Question about Samsung Televison & Video
Require a manual for a Samsung PS51D550 51" 3D P TV
My friend bought this TV not long ago and he said when the guy installed it for him there was a blue light which could be switched on or off around the TV screen - then he said as he was messing around with the TV finding out how it worked etc the blue light went off and now he doesnt know how to put it back on again - what he would like to know is Is there a blue light that comes on around the TV screen and if so how can he switch it back on?
james klgr
  • 362 Answers
SOURCE: Panasonic 50 inch Plasma
it could have over heated you can try to reset it first unplug it for about five minutes and try to turn it on if that dont work the remote might have a set button try holding that down until the red light flashes twice, then turn it on if not then hold the power button down on the set for a good five seconds to see if that resets it. if none of that works you will have to go to panasonic .com for the reset instructions.with the red light blinking the power supply is most likely good you just need to reset i.
Posted on Dec 24, 2007
Shuttle83
  • 1139 Answers
SOURCE: Hitachi 55" Plasma HDTV, 1 yr old, suddenly lost picture and sound, but power light still on.
It sounds like a shutdown circuit is being activated. This is normal in cases where the power supply id drawing excessive current. I would suggest that you get this looked at by a qualified professional. This is because this problem may be in the power supply and the voltages can get dangerous in this section of the TV set.
In any event if this is a power supply problem chances are the technician will just have to replace the power supply. Which should cost from 150-250 dollars.
I hope this helps
Shuttle83
Posted on Jul 14, 2008
  • 19 Answers
SOURCE: How to reset tv. Have sound but black screen
LCD's use a colorful crystal see through display which only visible when light is shining through it. if you have sound and no picture it's always a faulty PSU. Very easy to change out actually.
Posted on Mar 27, 2010
SOURCE: Samsung Series L3 360 TV
how to use pen drive in it
Posted on Jun 30, 2010
freetek
  • 5568 Answers
SOURCE: my olevia 42 in power doesnot come on. blue light
You may be aware that Olevia is bankrupt and apparently Emerson bought the leftovers and is offering service but no parts sales.
I found this thread discussing antoher model's various problems but I believe your power supply has likely failed.
Olevia thread
If it is the type of failure related to the switched-mode power supply, these can be repaired by a properly equipped tech; I've done hundreds of them while still in business (which I am no longer).
Posted on Dec 07, 2010
I bought my 46" samsung
The Capacitors on the Main Power PCB are failing which is why it's taking 3 attempts for them to charge before the TV will switch on.
These could be replaced for a few $ if you know someone with the technical ability and equipment.
Failing this it would require a new PCB at around $120 + fitting.
Jun 11, 2011 | Samsung LN46A650 46 in. LCD HDTV
I HAVE A 32" VIZIO LCD I PURCHASED 2 YEARS AGO.
You should buy a sodering kit and remove the buldging capacitors yourself. Find a local electronics store, I used Radioshack, and see if they can match the capacitors. I had this happen with my Samsung lcd about a year ago and just help another friend with the same issue yesterday. The sodering is not as hard as you'd think. The capacitors should be under $5 v. paying a few hundred for the power board.
Mar 21, 2011 | Vizio VOJ320F1A 32 in. LCD TV
Samsung RSH!NHSW fridge freezer Freezer fine. Fridge icing up. temperature between 8 and 10. Will not go lower. In cool place. Why?
We've just had exactly the same problem on our RSH1DBRS. After a recommendation from a friend of ours, we bought a DIY kit from Appliance DIY Repairs. It's a very simple repair, and ours is working just great. We had Comet out to it a month ago, but whatever they did never worked, and it went wrong again within a week. So it looks like the DIY idea worked!!!!!
Feb 07, 2011 | Samsung Refrigerators
I bought a Samsung AVR720 almost two years ago as well as a new Samsung blu-ray machine - to match our lovely Samsung series 6 TV (which our friend - who reviews all sorts of equipment - said was a really...
some of them require red , white, blue, green, an yellow audio jacks. make sure you have all the input plugs. or eles the tv will not use plugs it doesnt have.
Mar 05, 2017 | Samsung Televison & Video
I have two large spots on my screen on red one blue what is it? How can i fix it ?
Got the same problem with PT-61-LCX65 that was bought 4 years ago in 2006 - first red spot appeared, then few weeks ago got green one nearby. Fixed it for free.
I called Panasonic using the phone number in the manual (1-888-843-9788), selected Service, told that I got the problem which is most probably "a manufacturer's defect" that should be fixed for free - they redirected me to the next step, then to the next one and in about 20 minutes they arranged me a home-visit by a support person (the guy had to drive 2 hours to get here!). Everything went _very_ smoothly, I am very satisfied with Panasonic's support, it was just one call with few redirections.
The service guy came in two days, unscrewed the back panel, connected some kind of a box to one of the boards (eprom programmer?), turned TV onto some channel and let the box do its job for about 5 minutes - then all of a sudden the spots disappeared and the picture is OK now. The service guy told me that the overall picture quality should have been also improved all across the screen, I guess TV sends some kind of feedback to that box for optimization.
It was a free service, the service guy mentioned something about law action and that Panasonic is required to fix that for free.
Mar 06, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
Manual lost
You can download user manual for you LCD samsung TV from the follwing link
http://www.usersmanualguide.com/samsung/tv__lcd
You have the location (country wise) manuals, and in various languages.
You can download the required manual here.
Regards,
BEADHZ
Jan 29, 2010 | Televison & Video
We have lost a two inch wide black section on the right side of the plasma panel, any ideas
Most likely the lower buffer board " E " needs to be replaced. Right now I'm working on repairing a 42" Samsung plasma HP-R4272. The Service manual for that TV says for trouble shooting for that problem is the lower buffer board " E ".
Best to find the correct Service Manual for your TV over the internet to get the correct part number for replacement. The Service Manual should be less than $20.
Oct 25, 2009 | Samsung PS42P2S 42 in. Plasma Television
IT HAS A GREEN SPOT IN THE UPPER CORNNER
Got the same problem with same TV (PT-61-LCX65) that was bought 4 years ago in 2006 - first red spot appeared, then few weeks ago got green one nearby. Fixed it for free.
Aug 24, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
No tv picture
my less than 2 yrs. old hardly used Samsung plasma is turning off automatically for no reason within 10m minutes of watching. What could be the problem??????????
Mar 16, 2009 | Samsung HPN5039 50 in. Plasma HDTV
Open Questions:
Televison & Video Logo
32 people viewed this question
Jerry Greenberg
Jerry Greenberg
