Question about Hotpoint Washing Machines
ULTIMA WDM940 RUBBER INSERT COME AWAAY - Hotpoint Washing Machines
Hotpoint WT960
get some descaler part No C00090908 that should sort the smell as for the seal you will better off replacing it
Jan 26, 2012 | Hotpoint Ultima WF860 Front Load Washer
The message lamp on my KX-T7630 won't turn off! I don't have messages or any new info.. help!
Without picking up the handset, press the messages button and look at the display! Softkeys 2 and 3 should become something else, one of them being CLEAR. Press that button until your messages go awaay.
Carl
Sep 17, 2009 | Panasonic KX-T7630 Corded Phone
Capresso Ultima 121 rubber tube placement
I have the exact same tube that fell out of mine. Does your still work? I assume it has something to do with baffling the air intake for the frothing area.
Sep 15, 2009 | Jura Capresso Ultima 121 Espresso Machine
Changing door seal on hotpoint ultima washing machine
hello if you take the top off the washer and look down inside you should see a metal ring with long screw and nut unscrew this so it's loose you should be able to pull the seal off .then on the front of the washer where the next part of the seal is theres another rmetal thin bit of wire . unscrew the platic clip and the wire should come off. then just pull the seal out of the washer and when you put the new seal on fit it the same way you took it off good luck ps get back to me if you get stuck
shaun
Sep 06, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wd860; My washing keeps coming out smelling musty even though I use conditioner regularly. Is ther a filter I need to clean out. Thanks
you need to clean the draw and the inside of the draw and clean the rubber door seal all way round when you done that use a washer clean detergent whitch should be at a super market. and run it at 90 or 95 temp cottons wash it should stop the smell beacause dirt is buliding up so a good clean should stop it.hope this helps.
Sep 02, 2009 | Hotpoint Ultima WF860 Front Load Washer
Door seal has two holes in it and leaking
Hi.
You need to remove the front console panel and then the front panel to change the door seal.
Pull the dispenser drawer out and remove the screws.
Slide the console panel to the right and support it while you remove the rfont panel.
Change the seal, and reassemble in reverse order.
Good luck.
Nov 20, 2008 | Hotpoint Ultima WF860 Front Load Washer
Sgh-d900
throw awaay the thing or try the hair dryer
May 21, 2008 | Samsung SGH-D900 Cellular Phone
Washing Machines Logo
22 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
