Question about Xerox WorkCenter PE120i All-In-One Laser Printer
Driver Xerox workcentre PE120i windows 7 64-bit
5 Suggested Answers
  • 2072 Answers
SOURCE: soft copy of the printer
The guides can be located at Xerox.com under documentation. They can be downloaded easily
Posted on Jun 05, 2008
  • 17 Answers
SOURCE: unlock scanner
under the scanner where you retrieve you printed papers on the left side twords the front there is a slide lever (which is the lock for the scanner).
Posted on Apr 30, 2010
  • 79 Answers
SOURCE: My Xerox Workcentre PE120i screen
This is a fairly common problem with most printers. It is generally caused by something confusing the sensor that detects the paper.
1) Remove all the paper from the printer.
2) Switch off the printer and unplug from the mains for 30-45 seconds
3) Switch printer on
4) Put in paper
5) Try and print!
Most of the time this will cause the printer to "reset" itself and should print fine.
Regards,
sjstore2
Posted on Dec 20, 2010
  • 569 Answers
SOURCE: Need drivers for Windows 7
A Windows 7 driver is not available, but you may find that the Vista driver works OK. You can get it here:
http://www.support.xerox.com/support/workcentre-pe120-pe120i/downloads/enus.html?operatingSystem=winvista&fileLanguage=en
Posted on Feb 15, 2011
I have a xerox workcentre PE120i that displays "scanner locked".how do i unlock it
There is a lock switch below the control panel. When the all-in-one is first shipped, there is a label that wraps over the switch and up to the control panel. When the label is gently pulled out, it moves the switch forward into the unlocked position.
The switch is below the area to the right of the frequently-dialed numbers short-cut buttons. To see a picture of the approximate location of the scanner lock, see page 2.3 of the MFP User Guide (this is page 29 of the PDF). The manual is available on the WorkCentre PE120/120i support page in the Documentation section: http://www.support.xerox.com/support/workcentre-pe120-pe120i/documentation/enus.html?operatingSystem=win10x64&fileLanguage=en . The direct link to the manual is currently http://www.support.xerox.com/support/workcentre-pe120-pe120i/file-redirect/enus.html?operatingSystem=win10x64&fileLanguage=en&contentId=53827 .
I hope this helps. If the scanner lock is in the unlocked position and you still get the error, then there is probably an internal problem. Whether this is a problem with the hardware or a sensor is unclear. If your unit is under warranty or covered by a service plan, contact Xerox or your printer/copier service provider.
Mar 28, 2018 | Xerox Office Equipment & Supplies
Need drivers for Windows 7 for my xerox workcentre pe120i
Feb 15, 2011 | Xerox WorkCenter PE120i All-In-One Laser...
Problem connecting Win 7 64-bit to Xerox Workcentre M128 printer - Windows is giving a "no suitable driver found" error.
Try this link, it goes directly to the 64 bit driver download site.
http://www.support.xerox.com/support/workcentre-pro-123-128/downloads/enus.html
If that doesnt work. Go to www.xerox.com. Select support and drivers, in the search box, type 128, then go to the workcenterpro 123/128 and click on downloads and drivers.
You will find 32, 64 bit drivers for all OS.
Jan 27, 2011 | Xerox WorkCentre PRO 128 Copier
Unlock scanner
Apr 29, 2010 | Xerox WorkCenter PE120i All-In-One Laser...
Drivers won't load for xerox pe120i and new windows 7 install
This is NOT an uncommon problem with Windows 7. Many manufacturers have not updated the existing drivers for compatibility with Win-7... they want to sell new hardware! If the drivers that load automatically from Microsoft do not function properly then check on the Xerox site for updates - an email to customer support may help if you don't find new drivers on their site.
Feb 17, 2010 | Xerox WorkCenter PE120i All-In-One Laser...
Need printer driver for Windows Vista 64 bits for Xerox WorkCentr
http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=GLOBALPRINTDRIVER&ripId=&Xtype=download
You can try this driver. It may be quirky at first but it should work for basic printing needs. There is a PCL6 and post script try both sometimes it will take one but not the other. Its vista flip a coin :) -Phil
Jul 01, 2009 | Xerox WorkCentre Pro 423 Copier
Workcentre pe 120i memory full
in spec. say's so:
your workcentre Pe120 have only 32 Mb memory.
fax function is equipped with a 4 Mb standard memory.
In spec. shows a 4mb memory is just enough for 320 pages of fax!!!
i think your problem is given from the 32 mb of memory of workcentre pe120, not from fax memory, because the faxes received or delayed is compressed with a very strong altgorithm, and these files is very small.
http://www.office.xerox.com/multifunction-printer/multifunction-under-30ppm/workcentre-pe120-pe120i/spec-enus.html#Memory
a link bellow ; i think is useful:
http://www.xeroxdirect.com/direct/public/products/accessorizer/dsp_accessory.cfm
for a 32 MB memory module (product code is: 097n01434)
Sep 23, 2008 | Xerox WorkCenter PE120i All-In-One Laser...
Soft copy of the printer
Jun 03, 2008 | Xerox WorkCenter PE120i All-In-One Laser...
Xerox WorkCenter PE120i All-In-One Laser Printer Logo
87 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
