I complained earlier that unit wasn't coolin enough
    Top Expert:
  • Heating & Co... Master
  • 76,691 Answers
What diagnostics have you run, is the pressure ok?
Posted on Dec 06, 2012
My ps2 wont log onto my internet past checking the dnsa?
From memory of sons PS3 but should be similar in ps2---In set up--- check IP address settings are on auto make sure you have the right WIFI network -type indicated,.... and above all make sure your WIFI signal is in range and you have a good signal when setting up.....The problem I had with sons PS3 was similar nothing indicated that the signal wasn't good enough...i did everything i could think of including putting static ip addresses---nothing worked...to cut the story short, it turned out that the wifi which should have been in range wasn't good enough... accidentally got a connection in auto a couple of times which bombed out quickly...But---after replacing wifi with a better range unit and updating broadband all such problems disappeared
Sep 23, 2012 | Sony PlayStation 2 (PS2) Console
98 DEVILLE OVERHEATING...PURGE LINE OK, NEW THERM, NEW RADIATOR, YET IT STILL OVERHEATS. ALSO IM NOTICING A SMELL OF EITHER EXAUST OR GAS IN THE RESERVE..?? ANY SUGGESTIONS PLEASE...
check belt tension for the water pump if belt too loose pump will not send enough water in and will cause your engine to overheat, also check that your coolin fan is working,
Oct 12, 2011 | 1998 Cadillac DeVille
My bissell proheat turbo 2x hand tools will dispense solution but not water.
  • Fixed it! The check valve on the bottom of the bladder wasn't going deep enough into the recepticle on the base of the unit; the valve wasn't opening, and the pump was sucking from a dead end. (It WOULD pull soap from the small tank, but not the main bladder reservoir.) I cut a 3/4" piece of a disposable ball-point pen cap, to ride over the rod in the center of the recepticle. Long enough to push the valve open, but short enough that the tank assembly sat down on the base. If the rod is too long, it will push the whole tank up, and break the vacuum seal at the forward edge. Evidently this thing was designed to a tight tolerance, and just a little aging/distortion of the plastic reservoir base was just enough to keep the valve from being pushed open!
  • Jan 29, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
    Coolin
    As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
    Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
    http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
    http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
    http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
    heatman101
    May 31, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
    My television turns off for no reason. It will
    go here and complain-if enough of us complain they will do something-this unit shgould not fail after a few years of use
    http://www.support.philips.com/support/contact/contact_us.jsp?userLanguage=en&userCountry=us&contactId=PU_US_1_3&weekDay1=Monday%20-%20Saturday%208:00%20AM%20-%2011:00%20PM%20EST&weekEnd1=Sunday%209:00%20AM%20-%206:00%20PM%20EST&_dyncharset=UTF-8
    Feb 10, 2010 | Philips 32PT6441/37 32" TV
    On my 2000 Jimmy when I'm at low speeds in the city it usually blows quite warm out of the heater (not always). But suddenly it will quit blowing any heat at all. On the highway it just blows cold. The...
    Hello. First, it is probably that the clotch in the coolin fan isn't working. When the coolin fluid is warm, the temperatur put it in work, and the fan works rapidly, when the temperatur lows, the clotch loose the fan an is waiting the warm up again. But your Jimmy don't have the coolin fan in the principal belt, it have an electric coolin fan. In that case, your problen is for a low level of coolin water, or the relays of the electric fan don't work properly.
    Finaly, my english isn't good, because I speak in spanish, but if my bad english solves your problem, i'm geting so well. I working every day in electronics cars, and that is the basic metod of analyse that I use.
    Dec 21, 2009 | 2000 GMC Jimmy
    Picture darkens automatically at random times during use. Active Contrast and DNR make no difference. It looks like the TV is trying to compensate for bright scenes by lowering contrast and brightness.
    Oct 31, 2009 | Philips 32PT5441/37 32" TV
    Hi we have a burnt out circuit board in the cooline a/c unit under the house, is there a place that ells spares to the public? we are in brisbane queensland
    Cooline units are imported to your country from Kuwait. I doubt they are making them there - but I don't know who does make them.Try calling: Tri-Tech Air Conditioning Services - www.tritechair.com.au
    Stanley St E, Coorparoo - +61 7 3397 2266
    Oct 03, 2009 | GE APH10AA Air Conditioner
    Heating & Cooling Logo
    51 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Donni Steen
