Question about Haier Refrigerators
Refrigerateur [New] Is there freeon in compresser during shipping.Do I need to have charged.Thank's Pete.
    New Friend:
This is the common problem with haier compact refrigerator.All you can do is get contected with haier and get repaired.
Posted on Oct 12, 2013
    President:
  • 1,082 Answers
No you should not need it charged. The system is sealed.
Posted on Dec 06, 2012
Freon smell coming through vents on 323ibmw
I don't think there is any smell put into refrigerant,so
you may be smelling coolant from a heater hose or
heater core leak or system valve, somewhere
The A/C cycling could be low refrigerant, in which case
you have it leak tested & system repaired
You don't try to add yourself,it will leak out & pollute
the atmosphere
Sep 07, 2012 | 2000 BMW 3 Series
Can you recharge the freeon in a frigidaire upright freezer?It's not as cold as it should be!
I the freon has leaked out, this means there is a leak in your sealed system. Unless you can find the freon leak, charging the system will do no good. It will leak out again. There are many things to cause a freezer to not freeze. Is this a "Frostless" Freezer or a "Manual Defrost"?
Mar 30, 2012 | Freezers
Blackberry 8900 would not turn on
Make sure that your battery is not absolutely empty. Plug in your charger and hang on for 15 minutes. If nothing happens than you must have a hardware problem, that means you have to visit your phone brand's service.
Feb 23, 2012 | RIM BlackBerry 8900 Smartphone
When fully charged the scooter only lasts ten to fifteen minuites
This is sadly not unusual for these things after some time of use. Depending on the quality of the product (battery, engine, etc). The battery often gets reduced over time, and eventually needs to be changed. I have no knowledge of this exact product, so it could also be a great quality, but faulty battery. In either case you would have to by a new battery.
Another possibility is heavy spinning wheels. Too much resistance quickly depletes the battery. Easy to check out by turning the front wheel, but the rear wheel is harder examined as it is connected to the engine. If you are unsure, you could remove the chain.
Jan 28, 2011 | Razor E100 Electric Scooter
I had my ac charged with freeon in June and a month later I have no ac. I don't think this is a compressor problem. Any idea where to leak could be?
Check to see if you still have freeon. If not you have a leak. Most auto parts stores sell freeon with a stopleak and oil combination charging system.
Aug 07, 2010 | 1995 Pontiac Bonneville
Refrigerator not getting cold enough
hi..
the blower is broken or frozen.You need to defrost and clean it or the air passages are clogged...
thank u
rate me
Jul 25, 2009 | Dometic RM2620 Refrigerator
Air conditioning
You probably have air in he system. You need to vaccum the system down and then put freon in. You can either rent the equimpent to do it from autozone and do it yourself, or take it to a shop.
Jun 08, 2009 | 2000 Dodge Caravan
SR42NMB
The double switch of the door might be out. change it with a new one (it is so easy to do ) you have also to clean the defrost channal. agood luck!!!
Jun 26, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
Refrigerators Logo
300 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
