Question about Lexmark X2600 InkJet Printer
X2600 wont print from computer to printer
Everything works except printing from computer to printer
  • Official Brand Answer
  • 3,344 Answers
Try to uninstall the Lexmark driver and download an updated driver online: http://bit.ly/123oqJU
Also, check your security software if it's blocking the printer.
Posted on Dec 10, 2012
toddg
  • 171 Answers
SOURCE: Will not Print
Try a hardware check of the printer first. To check the hardware of the printer, do the following:
  1. Switch off the printer.
  2. Load one sheet of paper into the paper feeder.
  3. Press the Power button and the Paper Feed button at the same time and hold them both down for three seconds. Then release the Power button only.
  4. When the printer begins to print, release the Paper Feed button. A page will be printed. The page should contain some text at the top and a series of horizontal color lines (cyan, magenta and yellow) below the text, with a thick black line below the colored lines. All the lines should be solid.
  5. When the test is complete, switch off the printer. NOTE: If you do not switch off the printer, it will continue to print.
Posted on Sep 24, 2008
frankzjm
  • 191 Answers
SOURCE: Lexmark X2600 printer will not print in black and white
you may check your only black ink cartridge
longer time less using cause ink chanel(holes) dryer, could not print out even refilled.you may take out the ink cartridge and put it's surface of bottom (just touch ) in the clean water 1 -2 Hrs, then set back and test it. still not fixed, you also need to do same thing if your print head is separated from your ink cartridge
Posted on Feb 06, 2009
SOURCE: lexmark x2600 printer
Pull the tray out at the bottom of the printer. This is causing the printer to think it has a paper jam. It is simply the paper feed button.
Any other issues email me at derrickfoster3@gmail.com
Posted on Feb 25, 2009
  • 27 Answers
SOURCE: My lexmark will print page, business cards, labels, pics, etc. But it will not print envelopes. Looks, sounds, and acts like its printing. But when it spits out the envelope nothing is printed on it.
There must be an issue with the size of the envelope the printer is expecting. If you're using Microsoft Word, check under "Letters and Mailings" and then "Evevolopes and Labels" to check the size you have set the envelope to. Perhaps its also a setting in File and Page Setup or in the printers own settings under Control Panel and Printers. Sorry for not being of more help but if its not jamming or giving an error then its probably just set to the wrong envelope size.
Posted on May 17, 2009
SOURCE: Paper jam in my new Lexmark x2600 inkjet printer
I had the same problem with it jamming every time that I printed. I took it a part and found that a pencil had fallen into the bottom of the paper feed. I removed it and it works fine now.
Posted on Aug 17, 2009
Im trying to print a black and white document but it wont let me print because my color cartridge is missing
The Lexmark X2600 requires both cartridges to have ink in them to continue printing, even if your printing in "black and white". To print true black, you actually use some of the color ink. , Leaving the color cartridge empty or dry isn't good for the printer. It can lead to poor print quality issues.
Sep 22, 2011 | Lexmark X2600 InkJet Printer
My lexmark printer is doing everything it's supossed to, but it's NOT printing. There isn't even any paper jammed. what could the problem possibly be?
Try to disconnect your printer from your computer. Then unplug and replug the printer into the power outlet to reset itself. When the printer turns on, reconnect to your computer. Doing this usually fixes minor communication issues. If that doesn't help, try to check and make sure the print spooler service is running on your computer. Refer to this article: How to Restart or Reset the Print Spooler in Windows.
Apr 11, 2011 | Lexmark X2600 InkJet Printer
My lexmark x2600 keeps telling me i need to realign the cartridge but nothing is really wrong.. wont let me print anything but alignment test pages. How do i fix this
One of the utilities included with the Lexmark software will print a "test" page.
Then, you view the test page, and enter some numbers into the utility.
The utility uses those numbers to (ectronically) align the print-heads.
Dec 18, 2010 | Lexmark X2600 InkJet Printer
My lexmark x2600 printer wont print where can i get a free manual?
Navigate into this site, you can download free user manual of lexmark x2600..
http://www.retrevo.com/support/Lexmark-X2600-Multifunction-Printers-manual/id/17669bh333/t/2/
Thanks,
Nov 20, 2010 | Lexmark C533DN InkJet Printer
Can i wirelessly connect my Lexmark X2600 printer to my Toshiba Laptop
I regret to inform you that the Lexmark X2600 is a USB based printer, however, you can use a wireless print server to turn this printer into a wireless one. You can check the internet on how wireless print servers work. Thanks.
Aug 11, 2010 | Lexmark X2600 InkJet Printer
Computer says it is busy when I try and print out a page, just installed new black ink cartridge and it won't try and print anything now.
1. Check to make sure the black ink cartridge is installed properly.
2. Check to be sure no printer alignment program is trying to run.
3. Right click the printer icon on the tool bar and see if any print jobs are still lingering. Cancel them or Restart them. Printer should pickup and start working from there.
Last resort:
4. Shut down the computer and unplug the printer for at least 1-2 min.
Restart everything paying close attention to any error messages.
If none, the printer should work again provided nothing serious has happened.
Hope this helps!
Oct 17, 2009 | Lexmark X2600 InkJet Printer
Printer is not printing - i have started, restarted diagnosis tests, changed the ink, uninstall and installed program. I have a Lexmark X2600. It says that it's ready; but still doesn't print? what else...
Check the USB cable to make sure it is connected, then restart your computer. Sometimes the computer registers it on a different USB port. When you go to print look at your printer options, is there a Lexmark and a Lexmark (copy 1)? Try printing from Lexmark (copy 1) if it is showing. If there is still a problem, try putting the print on another computer, to see if the printer is malfunctioning. If that is the case, you'll need to get another printer.
Sep 14, 2009 | Lexmark X2600 InkJet Printer
Will not print; has worked great until now. I did
make reset to the printer
and restart the computer
daniel
http://rylwy.com/
Aug 17, 2009 | Lexmark X2600 InkJet Printer
Changed printer cartridge in my lexmark x2600. now how do I get it to print. it went off line from my computer.
Go to start> settings> printers> and double click the printer icon, then uncheck use printer offline under the printer menu. Also make sure Pause Printing is unchecked.
Aug 10, 2009 | Lexmark X2600 InkJet Printer
May 17, 2009 | Lexmark X2600 InkJet Printer
Lexmark X2600 InkJet Printer Logo
198 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
