Print head not moving into replacement position
SOURCE: iP2000 print head won't center
try to unplug the printre while the print assembly is on the middle
SOURCE: Canon MP780 print head won''t move automatically
THis may be a stupid suggestion but normally, you must open some housing part to force it to center for service or cartridge replacement and the closure of the same access part causes the carriage to return to its hiding place.
With the power on, gently push against the carriage in either direction. If it doesn't fight with you, the belt may be either off a pulley or torn.
SOURCE: I get an error message c000 when i turn on my
Feeder unit and / or purge unit defective.
Blocked Zahnrad-/Kupplungs-Verbindung between the two systems / defective. The purge unit pump or hose is clogged...recommend having serviced by tech.
SOURCE: Pixma MX860 - Error Code U052
Kindly follow this link: http://support-hk.canon-asia.com/contents/HK/EN/8000138702.html
Thanks
Sachidanand
Testimonial: "Thank you. I thought I had already reseated the component, but the graphics of this response were very helpful to insure I did not miss a step - K"
Hi, please get new driver here:
www.driversdown.com/
www.nodevice.com/driver/company/Canon/Printer.html
www.usa.canon.com/cusa/office/products/.../hs_1200ts
Jay klhnc
