Question about Dell OptiPlex GX270 PC Desktop
I have no power button lights but have an orange light on motherboard
When put power lead in back fans start then stop
    Guru:
  • 571 Answers
I suggest that you reset your memory stick inside your computer. If you have two memory/RAM sticks inside, then try using one. Try starting your computer. If no go, try unplugging the DVD drive - then start the computer. And do the same thing with the other components.
Here's the situation: Your computer's hardware part has a problem with it. You have to isolate that part that's causing it. If this seems hard for you, then I suggest that you get a technician for that.
Posted on Dec 06, 2012
  • 85 Answers
SOURCE: dell dimension 5100, power button has turned orange
If under warranty contact Dell? I had this same problem, a new motherboard and fan assembly fixed this problem. Bad capacitors on the motherbard.
Posted on Apr 12, 2008
  • 326 Answers
SOURCE: Dell optiplex won't Boot-up.. Orange light on motherboard
its going to rather your power supply or your motherboard has died, id try a different power supply first
Posted on Aug 11, 2008
SOURCE: Orange light on Dell GX270 power button
I agree, the Optiplex GX270 is infamous for MoBos going bad. The capacitors have a manufacturing flaw, and up until February of 2008, Dell was replacing those boards for customers for free if it was found that the capacitors were the culprit. I just found a board yesterday with this problem. A sign that the capacitors are bad is either a buldge or they will be leaking an orange-rusted looking substance (primarily capacitors near the CPU). Symptoms of this problem include the PC rebooting itself randomly, and/or getting a BIOS error saying there was a thermal event.
Posted on Oct 14, 2008
SOURCE: optiplex 755 flashing orange power button light only
Sounds like you only have power going to your motherboard.
The power supply might be bad on it, that or maybe the power cord is going bad and is only letting a small amount go through. I don't see why there should be a problem if you have even a little bit of power going though.
Posted on Jul 11, 2009
Current009
  • 135 Answers
SOURCE: Dell optiplex 330 flashing orange on the power botton
Try to clean the RAM and place it again in the motherboard.
Posted on May 31, 2010
Can i test the on/off button to see if its broken
If the fans start up and stop it sounds like a power supply problem and the power supply is shutting down to protect itself. You may have short on any of the power supply leads or in the motherboard.
Sep 10, 2014 | Computers & Internet
I have a Toshiba satellite L655 - SW5096. went to turn it on but will not start. No fan, no screen. Only the power light indicator and a steady orange light . The orange light goes off if I remove the...
The orange light shows the battery is charging. It will turn green when the battery is fully charged. The white light shows there is power entering the computer.
The usual problem with a computer when there is no response to pressing the power button is that the motherboard has failed requiring the replacement of the motherboard.
If the computer is still under warranty there should be a free motherboard replacement, if not, and you are able to do the replacement, you can find motherboards for sale on various websites. Be aware that motherboard replacement for laptops can be expensive if done by computer repair shops.
Oct 20, 2013 | Intel Motherboard
Wont power up
My wont turn on too, There is a orange light on the tower, Green on the left, Battery ovel, If I push the restart button, also switch the power supply switch in the back, also unplug from it, Sometimes does it, Do ou know whats causing this to happen, Please let me know Thanks
Jan 26, 2013 | Asrock K10N78M Motherboard
We have 30 optiplex 360 now 10 pcs are not able to start the orange light remain when we click the start button what is th actual problems and how can i solve it
make sure the cpu has secure dust free connection and thermal grease
you might need to replace the psu
if you have added any extra devices to your computer you might need more power voltage or it might be faulty
also check all leads from motherboard to hard drive for secure dust free connections and ram modules cmos battery for dust free secure connections
hope it helps
Apr 10, 2012 | Dell OptiPlex 360 Desktop Computer
No power only orange power light
Hi, It most likely is a faulty power supply or a motherboard issue. Remove the power cord then press and hold the power button for at least 30 seconds. Then plug it back in and hit the power button. This will release any static buildup that might be in the computer and sometimes that causes it not to boot. If nothing is happening it is more likely your power supply than the motherboard.
Mar 19, 2012 | Dell Inspiron 530s Desktop Computer...
When i start my dell optiplex 330 pc, the power light will be blinking orange and all the fans on the pc do not work but the orange led on the motherboard works.
Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
good luck
Sep 16, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
Power button if flashing orange and nothing else works
It's likely that your power supply has started to go out. There are several different leads with varying voltages & amps. If your computer is getting enough power to make a light flash yellow or orange then this often means that there is something wrong with one or more of the voltages from the power supply. Sometimes it means that something is wrong with your motherboard. Like: burned out capacitors, resistors, & etc.
Jul 06, 2010 | Dell Dimension E310 PC Desktop
Intermittently the power button constant orange fan full speed
Try removing the battery from the motherboard if its not soldered and leave it for an hour then out it back in, that might reset you bios and fix your problem.
Nov 25, 2008 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Dell dimension 5100, power button has turned orange
Apr 12, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Gx260 pc wont start
Have you checked the post lights located in the back of the system by where the keyboard plugs in? There are is a row of 4 lights; either yellow or green. If the systems gets stuck at a particular post location, the lights will tell where. Good luck
Aug 16, 2007 | Dell OptiPlex GX260 PC Desktop
Dell OptiPlex GX270 PC Desktop Logo
41 people viewed this question
Alun Cox
