Leaks when rinsing/spinning
SOURCE: Water leaking through detergent tray of my Hotpoint WF860
It sounds like the washer is not draining properly.
Remove lower rear cover of washer, locate and remove the large black hose fastened to bottom of tub.
remove plastic filter inside hose, and clean same.
Refit filter and hose, making sure it is on properly.
Be careful when you remove the hose, as there will be water in there.
As an extra precaution, remove soap draw,and thoroughly clean all parts, particularly,the conditioner parts
Please rate my fixya solution.
Thanks.
SOURCE: Hotpoint WD61
1, your pump may be blocked by fluff coins and other debris.
2. more likely bushes worn on the main motor not giving enough umphhh (loverly word) to go through a complete spin....Bushes easily replacable. Job start to finish with parts on hand a machine mechanic 10-15mins top Diy er like me an hour allways have trouble finding the right spanner... Good luck.
SOURCE: no instructions
Go to:
www.hotoint.co.uk.
Scroll down and click on www.hotpoint.co.uk.
Click on after sales and then click on down load instruction books, type your model number in and you can save it to your hard drive, or print it off.
Plz rate my solution.
Thanks.
SOURCE: I have a Hotpoint WM52 that fills but will not spin / rinse
Check the brushes in the motor, and replace if less than 5mm or or so in length.
Please rate my solution.
Thanks.
SOURCE: Hotpoint First Edition 1000 WM52
I had same problem. Had to replace brushes on motor. Easy enough job to do yourself
hi thanks to all ref's on fixya, i removed 'pump hose',grey hose that pumps water out, it was full of gunge. i rinsed it through and cleaned the connection to the u bend, no more leakage! hope this helps someone else. thanks to all on fixya, jerry
