Where can I download new firmware for my Panasonic DMR-EX77
Unit will only register the first 250 channels in the automatic scan mode. (Up to the first few in Channel 49, Frequency 690, then terminates). Hence, the preferred channels are missed.
bestdarngood
  • 3037 Answers
SOURCE: My panasonic dmr ex77 is
I know that this is what you do on a different one, please let me know if it doesn't work
Try this to unlock it to be region-free:
1) make sure you don´t have any DVD inserted and have Door Closed
2) IN remote control :
3) press SETUP
4) IN the Front Panel :
5) press NEXT
6) press STOP
7) press PAUSE/STEP
8) press PREV
9) press NEXT
You should now see a new MENU. Go to Select Region and make your choice:
- region 1
- region 2
- region 3
- region 4
- region 5
- region 6
- By Pass
Select ByPass and you're sweet. Not sure if it'll work with yours but it's worth a go.
Let me know what happens, good luck and have a good day
Posted on Apr 22, 2008
ginko
  • 19396 Answers
SOURCE: Multi region code for DVD
You need to hack the dvd reinstalled firmware, I can see if I find hacked firmware for your dvd
Posted on May 01, 2008
  • 12 Answers
SOURCE: PANASONIC DMR-ES35V CANNOT READ ANY
i thing its a laserunit you need open that dvd and try cleen laser,but very very easy,its a little pot on back laserunit its can be set to,but if that not help,find laserunit number and try find new on internet :o(
Posted on Aug 14, 2008
SOURCE: Panasonic DMR-E85 DVD recorder TV Guide problem
Try unplugging the DMR-E85 power cord. It is important that you unplug it from the back of the recorder, not the wall. Leave it unplugged for 10 or 15 minutes. For good measure disconnect the cable 'in' connection as well. Once both lines are plugged back in it will go through its self-check diagnostics. Leave it alone for awhile (give it time to consider the error of it's ways). If you are lucky, when you turn it back on it will ask you to verify the channel lineup. If this does work, and all the channel info is correct, press 'enter' (lineup 1 highlighted). Good luck! This is an awesome machine, WHEN IT WORKS!
Posted on Jan 24, 2009
  • 38 Answers
SOURCE: Panasonic DMR-EX77 - Error code DVD3
Pan use a version of Linux on the recorder. If you change the hard drive there is a format command in setup to format a new hard drive. Put a DVD in and try selecting and playing both DVD and HHD via the front panel buttons. Sometimes you can get error codes on a unit when the batteries in the remote are low. Try changing them Sometimes the remotes are faulty and not communicating properly. A fix in some cases is to press the number button corresponding to the number shown on the display together with the enter or OK button for at least 2 seconds. Good luck
Posted on Feb 07, 2009
How do I retune my Panasonic Viera TV?
Hello
To tune your Panasonic Plasma to on air TV channels do the following:
Connect the antenna connection to its antenna in at the back panel.
Automatically searches and adds available channels to the memory.
Select "ANT in"
Select Cable or Antenna Select "Auto"
Select a scanning mode
Auto channel setup
Select "Auto program"
Select "ANT in"
Select "Auto"
Select scanning mode (ALL channels/Analog only/Digital only
Start scanning the channels
Available channels (analog/digital) are automatically set.
All channels: Scans digital and analog channels
Analog only: Scans Analog channels only
Digital only: Scans Digital channels only
Confirm registered channels
If OK is not pressed after selecting "Apply", the channels will not be saved.
The channel will be saved when no operation is performed for 60 seconds and
the "Manual program" menu will also exit automatically.
If you perform scanning more than twice, previously saved channels are erased.
About broadcasting systems
Analog (NTSC): Conventional broadcasting
Digital (ATSC): New programming that allows you to view more channels
featuring high-quality video and sound
[Use "UP ' DOWN ' RIGHT ' LEFT] AND 'OK"] keys to selcet and proceed.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
My panasonic dmr ex77 is not multi region. How can i make it so?
