Question about OCTOPUS Microfinance Suite Octopus Micro Finance Suite
I just bought Octopus box but does not work efficiently
Octopus box what do I need to use it
If I'm reading this right you have an octopus which is a second emergency regulator for your buddy if he is in trouble. Where the original regulator hooks to the valve that goes on your tank ther should be a blank with a screw in it . This is where the octopus screws in . You will have a rubber o ring in side. Put it on the end of the threads from the octopus hose and insert it into the hole the screw once occupied.. The screw is just there to fill the blanks hole and can be thrown out.
Apr 13, 2018 | Scuba Diving & Snorkeling
What is spanish octopus?
That is the octopus caught off the coast of Spain (you did know that Spain has a lot of water along its coast).
Feb 27, 2015 | Cell Phones
Samsung Galaxy Note 3 unlock code
you can use z3x box or octopus box or you can make sample order in any server of unlock and you can unlock it for just 21 usd
Dec 01, 2014 | Samsung Cell Phones
Have a Ikelite ( Octopus) housing that I bought for my Cannon 20D in 2006. Now I have a Cannon 60D. The housing works for still photos, but not for video. Can it be modified to work with my new cam
Yes, this may be possible, send it to Ikelite, if there is room they are able to add another control/knob or push-pin to the existing housing. Also if you have knobs you don't use and find them in the way they have a special plug that replaces an in the way knob. Goo-luck!
Jan 03, 2014 | Ikelite Housing For Canon 60d 6870.60...
My octopus leaks from the head (not the hose). Could it be an internal problem?
A rebuild or simple adjustment can make it stop leaking if it is coming out of mouth piece if it is leaking from anywhere but mouthpiece or hose connection it needs service.
Mar 26, 2012 | Oceanic Swivel Octopus, Scuba Diving...
Genesis "S.K.O." Octopus GS060 The above product is constantly leaking, not much but pretty much all the time, it does help depending how I position it but that should not really be the answer, It has been...
Hello, there are a few things that may have happened. Often octos pick up sand and grit when they get dragged on the bottom. Try a good vigorous shake in fresh water. After that your moving into badly seated diaphram, split diaphram or slight hole, badly adjusted spring etc etc etc. Would recommend that perhaps you get it serviced. Especially important if you have been using Nitrox. Hope that helps
Jul 17, 2010 | Genesis Scuba Regulator Octopus S.K.O....
Smell of octopus in freezer
well wat u will have to do is clean the entire freezer out
with warm soapy water
then put a bowl of vanilla esence in there for a while
Jul 19, 2008 | Carrier Beverage AirĀ® CRD5GE-1W-G...
Computers & Internet Logo
23 people viewed this question
Top OCTOPUS Microfinance Suite Computers & Internet Experts
David Payne
David Payne
Are you an OCTOPUS Microfinance Suite Computer and Internet Expert? Answer questions, earn points and help others
