Question about Lexmark Computers & Internet
Printer sharing problems
Cant seem to share the printer. it works fine on the computer that it is conected to but will not print from the shared pc
  • Jay Glendenning
    Jay Glendenning May 11, 2010
    What operating system is the computer connected to the printer and what operating system is the shared pc?
    Master:
  • 413 Answers
Can you see the printer from the networked computer? Have you gone into the printer properties and set it to share? Right click on the printer in printers and faxes and select properties. Click on the sharing tab and clickn on the circle next to share this printer. (Windows xp)
Posted on Jan 12, 2009
I cant print shared printer but can test print
If you're trying to connect to another computer, make sure that computer is on, that you have enabled file and printer sharing on both computers, and that file and printer sharing can communicate through your firewall.
For more Help Read... Troubleshoot file and printer sharing and HP Printer Installation
Thanks
Jun 27, 2014 | HP LaserJet 1022 Printer
Epson l100
SETTING UP A SHARED NETWORK PRINTER
Any printer that is connected to a computer and is connected on a LAN can be configured so all other computers on the same network can print to this printer. This means the computer with the printer attached to it MUST be booted up at all times when other computers want to access the printer.
You need to install the printer driver on the computer and configure it as a Shared printer.
The other computers on the network need to add this printer to their computer.
Follow these steps to set-up a shared network printer -
1. Connect the printer to the computer and install the printer driver.
2. Open Printers and Faxes - right click on this printer and click Sharing - click Sharing tab and click
Share this printer, and then if you wish you could change the Share name, then click OK
3. Right click on the printer - click Properties - click Print Test Page to confirm printer installation.
Follow these steps to configure the computers on your network :-
1. Open Printers and Faxes - click Add a printer - Next - select a network printer, or a printer attached
to another computer - Next.
2. Select Browser for a printer - Next
3. Click on and expand the Microsoft Windows Network down to the computer with the printer - Next
4. Select Yes for - Use this printer as the default printer - Next - Finish
5. Right click on the printer - click Properties - click Print Test Page to confirm printer installation.
May 07, 2013 | Computers & Internet
How to conect printer and i have only one lan conection it is not ossible to use at time net or printer
connect the printer to your computer through parallel cable or usb cable. install the printer on that computer and share it with the network. to share it, right click on the printer and select share. add drivers for other operating systems as needed. To set that printer up on other computers on you lan that might be wireless, just search for the computer its connected to through the network and connect to the printer. The computer that the printer is connected to must stay on so other computers can print.
Jan 14, 2011 | Office Equipment & Supplies
I have problem of local printer is connected to domain i cant shared this usb printer on other connceted same domain pcs Basically i have one usb printer and have 20 pcs all are in domain so i want to...
Well you install the printer on the PC required, then in the setup SHARE the printer. You must then install a printer in each one of the "Clients" when asked what sort, use NETWORKED printer and navigate to where ya Printer is on the network using the "Browse" and choose it, then ya good to go.
I have found a more detailed link for your Convience http://uis.georgetown.edu/software/documentation/winxp/winxp.network.printer.html
Jan 21, 2010 | Office Equipment & Supplies
Laserjet 1022 not printing on shared computers
on printer properties try to set on sharing tab check marks on : share this printer- render print jobs on client computers- list in the directory ..( all of this must be chacked).. on port tab see on what port is printer ..(tcp/ip - or virtual), on advance tab.. check alway available, spool print documents first., under security see if you have set group permission.. if you did not ,, add the computers to use this printer ( in most cases this is the problem).... if all of the above s set , and you can still not able to print .. enter in run...services.msc... find print spooler and restart it .. then try to print.
Dec 02, 2009 | HP LaserJet 1022 Printer
Wireless printing from laptop
If you have your laptop and pc networked you can simply "share the printer....If not, you have to do that first......then "Right click" on your canon printer icon in "Printers and Faxes", left click "sharing", select "share this printer and name it whatever you want.
Then go to "add printers" (on your Laptop), "add printer" (the add printer wizard comes up), click "next", slect "a network printer..", select "browse for Printer". In the next box you should see your home network, you may have to click on this to search for available resources, then you should see your printer, double click on it to transfer the files to your laptop. You can use this process for any and all printers you may have conected.
You are now sharing the printer from your PC, so keep in mind that it has to be "ON" in order to print from your laptop.
Feb 13, 2009 | Canon Office Equipment & Supplies
Sharing cannon printer MP170
If you want to make your printer a Stand-alone device (no need to be connected to a computer, just directly to the router) you may want to look at getting a Print-Server.
But if you just want to share the printers, you will have to install the printer separately on both computers (since they use 2 diff drivers for the printer), then share it on the vista computer. at this point you should now be able to print on both machines
Nov 24, 2008 | Office Equipment & Supplies
Use two computers with one printer
Printer Sharing (This is good for Windows 2000, XP and Vista)
Sharing will be very easy if your network is working.
You need to consider the computer where the printer connected as the "Host" and the other computer that wants to print to that printer as the "Client".
Before you do such sharing, you need to acquire each computer's IP address.
You can do it by accessing MSDOS Prompt and typing in ipconfig/all. Write down your IP addresses and the share name on a paper.
For your Host:
Install the driver, make sure that you can print on direct bi-directional connection (such as USB).
Go to Control Panel >Printers and Faxes* >Sharing >Share this printer >Type in your share name, good example is PRINTER (this is case sensitive).
For your Client:
Install the driver, make sure that you can print, same with the Host.
Go to Control Panel >Printers and Faxes* >Properties >Ports >Add Port >Add local port type in \\ (the IP Addressof the Host) \ (share name), click OK.
ex. \\192.168.1.3\PRINTER (watch your backslash, no spaces)
*Term used is "Printers" for Windows Vista and Windows 2000
Oct 23, 2008 | NetGear FS105 5x10/100 Mbps Networking...
HP 3100 LaserJet All-in-one Print Driver for Vista OS
It doesn't work in share mode either...It prints the pages incorrectly. I have the hp3100 connected to my xp pc and my vista laptop connects to it via printer sharing on my network. the xp prints fine but the vista doesn't print ok due to lack of driver support for it.
I have to resort to print to pdf and then take the pdf to my xp for printing. Its a half *** solution but if anybody out there made his/her own driver please post.
Jan 25, 2008 | HP LaserJet 3100 All-In-One Printer
Sharing srp350 network printer on win98 to winxp
You are correct with the conflict, although, it's a difference in drivers, i think what has happened is when you share a printer with xp, it installs the driver from the pc with the driver and printer attached, and as it is attached to a win98 pc, the full functions are probably unavailable,unlike an xp local driver.
Mar 06, 2007 | Samsung SRP 350 Thermal Printer
Computers & Internet Logo
102 people viewed this question
Top Lexmark Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Robert Monigold
Robert Monigold
micky dee
Are you a Lexmark Computer and Internet Expert? Answer questions, earn points and help others
