Question about Panasonic SC-AK500 CD Shelf System
House already wired up for wall speakers (2 wires) BUT
My stereo speakers have 4 wires per speaker, can i bi wire? I have a Panasonic sa pm29
THanks in advance
    Genius:
  • 1,175 Answers
Hi...
The 4 wires are 2 for the treble/midrange 2 for the bass.
You can tie the wires in parallel ( one wire from one pair to another in the other pair and repeat) but you need to know how many "ohms" the stereo can handle.
Should say on the back of the rack system
Posted on Jan 12, 2009
Not getting sound through the speakers but can through head phone
Check speaker wires have not come out off the sockets at the stereo end .at the back of the unit you should have a place where you put the wires . Normally these have a couple of clips . Open the clips and push the wires into the holes then close the clips afterwards . Repeat for both sets of wires . Your speakers should then produce sound
Apr 20, 2014 | Panasonic Audio Players & Recorders
How to hook up Panasonic SB PM19 speakers to SA-PM23 reciever
yes you can. these are called "bi wired" speakers which means there's a hook up for the woofer and the tweeter individually. If your amp have just 2 speaker hookups it's no problem to hook the woofer/tweeter wires of each speaker together. If your amp had 4 speaker hookups, you could put the tweeters in 1 and the woofers in the other but it will still work fine with 2 speaker hookups.
Mar 21, 2013 | Panasonic Audio Players & Recorders
I have a panasonic SA AK25 with no manual.There are 2 sets of wires coming out of the speakers .how do i hook them up at the back ,thanks
you need a basic meter to ohm out the wires. most speakers ohm out around 8 ohms. some speakers have wires that can hook up to more speakers. others use an external power source to boost the output of the speaker. I would ohm out the wires and find the closest thing to 8 ohms. then with a small 1.5 volt flash light (AA) or (AAA) battery you go across the wires that you think are the load (speaker) if you hear a poping or crackle sound then you have found the wires that are the speaker wires. this would be the wires to hook up to the amp.
May 01, 2011 | Panasonic Audio Players & Recorders
Do i have to remove the pin between the two speaker treminals on my old mission 780 speakers before i bi wire them
Yes, the two sets of terminals are for the tweeter and bass driver.
When you bi-wire you want the low frequencies to go only to the bass driver and the high frequencies to go to the tweeter..
Please see this link for more information:
http://www.brilliancehifi.co.uk/how-to-bi-wire-speakers.htm
Please rate my answer if you find this useful.
Thanks,
Chris
Mar 02, 2011 | Mission 780 Main / Stereo Speaker
How do you hook up the speakers to a receiver. It has duel inputs. Is it two separate channels, or what?
Hello,if the speaker has 2 red and 2 black connectors then its designed to have an option for bi-amping and or bi-wiring.If you dont intend to do either than simply connect the reds together with a speaker wire and do the same with the blacks(if there is already a metal post connecting them than dont do anything but connect your speaker to the reciever as usual.
Jan 19, 2011 | Digital Audio DA-600SL Main / Stereo...
Will Bi-wiring these speakers give a noticable difference in audio sound quality ?...I'm using them with a Harman Kardon HK 3490 receiver..
Hi gregorygoff
This speaker is already having its own crossover PCB inside the box, the xover frequencies are all set as per the speaker's response. So, there will be no point making it Bi-wired.
Dec 15, 2010 | JBL ES30 Main / Stereo Speaker
Speakers to amp
With the CLS-215 speakers, you can Bi-Amp or Bi-Wire them.
Here is how to Bi-Wire and Bi-Amp Speakers:
http://www.oregondv.com/Audio_FAQ_Bi-Wire_Bi-amp%20.htm
Jul 13, 2010 | Cerwin Vega CLS-215 Main / Stereo Speaker
Pioneer car stereo instalation
if they are all positive speaker wires then each speaker will get a positive and the other speaker wire goes to the ground of the ground wire
Oct 12, 2008 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
2002 Chevy Cavalier audio wiring diagram
to the guy who is looking for the wire diagram, you can buy a wire kit for the stereo connection for about $60 from best buy or some other place like that. your car's door ding and some other things wont work with out it. hope that helps you some.
May 30, 2008 | Car Audio & Video
Bose amplifier does not work with a 6 speaker selector
your wall speakers may not be connected.... disconnect each speaker from the selector box and test with a small AAA battery to see if they are connected by putting the battery between each speaker's wires , you will hear it crackle ,then gradually connect each wall speaker onto the speaker connector box . If the first set does not work i suggest there may be a problem with your speaker selector box . Good luck
Mar 18, 2007 | Bose Lifestyle SA-3 2-Channel Amplifier
Panasonic SC-AK500 CD Shelf System Logo
335 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
