Question about Sony Playstation 3 (PS3) Console
Getting online its saying something bout a ip adrress n no connection n i have it hoooked up 2 a wire connection
    Scholar:
  • 50 Answers
You have to make sure that when you go to 'network settings' and 'wired connection', that you pick the same security option that your connection shows. (wlap or something) (hopefully it is the 'none' option) if it is none then you should have no problem. if it is one of the other 2 then you have to make sure that the password that you enter is identical to that of your modem and/or computer (it is case sensitive) hope this helps, if so please rate me...Thanks a lot.
Posted on Jan 12, 2009
Cant find ip adrress can u tell me what it is
Unless your television is connected directly to the internet somehow, or it is accessed on a local network using an ethernet router, it should not have an IP address of its own. What is the context of the original request?
Aug 03, 2013 | Proview PA-32JK1A 32 in. LCD Television
I instal my wireless adapter and thats work fine with my router. Its says that is connected, but I have error message from network that computer cant find netgear and my network is unidentified. If I look...
Right-click on the Wi-fi icon in the bottom right corner of your computer display and select "Troubleshoot problems". Wait while the Windows Network Troubleshooter tries to identify and fix the problem.
Sep 29, 2017 | NetGear WG111T 802.11g/b (E82321) Wireless...
How to configure ip address in canon ir 400
if you want to configure IP adrress you have to righty clic on the LAN connection and select properties and then select internet protocol ( TCP\IP). select its properties and enter manual IP address 192.168.1.2 and sub mask net 255.255.255.0 and press OK and close dialogue box.
After that open run and enter ping 192.168.1.2 press enter if you got reply the printer is ready.
all this use when printer on and connected properly.
or call me after 8.00 P.M Cell : 9014363609
Aug 19, 2010 | Canon imageRUNNER 400S Copier
Unable to connect lapttop it says limited connectivity green bars are full
Check out thenetwork setting. Try using the ping in cmd and the ip adrress of the host from the guest. Check that your network is on shared and on nonprotected mode or if protected apply proper authentication which is being prompted.
Jun 05, 2010 | 2wire (1000-400108-001) Router
2 wire att&t box not working
Ley me tell you att and 2 wire/netgear/linksys router 's ip address are same it's known as Double Nat issue.
So here you go-
Try to change the ip of your router say 192.168.5.1 - Save settings- and restart the router-If still unable to go online.
Call isp and get the username and password for PPPoE settings and convert the modem to FULL BRIDGE MODE.
I hope it will work
TechGuy
Linksys
Samson
Apr 02, 2010 | 2wire Computers & Internet
Need an ip adress for x box live the one i have says its not valid
All routers made by NETGEAR DG834G routers admin panel is located here type this into the browser (not the search engine)
http://192.168.0.1
Username:admin
Password:password (unless its been changed)
Then goto connected devices when you Xbox is plugged in and find you MAC address and IP address for all clients connected to the router, create a reservation if you want you X-Box to have the same IP adrress everytime it is used.
http://www.routerpasswords.com/index.asp
Check this excellent website for other passwords that may work on other models if you have any problems.
Please Rate my Solution
Oct 19, 2009 | NetGear DG834G Router
I can not access wirless connection. The system states connected but it's not connecting
check wireless network adapter is configured to get the IP adrress manualy or automatically. if it's manualy, then change the settings to automatic so that wireless network can issue an IP adress to the device.
Aug 17, 2009 | Acer Computers & Internet
On your computer, click start>run.
In the box, type <command> (without the brackets)
at the c:\doc&set\<username> prompt, type <ipconfig> (again, no brackets)
the line you are looking for is default gateway
Apr 18, 2009 | Computers & Internet
Can't find an IP Adrress
my friend thin may due to your new ip address.just repair it and try u can then connect.
Mar 28, 2009 | Sony PlayStation® 3 (60 GB) Console
Belkin ADSL2+ Modem with Wireless G Plus MIMO Router
Me Two, I just reboot my cable box and router box, i do wireless online gaming and every bout 10 mins, i get disconnected even though i have full signal, on he routers web interface settings I have everything up-and-running and thr top right hand corners says connected, but when it drops I just realised that the internet light stops blinking aswell..???
What is this, this routers is way too annoying keep getting disconnected from every god damn game.
Keep me up-to-date if you what the preoblem is.
And oh, the person who can't get on the internet even though his ''WAN'' Says Stable i have 2 possible reasons.
In the address bat type in the following..
192.168.2.1.
look on the left of the screen you can see DNS, if not already ticked, tick the the little box which states.
'' Automatically assign DNS by IP'' then Apply Changes.
Or, Go Straigt down to the bottom and go to system settings, also go down to the very bottom. At this poin you can see A option or '' Advanced Featue! '' Menu saying, UnPn or something lol, click the box which says enable or something.
Hope this has helped
Thomas Miezavs
Jan 04, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
