Question about Dell Inspiron 6400 Notebook
My dell inspiron 6400 will not boot.It says no bootable devices found. It has failed MATS Test, March A Test, March B Test, March C Test, March LA Test, March LR Test, March SR Test and it has error codes 2000-0321 and 2000-0123, what can I do
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 35 Answers
Most probably your harddisk is failing ....get a new harddisk and try to recover your data from present one...
Posted on Dec 06, 2012
djnick989
  • 1067 Answers
SOURCE: Laptop won't boot..
try new hard drive 1st ok
Posted on Jan 30, 2008
Pyrhyc
  • 2028 Answers
SOURCE: code error 0146 and 0148
Both of these are hard drive errors. Error 0146 is a failed hard drive or bad drive sector, and 0148 is that thew machine is no longer detecting the hard drive. Basically, your hard drive has failed and will need replaced. Replace the hard drive and you will be set. The best place I've found to buy hard drives is at pricewatch.com, they have the best prices on the market.
Posted on Jul 29, 2008
tanvierahmed
  • 118 Answers
SOURCE: When I try turning my
Try to listen the noise coming from H-disk and note that its normal or abnormal.. like clicking or something....
Remove your H-disk a try new one... its surely a H-disk issue...
regards,
Posted on Dec 03, 2008
Fixe_You
  • 1800 Answers
SOURCE: Cannot boot up Inspiron 8200
The configuration is the internal HDD is the Master on the Primary IDE bus, the fixed optical drive is the Slave on the Primary IDE bus, the Media Bay device is the Master on the Secondary IDE Bus. Pull the HDD and nothing will work.
The error occurs when either the HDD or optical drive becomes half connected to its connector. That locks up the bus and the BIOS reports both failed. Reseat one or both of the drives. The Inspiron cases flex too much because of the loose palm rest "feature"
plz give me a good feedback.
Posted on Feb 02, 2009
  • 11800 Answers
SOURCE: Dell Inspiron 5100 will not boot. Error ide
The hard disk is dead, it must be replaced and Windows reinstalled .
Posted on Oct 28, 2009
Testimonial: "Thanks, sad but true. It is an older laptop and was bound to need an upgrade. Thanks again."
Dell inspiron 6400 will not boot
It's something whit the LCD or LCD cabel. Take it to the service if you not so expert about taking a part the computers.
Dec 06, 2012 | Dell Inspiron 6400 Notebook
Dell inspiron 1525 shows black screen after dell logo?
The computer cant find a bootable device. Either your boot sector on your Hard drive is gone/damaged (most likely a virus) or the Hard drive failed. Start with booting with your windows disk and try to do a repair installation.
Nov 03, 2010 | Dell Inspiron 1525 Notebook
Dell won't boot up. The following problems isolated by F12: 3600:0123 Battery test failed 0F00:075D IDE device failed: the self test failed to read ... 0F00:0244 Block 1905 74359: uncorrectable data error...
sounds like a complete motherboard failure with a lot of other problems.
if you remove the HDD ( turn the machine over. 2 screws on the right.slide drive out ) and mount it in an external caddy you should be able to use another machine to access the drive and probably get most data off it.
Aug 02, 2010 | Dell Inspiron 6400 Notebook
My dell inspiron 6400 lap top will not do anything when i swich it on only show up the dell screensaver can u help iv tryed swoping the hard drive and it dosent help
I had a similar problem. I fitted a new hard drive loaded windows and on the first re boot i had no OS again.
I went into the bios checked the boot order and also the hard drive booting options. My settings had unticked the hard drive as a bootable drive. When i ticked it and installed the original HD it worked again.
At least i have a spare Hard drive in the draw :)
Jul 10, 2010 | Dell Inspiron 6400 Notebook
La batteria non tiene più la carica.può essere un problema tecnico
Battery for Dell Inspiron 6400 (5200mAh)
http://www.batteriamondo.com/dell-inspiron-6400.html
  • Availability: In stock
  • Voltage: 11.1v
  • Capacity: : 5200mAh
  • Colors: Black
  • Weight: 310.24 g
  • Dimensions : 156.30 x 120.00 x 23.04 mm
  • Customer review: 4.5star.gif
  • 100% compatibility with the characteristics meet or exceed the original
  • Performance using a spare battery for your dell inspiron 6400.
Feb 15, 2010 | Acer Aspire 5610-4648 Notebook
Trying to install drivers and utilities disc
First install Windows OS in your PC to make it bootable then the motherboard installer of Dell to install all utilities and drivers.
Jan 28, 2010 | Dell Inspiron 6400 Notebook
My laptop is a dell 6000 and it says there are no bootable devices
your hard drive has failed, on boot (dell splash screen) press f12 to bring up boot menu, choose diagnostics option, run this and it should confirm hard drive failure on dst short test (drive self test) and give an error code (e.g 2000 - 0142), trust me on this i am a dell field service engineer
Jan 14, 2010 | Dell Inspiron 1525 Notebook
I'm in the process of "downgrading" my Dell Inspiron 6400/e1505 from Vista to XP. Using nLite I have slipstreamed drivers downloaded from the Dell website and then created a bootable iso XP disk which...
Just boot from XP CD - pressing F12 should give you the option in Bios, allowing you to boot from CD when all is completed. Some PCs still need sata/scsi drivers loaded by pressing F6 in the install. If all fails read original manual that came with Dell 6400. If lost you should be able to download from dell support, using express service tag.
Dec 17, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
229 people viewed this question
Alun Cox
