Question about Linksys WRT160N Wireless Router
WRT160N: Can't connect internet to router
So there was a blackout around my area 2 days ago. Once the electricity came back on, I was able to connect my desktop and iphone to my router with no problem but then it said "No Internet access". I'm connected right now straight from the modem itself through my desktop. All lights are flashing accordingly and I'm just thinking is it the wires that are the problem or the placement of the wires or it's really the router itself. I'm not much of a techy girl so try to ease up on the technical terminology while you're at it.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 38 Answers
I think you should reset your router. There is a red small button in the back or the bottom side. Press it around 30sec after release it and turn off the router(take out from the power). After 1minute turn it on again and wait until the led lighting well. If you do this methot after you have to make security settings again. open your browser and type the address usually http://192.168.1.1 after that login:admin pass: just leave it blank. if you not sure about the security setting ask somebody close to you to help. i mean WPA and other wifi network protections. so nobady can steal your internet.you can try this process to but that is quite complicate if you do not know so much about routers.
http://www.computing-tips.net/Reset_Linksys_wrt120n_default_settings/
Posted on Dec 06, 2012
  • 3 more comments
  • Jacque Avalon Dec 06, 2012
    I actually restarted it for like 10+ times yesterday and it still won't work.
  • Endre Nagy
    Endre Nagy Dec 06, 2012
    Yes but i talking about RESET not RESTART. There is big difference. Restart just restart the router but the reset is take the default settings as you bought it. Sometimes the electronic stuffs get crazy and need to reset them.
    So I just restore it to its factory defaults?
  • Endre Nagy
    Yes you can do that if you do not know so much about router settings. Because if the cabel from the router to your computer is working than the cabel is working. So it can just the router i think. Sometimes my router is get crazy too. I just reset it and set the things again. wifi password is the most important. I do not no what type of internet you have but if you just plug in the cabel from the modem to the pc and it's working then i think you get automatic ip so you do not need to setting so much after factory reset.
  • Jacque Avalon Dec 09, 2012
    So I have an update: I checked my wifi signal and the yellow caution sign is gone and it says Im connected to my internet. So I checked my phone and I tried to connect to twitter but it still doesn't load my tweets and stuff. So I checked the connection status of my WIFI and it says that the IPv4 connectivity has internet but my IPv6 Connectivity has no network access. What can I do with this?
SOURCE: configure WRT300N wireless Router to connect internet using PPPoE
Often the nets and subnets are NOT the same.. ie The Fixed connection often uses 192.168.0.1, 192.168.1.1, however sometimes the wifi is setup 10.1.1.1, or 10.0.0.1 etc, have you checked this? Esentially tho ya router is an "Acess Point" and ya Lappy etc is ya "Client" the links below has a lot of tutorials to help have a look. http://portforward.com/routers.htm http://portforward.com/guides.htm
Posted on Aug 05, 2007
  • 31 Answers
SOURCE: LInksys wrt160n v2 wireless router not connecting to internet
Most cable companies will only allow 1 active device at a time conneceted to the cable modem. When ever you change what is connected to the cable modem you must always cycle the power/reset your cable modem.
When you are reseting the units, always rset the cable modem first, wait until it boots back up then reset the router. If that doesn't fix the poblem then it may be a configuration problem.
I forgot to ask if you are cable or DSL.
Hope this helps
Posted on Apr 09, 2009
  • 73 Answers
SOURCE: Linksys wrt160N router inconsistant internet connection
Check on your cables makes sure they are inserted properly and the cord should be free of kinks, scrapes or loose connections......Also check the back of your computer make sure your ethernet card (the one that has the green lights/LED's) is seated properly (not loose)....
Good Luck.....hope this helps...if not let us know....cheers
Posted on Apr 13, 2009
  • 22 Answers
SOURCE: cant connect to the internet with linksys wrt160nv2
if this is DSL connection then you have to configure your modem before you connect router
follow this
first disabled wireless on your modem/router
.1) Turn off DHCP on your modem/router I am assuming this is verizon westell
2. Configure the first VC port to Bridge-Bridge mode
3. Keep hitting "apply" in the windows until the 7500 reboots
4. Plug the "Internet" port on the linksys to one of the normal ethernet ports on the modem /router
5. Turn on the Netgear and wait for the green Internet light to go solid
good luck if this does not work provide more info on your setup
Posted on Jun 12, 2009
SOURCE: can't install linksys wrt54g2 router with arris tm602g modem
I've tried network magic and everything thing else and I still can't get it to work.
Posted on Dec 19, 2009
Connecting pc's to a router
Try to use reset button on your router. Than change network settings to auto in your PC's. Should help.
May 08, 2012 | Linksys WRT160N Wireless Router
If the wireless router is connected to the PC
You are using WRT160N router. This router has issues with the firmware.
Try to upgrade the firmware of the router. Firmware is the software of the router.
Download the latest firmware of the router. Go to the manufacturer's web site and download the firmware of the router.
Open the set up page of the router and upgrade the firmware of the router. Once you upgrade the firmware of the router, reset the router.
On the router you will find a small reset button, hold it down for 30 seconds. release it. wait for 1 minute. Now unplug the power to the router and plug it back in.
Now you will need to reconfigure the router according to the Internet service provider.
May 17, 2010 | Linksys WRT160N Wireless Router
Continually disconnects internet at random
You have WR160N router. This router has issues with the firmware.
Apr 27, 2010 | Linksys WRT160N Wireless Router
Cannot detect network connection
Instead of running the CD, try to configure the router manually. First, make sure that you have verified internet connectivity between your PC and your modem. Once verified, connect your modem to the internet port of your router and then your PC to any of the ports (1, 2, 3, or 4) at the back of your router. Turn ON your modem, router and PC.
On your PC go to Start>Run> then type "cmd" and hit the Enter key.
On the black screen type ipconfig/all and hit the Enter key.
Check the IP address of your Local Area Connection.
If it is 192.168.1.xxx, then you are good to go.
Check the connectivity between your PC and the router. On the black screen type ping 192.168.1.1 and hit the Enter key.
If you're getting replies, minimize the window and open a browser.
Type http://192.168.1.1 and hit the Enter key.
Once prompted with a username and password type admin (admin is the default password).
Once you're on the Web interface of the router, enter your internet connection type and then save the settings.
Once done, click on the Status tab and then check the internet IP address.
If there's an internet IP address, try to open a new window and see if you can access the internet.
Jul 03, 2009 | Linksys WRT160N Wireless Router
Apr 13, 2009 | Linksys WRT160N Wireless Router
Lost internet connection
Change the wireless channel of the router to channel 1, 9 or 11. Usually other routers use channel 6. If there are other wireless devices on your area like a wireless cellphone, microwave, try to relocate them or the router itself. Place your router on a higher location so that you will be able to get a better signal.
Feb 09, 2009 | Linksys WRT160N Wireless Router
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
Linksys WRT160N Wireless Router  Logo
217 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