The procedure below is a hack , can interfere with the normal working of the DVD player
*** Please note *** You will need a laptop with an Infrared (IR) port to use this method.
Most modern laptops have now dispensed with IR ports in favour of WiFi and Bluetooth, so you may need to forage around and find an older laptop with IR.
1) Download both parts of Chachi's RAR file (both of these files can be easily found on this forum).
You will need both files, as the ISO image file has been split across two compressed files.
2) Using WinRAR or WinZip unpack the ISO image file to a folder on your hard disk (the desktop is a good place, so you can easily find it later).
To successfully unpack the ISO image file, both of Chachi's RAR files must reside in the same folder.
As you extract the ISO file from the first archive, WinRAR or WinZip will automatically move to the second file and continue the unpacking process.
After the unpacking process has completed you will be left with a single file with the extension ISO.
3) Using Nero (or similar), use the "Burn Image to Disk" feature to burn the ISO CD image onto a blank CD (just copying the ISO image file onto a CD will not work).
I used Nero to achieve this, but most CD burning software can do the same.
4) On the laptop, ensure that the IR port is set to COM2 in the BIOS (note the original settings, so you can put them back after you have reprogrammed DMR-EX77).
Try to select an older IR mode if available.
My old Toshiba Satellite 4030CDT only supported FAST IR modes and wouldn't work.
I then switched to an Acer Aspire 2000 and through trial and error found the "IrDA (HPSIR)" mode worked perfectly.
5) Boot the laptop from the CD
If your laptop does not give you the option to change the boot drive order at POST, you may need to temporarily change your boot drive order in the BIOS (note the original settings, so you can put them back after you have reprogrammed DMR-EX77).
6) When the laptop has sucessfully booted from the CD you will be presented with a menu.
Using the down cursor key, select option "4. Minimal Boot" and press return.
7) At the "A:\>" prompt type "cd winamp" and press return.
8) At the next prompt "A:\>WINAMP\" type "winsamp" and press return.
9) The Remote control test tool should now be loaded (blue screen with white text).
10) Press the "r" key to load in the REMOTE.TXT file (this file contains the IR signal information required to reprogram your DMR-EX77).
11) The captions "button 1" to "button 10" near the bottom of the screen will now have changed from white to pink.
These are the emulated buttons you will need to press in order to unlock you unit.
Ensure "button 1" is highlighted before proceeding to the next step.
12) Power on your DMR-EX77 and switch it to DVD mode.
You must ensure the disk tray is empty during this process.
I had my disk tray empty and ejected (sticking out) during the process just as a precaution.
13) Point the IR port on your laptop at the IR receiver on your DMR-EX77.
The IR port on the DMR-EX77 is located just above the DVD/CD Open/Close button on the right of the unit.
I found the optimum distance between the laptop and the infrared receiver on the DMR-EX77 was approximately 5~6 centimetres, any more and it may not work.
14) With the IR ports aligned and "button 1" highlighted in pink press the return key on the laptop, wait a moment, cursor right to "button 2" and press the return key, wait a moment, cursor right to "button 3" etc....
Keep repeating this procedure until you have entered all buttons highlighted in pink from 1 to 10 in order.
If your DMR-EX77 reacts as mine did during the process you may see the display on the DMR-EX77 change and also experience the TV channel changing.
Don't panic as this appears to be quite normal during the unlocking process.
15) If all has gone well the display on the DMR-EX77 should now read "HELLO" and you should hear the hard disk spin down for a second, then spin up again.
The DMR-EX77 has new reset itself and has successfully been reprogrammed.
Leave the unit alone for approximately 10~15 seconds before doing anything else, just to be on the safe side.
16) The buttons on the front of the DMR-EX77 unit will no longer function, so switch the DMR-EX77 off using the remote control.
If you left the tray poking out during the reprogramming process (as I did), just wait a few seconds and it will close automatically, you can then switch off the DMR-EX77 using the remote.
There is no need to disconnect the DMR-EX77 from the mains supply.
