 watt Generator
Maunual for generator #580.32670
How do you replace the cam in the motor of a craftsman model 580327360
Nov 06, 2013 | Craftsman Briggs & Stratton Generator,...
Wiring diagram for generator
What generator make and model do you need a wiring diagram for?
Sep 17, 2013 | Electrical Supplies
Flywheel on 5hp generator keeps freezing up
sounds like bearings on your krank are going out
Jul 01, 2012 | Craftsman Briggs & Stratton Portable...
Just changed oil on the 4200 watt Craftsman generator, motor starts and runs 2-3 minutes then automatically shuts off for no reason. Any ideas on how I can solve this problem?
cheers pauly46
Apr 03, 2011 | Craftsman Garden
I have an older Craftsman 750 watt generator model 580.328310. Serial # on this unit is 029434. Unit runs great. I am looking for foam air filter, rubber foot for bottom and new gas gauge.
Take a look at the http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Generator-Parts/Model-580328310/0247/0702250?pathTaken=
look for the parts that you need and you can order them direct from Sears.
Jan 09, 2011 | Craftsman Garden
Potential Motor damage
Submersable pumps pull a lot of current on start up. Up to 7 times running momentarily. This is especially true of three wire pumps. ( Ground and 2 , 110V) 4 wire pumps have a capacitor start provision ( the extra wire) and a control box that greatly reduces the starting load by shifing the phase on startup.
4200 watts should handle it how ever if you have no line losses. Excess Line losses will do exactly what has happened to you. Overheated the connections and burned up the pump.
First check what gauge wire you have going from the generator to the pump and the length of the run. Check a wire gauge calculator such as http://www.denningelectronics.com/wiregauge.htm
use at least 4 times the running load for your wats and if it is a deep well pump, more than 50 feet of head from water to spickot) then use 7 times wattage. Use 5% line loss allowable,. This will probably uncover your problem as under size wire.
The other possibility is that the breaker was going bad over time and caused the voltage drop0 that destroyed the pump.
Last item you can do, check the voltage at the generator when the pump starts, it shold not drop more than 10% on start up.
Good luck
Mar 17, 2009 | Craftsman Air Tools & Compressors
Craftsman 7.8 Generac Generator Engine Muffler Exhaust 4200 Watt Part No. 83071 Logo
71 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
