Question about Bosch Dishwashers
Can't find SGS43t62 float switch assembly
  • Sam Dec 10, 2012
    sorry did not realise you had posted a comment. Tryhttp://www.bosch-home.co.uk/store/sparep... and go to diagram number 0524 for location of float. Sometimes the problem could be with the Aquastop hose if you are using one.
  • Sam Dec 10, 2012
    that should be diagram number 5 - item number 0524
  • Bosch Master
  • 3,247 Answers
The float switch in most Bosch dishwasher is part of the Aquastop circuit found in the inlet water hose connected under the kitchen sink. Refer installation instructions at this page. Type in the model number and download it.
Posted on Dec 06, 2012
  • philip903
    philip903 Dec 06, 2012
    Many thanks for the reply , unfortunately the link wouldn't let me login
Dishwasher won't fill with water
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Kenmore Dishwashers
Dishes just aren't getting clean...bottom or top rack
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | Frigidaire Dishwashers
The dishwasher is stuck on drain, I think it has something to do with the overflow. Can you help? Thanks. I have checked all out lets & water in & filters.
Hi
The issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | Candy 17 in. CS455 Built-in Dishwasher
MAYTAG PERFORMA PDBTT49AWW, SN 10120630ET - Under counter model, ABOUT 6 YEARS OLD. No longer gets dishes clean. Problem got progressively worse over 2 year period. After washing cycles, the inside of...
Hi
Daniel
Aug 22, 2011 | Maytag Dishwashers
Dishwasher comes on but it won't fill.
Hi
Daniel
Aug 21, 2011 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
Unit won't fill with water
Hi
Daniel
Aug 01, 2011 | Bosch 24 in. SGS43C12 Classixx...
Dishes come out with a film on them & have to re rinse them by hand model # GSC3200Z30Bl
Hi
Daniel
Jul 21, 2011 | Dishwashers
Freestanding model ADP7740, 33" tall.
Hi
Daniel
Jun 19, 2011 | Whirlpool Dishwashers
Not filling with water
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly.
Daniel
May 07, 2011 | Beko Dishwashers
No water intake
Hi
Daniel
May 06, 2011 | Neff Dishwashers
Dishwashers Logo
286 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