17) Switch the unit back on, pop in any region DVD you like, sit back and enjoy biggrin.gif
Switch off your DMR-EX77 using the power button and leave it off for a few seconds.
Switch back on your DMR-EX77 and when it's ready try the proceedure again.
I failed several times initially, but it didn't seem to do any harm and everything is fine.
You may also find that changing the IR mode setting in your laptops BIOS may help.
I had to try a few different modes until I found one that worked.
If you can't find the files you need, or require the procedure for using another type of device to region free your DMR-EX77, then visit:
http://www.dcevolution.net/panasonic...tpage&Itemid=1 user_offline.gif
Apr 22, 2008 | Televison & Video
I have the Panasonic DMR EZ28K and while in stand by mode and even while playing a DVD, the display will show U99. When this happens, the unit will not turn on to record whatever I have programmed. To...
You can probably fix this issue by updating the firmware and doing a system reset. First, download the latest firmware and burn it to a CD. You can download it from here: http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/Drivers-Downloads/model.DMR-EZ28K.D#ts
Now, power the unit down, press Skip/Rev + Time Slip + Open/Close for 5 seconds. The CDR should be in the disc drive as you do this. This will install the new firmware and re-initialize the system settings.
The complete manual is here: http://service.us.panasonic.com/OPERMANPDF/DMREZ28-MUL.pdf
Good luck and thank you for using FixYa! We would sure appreciate a 4 "thumbs-up" rating for this answer. Happy holidays!
Dec 05, 2010 | Panasonic DMR-EZ28K DVD Recorder
Since it went into "disk recovery mode" it now will not play dvds
Got the same problem. Happened 2 months after guarantee expired. **** machine. The only good thing is the harddrive and that is made by HITACHI not Panasonic! I go Sony next time. Panasonic quoted £200 plus to fix the problem. I only paid £220 when I bought it new.
Sep 13, 2009 | Panasonic DMR-EH65 DVD Recorder/HDD...
I have a Panasonic DMR EX77 PVR. Two days ago the Electronic Programme Guide stopped working and was replaced by the message "No Data". Is this a unit failure or just a temporary problem with the...
It must be no coincidence that our Panasonic DMR EX768 has done exactly the same exactly 2 years later i.e. on the weekend the clocks go back. We intend to reset the time & see if that solves the probelm
Oct 30, 2008 | Panasonic Televison & Video
Making my Panasonic DMR EX77 multi zone
i have the same player and wont play burned dvds
Sep 05, 2008 | Televison & Video
May 01, 2008 | Onkyo DV-CP704 DVD Player
Panasonic DVD Recorder DMR-EX77 My DVD Recorder is communicating between the Remote Control and the DVD Recorder, but the Recorder is not communicating correctly with the television. The DVD Recorder seems...
It sounds as if the actual T/V channel is out of tune.
I,d suggest powering the player On.
Then using channel 8-12 on the T/V to Scan for its frequency.
When you,ve located it to the Player.
Lock the channel, then use the DVD on Channel 8-12.
Mike @ compurepair.
p.s also check the output from DVD To T/V lead has,nt come loose.
Mar 17, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
How do I flash the firmware for a Panasonic DMR-EZ47V?
According to the Engineering channel schudle there is a new firmware (v.1.13)for the following panasonic models
DMR-EZ27, DMR-EZ47, DMR-EX77, DMR-EX87
This is scheduled to be broadcast on 6-2-08.
http://www.dtg.org.uk/retailer/download_schedule.pl user_offline.gif
Jan 31, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
DMR-E85h
That's frustrating huh! I finally found someone at the cable company that knew somthing.. I think it's channel 95 (might be 94), if you tune to that channel, sometimes it get's it immediately, other times it needs some time to download it. But make sure you're tuning to that channel in your line up. In the setup mode you can specify it if it doesn't do it automatically. (just spend some time in setup and you'll see what I mean)
Nov 14, 2007 | Panasonic DMR-E85H DVD Recorder
Televison & Video Logo
517 people viewed this question
Top Televison & Video Experts
Electro Med Services...
