TCD970 hotpoint ultima set and forget dryer and how do i fix it
F10- fault displayed on display panel and blowing cold air, changed elements and thermostats with genuine parts drief worked properly once then started to blow cold air again with F03 on display panel. what is F03 fault and how do i fix it
4 Suggested Answers
  • 139 Answers
SOURCE: hotpoint aquarius dryer
The t-stats have blown.. these are located on the top of the heater on top of the drum.. To check to see if their blown check the continuity if they are blown then there will be no continuity ... They come in a pair and are easily replaced.. All you have to do is take off the lid...
Posted on Nov 14, 2007
  • 108 Answers
SOURCE: My dryer is blowing cold air. I replaced the
if you hooked up yhe wires on the heating element check the thermostat it will be a oval shapef unit on housing of element and has wires going to it it may be bad.
Posted on Dec 28, 2009
barkencoa
  • 3463 Answers
SOURCE: my Hotpoint Ultima keeps displaying an F10 fault
F10 meanswater level pressure switch not sensing correctly, there could be a blockage in the switch hose or chamber, or the switch could be faulty.
Posted on Jan 17, 2010
Hotpoint ultima TCD970 dryer squeaking
hi check rear bearing is not worn push at rear of top of drum inside if you can feel it lift replace bearing or it could be belt wheel check bearing 1st
Mar 02, 2014 | Hotpoint Dryers
My Hotpoint Ultima keeps displaying an F10 fault and doesnt spin correctly. However, if I then switch it to a rinse and spin cycle it seems to spin OK.
Jan 17, 2010 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpoint condenser dryer but its just blowing cold air could you tell me what i can do to fix it thanks zoe
Sounds like your heating element and/or thermostats blown. I've just replaced both for £45. Is working fine now. However if you decide to go ahead and do this ensure that the element hasn't been damaged by any other reason (such as water getting onto the fan) otherwise the fault will reoccur. If your electric is tripping then water may be getting onto the element. The parts are relatively easy to remove and replace and are located behind a large metal panel on the back of the machine.
Jun 04, 2009 | Hotpoint Dryers
I have an e15 code on the lcd display
Are you sure it is E15 and not F15?
F15 on an lcd display washer/dryer indicates dryer element faulty. this being the case then it will probably require a new element fitting.
Hope this helps
Dec 05, 2008 | Hotpoint Ultima WD72 Front Load...
Wf860 Error Code: F10
hiya
this could be caused by a faulty pressure switch (controls water levels). but due to the machine sharing the same electrical components as indesit it could be a fault on the main pcb.
hope this helps
please dont forget to rate the helpfuness of this reply, thanks kj
Jul 29, 2008 | Hotpoint Ultima WF860 Front Load Washer
Re Hotpoint Ultima washing machine
this is a common fault you can get hotpoint to replace the board at a cost of £90 or buy a second hand board for about £40 sorry but this is your only option without sending your board to qer
Jul 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima tumble dryer error code f-03
i have a hotpoint ultima ctd80 which i have had the last 2 years, it has shown error codes f11, f10 and f15, every time i fix this problem by first switching off and unplugging appliance then removing small cover from back (middle with 2 screws) then larger panel that the smaller panel overlapped. once you remove these you will see the heating elements, remove the 2 screws at the back off this, remove cover carefully then at the top you will see two things (not very technical lol i am a woman), with a pin press the pin in the one with a hole, mine makes a clicking sound when i do it, not sure if it meant to but works for me. put all parts back together and thats the job done. make sure both fillters and water emptied regular, hope this helps and saves you a fortune on call outs
Jan 26, 2008 | Hotpoint Ultima WF860 Front Load Washer
Ultima Condensor Dryer
on the back of your dryer you have a heater behind the protruding panel... Either you heater element has gone, but most like the thermal cut outs have blown...these are located in the same area..they are small and round looking and are connected to them are wires either side. Anyways check the conitunity of the termal cut outs using a tester if no continuity then they are no good... hope it helps...
Nov 18, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
