Hi I have a zanussi fs1055 door won't lock . I have replace the door lock but still won't lock . The end light just flashes and noting more !! I held the start button and the delay start button to try
  • 1,013 Answers
I had a similar problem and found this thread helpful:
http://www.fixya.com/support/t652698-machine_start_clicks_turned_door_open
It turned out that the machine needed to "finish" the cycle it thought it was in
Posted on Dec 06, 2012
  • 236 Answers
SOURCE: Door not locking and program reverting straight to end
initially i would replaced the door interlock then if no result the control boart could be faulty.
Posted on Mar 13, 2009
blueextc3221
  • 15935 Answers
SOURCE: panel will not unlock
The lock/latch has likely failed.
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
blueextc3221
  • 15935 Answers
SOURCE: door locked indicator light flashing
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Posted on Sep 14, 2010
blueextc3221
  • 15935 Answers
SOURCE: WILL NOT LOCK OR START
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Posted on Sep 15, 2010
SOURCE: Hi my Hoover Nextra 6
the lights indicated a blockade, remove the front panel at the bottom to reveal a drain plug, the blockage is most likely at the back of the drain plug as the drain motor impeler sits directly behind the plug.
Posted on Feb 20, 2011
Zanussi zwf 1437 starts cycle then stops midway. door light flashes. have to turn off machine at main switch to reset
This is a door lock fault, the lock is working initially but as the machine operates it fails, the only way to fix it is to replace the door lock assembly
Mar 07, 2012 | Zanussi Washing Machines
My Zanussi FS1455W will not start,when I close the door and switch on the end wash light (the bottom light) flashes and beeps five times pauses and flashes again five times repeatedly. please could you...
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 16, 2011 | Zanussi FS1455W Front Load Washer
Our Zanussi FS1455W ocassionally stops with 'End' light lit and 'Door' light lit, washes OK but does not drain/spin. All lights flash at this point. When we turn control knob to spin it...
I suspect there is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
John C
Jul 04, 2011 | Zanussi FS1455W Front Load Washer
Hi, I have a Zanussi Timeline 1400 front loader and after it has completed a wash, it will not do another wash for some time. If you select a program it will think about it and then say it is complete with...
Try this..
Reading Error Codes
1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an "E" followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up.
Jan 30, 2011 | Zanussi ZWF1450W Front Load Washer
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
Mar 13, 2009 | Zanussi ZWF1430W Front Load Washer
Washing machine door lock
undo clamp holding door gasket on cabinet and peel gasket back in the area of the door catch.
door lock is just held in by 2 screws from the outside and will come away when these are undone. on some models, there is also a small diameter pipe going to the door lock and take this off. note where wires go before removing them
Jun 25, 2008 | Hotpoint First Edition FEW12 Front Load...
Zanussi 1035E
you have to check the electric door lock first open the door then take out the metal ring posted on the rubber seal then you have two scews on the font where the latch of the lock unscrew it and change the electric lock
May 11, 2008 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
