U2 ERROR IN WORKCENTRE 5020
SOLUTION FOR U2 CODE
  • 13 Answers
SOURCE: Sharp error code U2
you can get rid of this u2 by pressing buttons as follows: # , interrupt, C, interrupt sequentially. then enter the no. 16 and press the start button. good luck
Posted on May 19, 2008
SOURCE: Error code U2-40
u2-40
Posted on Sep 10, 2008
sir fixalot
  • 146 Answers
SOURCE: Error code U2 on a AR201 copier
To find out the sub code for the U2 error hold down the Start key. Below is a list of the errors:
U2-04 EEPROM serial communication error
U2-11 Counter check sum error
U2-12 Adjustment value check sum error (EEPROM)
U2-40 CRUM communication error
To clear the U2-40 error try pulling out the toner cartridge and firmly reinstalling it. If that doesn't work you must install a new toner cartridge. There is a CRUM chip on the cartridge that keeps up with how many impressions have been made with that cardridge. You cannot "refill" these cartridges without replacing the CRUM. This problem occurs frequently with remanufactured cartridges.
To clear other U2 errors you must enter simulation mode.
Perform the following procedure to enter the simulation mode.
Clear key - Interrupt key - "0" key - Interrupt key - 16 - Start key - Start key. The unit should reset.
Posted on Nov 11, 2008
  • 990 Answers
Hello sir; This error code it can be reset folloe the instruction;
1, press "clear", "interupt", " 0 ", "interupt"
2, enter 16 then press start.
Posted on Jun 01, 2009
xptareq2000
  • 1447 Answers
SOURCE: u4 in workcentre 5020
it is problem your printer cartridge chip is demage change it and buy a new one origin
Posted on Aug 04, 2009
XEROX WorkCentre 5020 given error code u2
That error signifies a carriage fault with the ccd scanner under the platen glass. Check connections of flexible cable and verify that the carriage moves left to right upon start up. If connections are okay you either have a defective IIT Carriage or IIT Carriage Sensor.
Apr 27, 2016 | Xerox Office Equipment & Supplies
U2 code for xerox work center 5020
U2-1 Carriage Module Fail
Maybe you can find more information in the service manual. About error codes go to page 20
Apr 16, 2014 | Xerox Office Equipment & Supplies
Xerox workcentre 5020/Dn c1 error
i have one xerox 5020 machine, there is display showing C1 error code in first tray and C3 error code in bypass tray .if open and close the machine will be idle and ready to cpoy. there is no paper pick up in both trays. please help to resolve the problem.
Dec 17, 2012 | Office Equipment & Supplies
Getting u 2 error with my sharp AR-5020 please help
U2 - EEPROM read/write error (serial communication
error)
Mar 05, 2011 | Sharp AR-5320 Black and White Copier
I have a xerox 423 with au3-5 error.whats up?
i have a xerox 423 with u2-3 error code whats that
Dec 07, 2010 | Xerox WorkCentre Pro 423 Copier
My Xerox Workcentre-5020 machine showing U4 error. How can I solve this problem ?
@basanta711, Press 0 for 5 seconds then press green (start) then 50, green, 20 green, 0, green then on/Off the printer........... problem is solved
Nov 07, 2010 | Cell Phones
CODE U2
A U2 is related to a memory failure. May be a bad memory chip or main board. BUT, before we get drastic and move in that direction there are a couple of other things that I have seen cause that.
So, first I have seen the chip on the back of the drum cartridge cause that problem. You can try removing the drum cartridge and powering on the machine without that installed. See if it just comes up with a J2 code then. Or even a CH code. If the code changes you may simply have a failed drum cartridge.
Sometimes memory corruption can occur and you can clear it using this procedure..
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Jul 23, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
421 people viewed this question
jasbo
jasbo
